Old Dec 05, 2012, 06:48 AM
Machineman is offline
Find More Posts by Machineman
Adicted to these things...
Melbourne, Australia
Joined Jun 2008
As a suggestion only if you would like to reduce the list...you could keep only the pilots single fastest time under 14s, as I see quite a few pilots with multiple times. You could still keep double ups for the historical times. E.g. I did 13.99 as well, but I don't feel the need to post it here as I have a faster time now. Just an idea.
Machineman is offline Find More Posts by Machineman
Old Mar 06, 2013, 08:08 AM
XCmama is offline
Find More Posts by XCmama
XCmama's Avatar
United States, FL, Titusville
Joined Mar 2013
What is the best for a junior pilot??
XCmama is offline Find More Posts by XCmama
Old Mar 06, 2013, 08:24 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
David Klein FS4, Gator F3B World Cup, 2013
3-1-13 13.01
3-2-13 11.90
3-3-13 12.70
Thanks Reto
djklein21 is offline Find More Posts by djklein21
Old Mar 07, 2013, 08:41 AM
Rich Burnoski is offline
Find More Posts by Rich Burnoski
Bolingbrook, Illinois
Joined Nov 2007
please add
Hi Reto
Richard M. Burnoski
Florida, USA, Gator F3b World Cup #1
March 3, 2013
13.85
13.10
Rich Burnoski is offline Find More Posts by Rich Burnoski
Old Mar 10, 2013, 10:41 AM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
I have the first 11.x flight on record at 11.98 as well as a 13.46 on 3-2-13 and 13.71 on 3-3-13.
Reto, you need to update the Shooter list.
mlachow is offline Find More Posts by mlachow
Old Mar 11, 2013, 12:35 PM
Glauco is offline
Find More Posts by Glauco
USA F3B Team Manager
Glauco's Avatar
United States, MO, Maryland Heights
Joined Jul 2002
Was it Reto that threw your Shooter for the speed record?
He must have been going to the gym
Nice flying Mike.
Glauco
Glauco is offline Find More Posts by Glauco
Old Mar 11, 2013, 12:42 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
It was pretty spectacular to see the 12 second barrier broken. It was smooth, and tight. Not out of control at all, very controllable. Although the air was good, it was even better at other times during the contest. It made it very clear that the 10 second barrier is possible with our current models. Kudos for showing us it was possible Mike.
Old Mar 11, 2013, 01:27 PM
RetoF3X is offline
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
@Glauco:
Yes, I work out. I was launching Mike's tungsten Shooter just before the line would have broken due to pre-tenison.
@Klein: I pay you a beer and Gator bites if you break the 10s barrier next time...
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Mar 11, 2013, 02:00 PM
mlachow is offline
Joined Oct 2005
I went easy on Reto and only put in 2.1Kg of ballast. It's possible to get more in there with all tungsten.
I made NO corrections for the entire run that I can recall. Just easy on the elevator and hitting a nice intersection of base A on a reasonably open pull onto the course. And each turn was very easy on the elevator, fairly open turns. Shooter can be turned much harder than what I did, but then the drag goes up in the turns. I heard the buzzers when the model was around 45 degrees into the turn so never any thoughts of missing the turn.
I wish I had the air on the course I had hooked over in the launch area. I never considered circling before entering the course.
The nice part was the thermal really smoothed out the air so there was no turbulence bouncing the model around like a lot of other runs.
I never expected to see a 11.xx run. But then no one expected Gavin's 12.72 run years ago. Now that was big lift.
Originally Posted by RetoF3X View Post
@Glauco:
Old Mar 11, 2013, 02:07 PM
Kiesling is offline
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Reto,
Some more times from the Gator.
Darrell Zaballos
Fosa
13.72 3/2/2013
13.51 3/3/2013
13.12 3/3/2013
Thomas Kiesling
Fosa
13.32 3/2/2013
13.39 3/2/2013
Peter Hubbertz
Radical Pro
13.19 3/1/2013
12.87 3/2/2013
13.33 3/3/2013
Armin Hortitz
FS3
13.24 3/2/2013
13.50 3/2/2013
13.04 3/2/2013
Kiesling is offline Find More Posts by Kiesling
Old Mar 12, 2013, 12:54 PM
Joakim Stahl is offline
Find More Posts by Joakim Stahl
Joined Mar 2013
Originally Posted by nic wright View Post
Reto,
Some earlier WC best speeds for you. They were picked off un-sorted lists from a mixture of official results and daily news bulletins, so if I missed a faster time, apologies in advance.
1995 14.83 Denis Duchesne <Ellipse ( 1 or 2 ? )> Romania
1993 15.62 Nic Wright <Electra EV-1> Israel
1991 16.3 Joakim Stahl <?> Holland
1989 17.5 Rienhard Liese <Epsilon> France
It would be interesting to know the best times from even earlier WC's ?? The 'old' winch rules applied up to and including 1987.
Cheers,
Nic
Nic,
nice research!
I was past my refinement after work today and found Achmer News from WC 1987. I had in mind that myself and a guy from the US-team had the best speed time at this WC. Kind of team work, I won the speed task round 1 and Stephen the last round 6
1987 18.5 Joakim Stahl <Grover> Germany
1987 18.5 Stephen Work <Synergy II> Germany
Best Regards,
Joakim
Joakim Stahl is offline Find More Posts by Joakim Stahl
Old Mar 13, 2013, 09:52 AM
Joined Mar 2013
Originally Posted by oakman7004 View Post
I assume Joakims Stahls glider at that time was his own model GROVER . He actually has one Grover left in "mint" condition...
Later (1994-95) came the T-tail Spacewolf succeeded by the V tail Spacewolf (one piece wing with for that time a small fuse) which flew great and made results, 96-98, before the Racemachine era!
/Jonas Ekman
Close my dear friend, but the glider for this era was actually Spojalo (1991 WC Holland). Missed to mention the model name in the answer to Nic Wright previously.
Spojalo was a dream to fly and I had a number of bomber speed runs over time. One blast was in Amay Belgium, it was judged to be wrong at the last turn on the B-base, got a new working time, yeeeak...
/Joakim
Old May 26, 2013, 08:30 AM
jeroens is offline
Find More Posts by jeroens
Joined Nov 2007
12.50 sec Jeroen Smits during the Dutch Nationals with fs3 (25th of Mai 2013)
jeroens is offline Find More Posts by jeroens
Old May 27, 2013, 08:37 AM
laurentp is offline
Find More Posts by laurentp
Joined May 2011
Congrats!!!! Didn't you fly with the Fosa?
laurentp is offline Find More Posts by laurentp
Old May 27, 2013, 01:20 PM
jeroens is offline
Joined Nov 2007
I crashed that Fosa also during that contest ;-(
ChuckTSeeker filmed the crash :
F3B Australian Open 2012 (15 min 22 sec)
at 10.06
Jeroen
Discussion Complete Speed Report For All Planes, Speeds And Pilots (Friday, June 18, 2010) daboz Dynamic Soaring 16 Jun 24, 2010 01:46 PM
Discussion Unworthy speeds marfish Dynamic Soaring 17 May 27, 2010 08:34 PM
Discussion Crazy new speeds daboz Dynamic Soaring 1 May 13, 2010 06:46 AM
Discussion Fastest DS Speeds update, need info. d.noland Dynamic Soaring 6 Jun 20, 2007 02:37 PM
