Old Jun 14, 2012, 06:19 PM
super kupfer is online now
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Im planning to put a P80 in my falcon for power, would 75oz/in servo be enough for the Ail???
super kupfer is online now Find More Posts by super kupfer
Old Jun 14, 2012, 06:24 PM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
The f16 will be a rocket ship with a P80 inside it.
If its a good servo you should be fine.
gunradd is offline Find More Posts by gunradd
Old Jun 14, 2012, 06:28 PM
Joined Jan 2010
Thanks Gun.
Old Jun 14, 2012, 07:19 PM
Lance Nordby is offline
Find More Posts by Lance Nordby
I want to fly everything!
Lance Nordby's Avatar
Hillsboro, OR, USA
Joined Mar 2004
Hey Wis, aren't there going to be any new episodes until next fall? I miss my favorite show.
Lance Nordby is offline Find More Posts by Lance Nordby
Old Jun 14, 2012, 07:24 PM
Wisdumb is offline
Find More Posts by Wisdumb
Wilsonville, OR
Joined Jun 2010
I'll have to get on it! Been bringing work home and it's been interfering with my F-16 project. I hope to have something up for this weekend.
P.S. looks like there are some 80mm stumax fans back in stock on that link I sent you!
Wisdumb is offline Find More Posts by Wisdumb
Old Jun 14, 2012, 09:44 PM
Joined Jan 2010
Hi Gun
On your "Yellow F16" build thread on post #112 I noticed that you did a mod of having the ail servos moved to the wings for easy wing plug in, can you give us your feedback on it.
I'm really interested in doing it as well due to wanting easy plug in wing setup for transportation reasons.
I was thinking of using JR DS378HV servos, what did you use???
Old Jun 15, 2012, 08:01 AM
gunradd is offline
KingtechUSA
gunradd's Avatar
Joined Apr 2009
It worked well with the servos in the wings. I used the digital hitechs back then that where for thin wings. I would not use them agian because I burned some out on different projects. The JRs should work well.
Me being so into scale like I am I much preffer the servos in the fuselage just for looks. The wingspan is not the big on this plane so I never took the wings off.
If you plan of pulling the wings off allot it would be worth doing.
Hi Gun
Old Jun 15, 2012, 11:29 AM
Joined Jan 2010
Thanks Gun.
I know what you mean about the wingspan being small but I also dont want it to be the only plane I take with me (I want to fit at least two planes in my GM Terrain).
Old Jun 16, 2012, 06:02 PM
Wisdumb is offline
Wilsonville, OR
Joined Jun 2010
Ok, here's a video recap of my last build post:
Episode #67 (8 min 49 sec)
Old Jun 16, 2012, 10:32 PM
Hillsboro, OR, USA
Joined Mar 2004
I would be remiss if i didn't voice my concerns regarding the CA on the wires.
I really like the idea in principle but my fear is that CA is stiff and will create stress concentrations that could potentially cause the conductors to break inside from fatigue. They will need to be supported well to prevent this. I might steal this idea but I would use a flexible glue like canopy cement or RTV.
Please pardon my pedantic pickyness Wis, but I would really hate to see this thing go in someday from a flight control failure.
Old Jun 17, 2012, 10:04 AM
Wisdumb is offline
Wilsonville, OR
Joined Jun 2010
Hey Lance,
Is your concern the wires themselves being glued together, or where I glued to the side of the fuselage (Where there may be bends, etc..?)
I'm actually trying to figure out how I can drill some holes in each bulkhead nearest where they are glued to the fuselage so I can run these straight through rather than having to make the 2 bends.
I guess if it does go down for something like that it would be totally scale as these things had/have a wire chafing problem that cause "catastrophic" failures. Too scale? I'll re-evaluate.
Old Jun 17, 2012, 10:36 AM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
I didn't see the video but I use hot glue for keeping the wiring in place and it works well. It's flexible and won't fatigue the insulation. I also learn that not matter how muh I plan and think ahead it's very likely I'll have to take apart stuff that was permanent. With the hot glue you just pull it off clean and no mess is left behind, on the plane or the wires .
Castel101 is offline Find More Posts by Castel101
Old Jun 17, 2012, 12:10 PM
Hillsboro, OR, USA
Joined Mar 2004
Well, if the wires are made to be stiff and there is vibration that wants to flex them then they may break over time. But if the wires are fully supported and can't move then it should be ok. I agree that hot glue is handy too.
Maybe I'm just being a worry-wart.
Old Jun 17, 2012, 01:56 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
What kind of CA are you using? The first time I dropped CA on a servo wire by mistake, I killed the servo, as the insulation came off the wires and I got exposed wires, all of a sudden.
ysolomon is offline Find More Posts by ysolomon
Old Jun 17, 2012, 03:07 PM
gunradd is offline
KingtechUSA
gunradd's Avatar
Joined Apr 2009
The CA is fine until you need to change something then it comes apart. There is no good way to get this plane all clean looking inside. Its a small plane with limited access and with gear doors and gear its a ton of crap with all the wires and airlines. Also you cant hide the rats nest with panels on top like you can with other planes.
Also a weak point on this plane is where the two halves of the fusealge join from lower to upper. When stressed this plane will sepperate thier and that is right where your wires are CAed too.
I am sure this goes with out saying but make sure you remove all those little screws on the rims beacause they do split and make painting them and installing tires a breeze.
Very nice install your getting close. Looks like a few days work and you can be flying it!
You should probably get it flown before you do all the finishing details. Those dry transfers are expensive and you want to get the plane all dialed in before you install them incase you need to repaint something.
Discussion Yellow Aircraft F-16C Down Under - EDF conversion m898 Electric Ducted Fan Jet Talk 528 Oct 12, 2011 10:43 AM
Discussion Yellow Aircraft F-4 Turkish paint scheme wrp7317 Electric Warbirds 0 Mar 31, 2010 10:24 PM
Help! Yellow Aircraft f-16 manual needed raypadro Electric Ducted Fan Jet Talk 2 Mar 12, 2010 07:05 PM
Discussion Yellow Aircraft F-4 photopack? AAbdu Electric Ducted Fan Jet Talk 8 Mar 12, 2010 02:22 PM
Poll Online Build -- BVM F-86 vs Yellow Aircraft F-18 k_sonn Electric Ducted Fan Jet Talk 56 Oct 02, 2008 04:43 PM
