Old Jul 24, 2012, 05:31 AM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
The install was inside a BVM F16 and was done by the great Ralf Dorvak (RIP)
How ever you do it I would recomend to make sure its locked before flight and open it after landing. When I had mine I would taxi out with it open and close it before taking off. Well that was until a strong head wind kept it from locking and it departed the plane after takeoff.
gunradd is offline Find More Posts by gunradd
Old Jul 24, 2012, 02:12 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Wis, dont give yourself a headache with all those linkages just put a sub micro servo in the nose to actuate a locking pin and just program it in your radio (that's what most people I see do and it would be easy to do since you already cut the nose off the jet).
Back in post #795 I was talking about needing to come up with a way to install the canopy hinges so that I have access to my fuel tanks if I ever need to take them out (in the picture you can see the limited space I'm dealing with........May have to just live with a permanent install if I cant find a solution).
Was going to glue the two front bulkheads a while back but ended only gluing the middle one (holding off on the front till I finish the nose gear steering).
super kupfer is offline Find More Posts by super kupfer
Old Jul 26, 2012, 07:22 PM
Lance Nordby is offline
Find More Posts by Lance Nordby
I want to fly everything!
Lance Nordby's Avatar
Hillsboro, OR, USA
Joined Mar 2004
Yep, there's that hysteresis I was talking about. Saved me a sketch.
Adding a servo would probably be less fiddly though. And since you spent so much money on that radio...
Ok, I'll shut up.
Lance Nordby is offline Find More Posts by Lance Nordby
Old Jul 26, 2012, 09:21 PM
Wisdumb is offline
Find More Posts by Wisdumb
Wilsonville, OR
Joined Jun 2010
Wow, that is tight. It would be difficult not to make it permanent.
I may use the existing servo for the latch and buy a little bigger one with more torque for the canopy.
Wisdumb is offline Find More Posts by Wisdumb
Old Jul 26, 2012, 09:24 PM
Wisdumb is offline
Wilsonville, OR
Joined Jun 2010
Ok, I'll shut up.
If I use another servo it'll be on a Y because I've used up all my channels on the receiver. Doh!
Old Jul 27, 2012, 08:16 AM
gunradd is offline
KingtechUSA
gunradd's Avatar
Joined Apr 2009
I had 2 servos for my canopy and had them on the same channel. Using servo slow you can get it to work but it takes a lot of trial and error.
I had a big servo that moved the canopy up and down. Then a small micro servo the moved a control horn that I shaped like a hook with a dremel. I had it just forward of the canopy. It grabbed a small rail I had on the canopy.
Old Jul 27, 2012, 09:57 AM
EDF Crazy is online now
Find More Posts by EDF Crazy
EDF Crazy's Avatar
UK
Joined Oct 2007
Maybe you could try doing it with one or two Lado electric gear door actuators? you might have enough strength to not even need a locking mechanism, maybe just some vertical locating pins to stop any horizontal movement and rely on the actuator to hold it down. Just a thought...
http://www.lado-tech.net/en/e-doors/...door-30mm.html
EDF Crazy is online now Find More Posts by EDF Crazy
Old Jul 27, 2012, 11:34 AM
Joined Jan 2010
Those are so cool.
If they are strong enough it may be worth experimenting (I would go with two of them, one on each canopy hinge).
Old Jul 27, 2012, 04:40 PM
icicles is offline
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
I have a Lado on my Spark nose door, very strong indeed. Huge amounts of torque. Haven't measured it nor do i know how much. They aren't travel adjustable. They are designed to stop at each end of their stroke. I'm guessing they are current limited
Chris
icicles is offline Find More Posts by icicles
Old Jul 27, 2012, 09:07 PM
Joined Jan 2010
Chris
Too bad they are not travel adjustable.......no biggy.
Old Jul 29, 2012, 12:23 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
You can try this. Works pretty good, and fully programmable: http://www.hobbyking.com/hobbyking/s...dProduct=11258
ysolomon is offline Find More Posts by ysolomon
Old Jul 29, 2012, 04:06 PM
GudmundT is offline
Find More Posts by GudmundT
Gudmund
GudmundT's Avatar
Canada, ON, Ottawa
Joined Nov 2005
I managed to maiden my Yellow F-16 this morning. It flies wonderfully.
Check out the pictures and post-build comments here http://www.rcgroups.com/forums/showthread.php?t=1701338
GudmundT is offline Find More Posts by GudmundT
Old Aug 14, 2012, 12:46 AM
Joined Jan 2010
Love your work
Old Aug 14, 2012, 12:54 AM
Joined Jan 2010
Guys, ones you remove the none brake wheel adpt. off the main wheel axle and slide the brake rotor followed by the wheel, How do you get the nylon washer on prior to the c-clip (not much room left there and I pushed the brake rotor on the axle as far as it will go)??????
BTW, the foam wheels suck a$$, they dont even roll straight.
Old Sep 06, 2012, 06:42 PM
Wisdumb is offline
Wilsonville, OR
Joined Jun 2010
I'm back! Here's some torque rod installin' action!
Episode #75 (10 min 20 sec)
Discussion Yellow Aircraft F-16C Down Under - EDF conversion m898 Electric Ducted Fan Jet Talk 528 Oct 12, 2011 10:43 AM
Discussion Yellow Aircraft F-4 Turkish paint scheme wrp7317 Electric Warbirds 0 Mar 31, 2010 10:24 PM
Help! Yellow Aircraft f-16 manual needed raypadro Electric Ducted Fan Jet Talk 2 Mar 12, 2010 07:05 PM
Discussion Yellow Aircraft F-4 photopack? AAbdu Electric Ducted Fan Jet Talk 8 Mar 12, 2010 02:22 PM
Poll Online Build -- BVM F-86 vs Yellow Aircraft F-18 k_sonn Electric Ducted Fan Jet Talk 56 Oct 02, 2008 04:43 PM
