Espritmodel.com Heli Air
Old Oct 12, 2010, 02:20 PM
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
That's a cool video... I didn't get to see the run live... I was busy being interviewed on Israeli TV for just having broken the speed record myself... 15.8 ish I think... don't really remember. The funny thing was, when they aired my interview, Nic's run was blasting in the background... 15's were fast in '93...
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Oct 14, 2010, 08:35 AM
JonasEkman
oakman7004's Avatar
Sweden
Joined Dec 2004
Originally Posted by nic wright View Post
1991 16.3 Joakim Stahl <?> Holland
I assume Joakims Stahls glider at that time was his own model GROVER . He actually has one Grover left in "mint" condition...
Later (1994-95) came the T-tail Spacewolf succeeded by the V tail Spacewolf (one piece wing with for that time a small fuse) which flew great and made results, 96-98, before the Racemachine era!
/Jonas Ekman
oakman7004 is offline Find More Posts by oakman7004
Old Oct 14, 2010, 01:53 PM
hhb
Austria
Joined May 2009
impressive
http://www.youtube.com/v/Cgj2FO-5BGc?fs=1&amp;hl=en_GB
Steve, The quality isn't great but it was 17 years ago ( what a good memory you have ! ). Chatter, blasphemy and expletives are courtesy of Steve Macken. Nice to hear from you and thanks for the kind comments, Nic
I was there, it was great. I would like to see also a video of one of the special speed lauches with turns during the launch.
Harald
hhb is offline Find More Posts by hhb
Old Oct 19, 2010, 08:20 AM
North Wales, UK
Joined Oct 2010
Harald
1993 r5 sp fullscreen (1 min 58 sec)
Harald,
The only video I have showing the ‘circle-tow’ is also from the 1993 WC ( round 5 ). As you no doubt recall the air was very mixed throughout the week but the wind speed was good for circle towing. I remember attempting it in most speed rounds. The air in this flight was very poor, barely good enough to do a 180 at the end of the flight and land back into wind. Without the circle tow this would have been a ‘21’.
The model is released by the launcher with the minimum tension to get the model away safely. Strictly ‘flat’ launch only. The winch is given a single pulse by the pilot at the point of release in case launch tension is not enough in which case the pulse is prolonged. A downwind weave to left or right, depending on crosswind, if any, would then be started and the winch is stopped at the same time. The wind is then used to kite the model to about 100m. altitude. Weaving continues until there are signs of improving conditions. Monofilament can also be used to fish for thermals ! When lift is sensed or when time ( or nerve ) is running out the model would be rotated towards the ground to convert the potential energy ( height gained by kiting action ) into model speed and line tension. Usually the rotation would be completed to make a circle with the model pointing into wind when the model reaches the vertical. The winch would be started near to the bottom of the circle which should be a safe distance from the ground and well above the slower wind at ground level. The tow is then completed in the normal manner, albeit with a much greater starting tension.
In good conditions this would increase launch height by 20-30 metres which is due to the combination of less line being pulled onto the winch drum and a more efficient winching phase due to increased model speed during the start of the launch ( some of which will build and carry through to the end ). Selecting the moment when the air is good based on feedback from the plane in flight, rather than visual survey from the ground, also provides a distinct advantage.
As the additional height gained is approximately 10% of the total launch altitude, which is comparable to the normal differences between successive launches in windy conditions, the overall advantage is not obvious to on-lookers. There are no other models in the air ( Speed task ) to compare with either. Consequently many folk did not see the advantage. Hence the comments by the video operator “ Nic doing his usual trick…”, “ What a plonker *….”, “for the birds…..”.
Control is by rudder with ailerons only used to keep the wings perpendicular to the towline. Elevator should be left alone if the model is trimmed correctly for the launch.
Cheers, Nic
Apologies for going off topic. Maybe best not to clutter up this thread with replies ? Thanks. * Plonker - British expression meaning ‘stupid person’.
nic wright is offline Find More Posts by nic wright
Old Oct 19, 2010, 08:53 AM
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
Hello Nic
As this is "my" thread, I dare to clutter it up with a reply:
Awesome, thanks for the video and your thoughts on circle tow! It was a nice read.
When you feel the air is not good when you have your go in speed, you can either wait for a minute or so ( and risk misjudging the conditions) or make a test launch to feel the air (with the hassles of a relaunch, expiring working time). But having the plane on tow for some time to fish for a thermal/good air is an intriguing idea!
Further weaving left to right several times on launch is also an efficient way to keep others away from launching (duration, distance).
Reto
RetoF3X is offline Find More Posts by RetoF3X
Last edited by RetoF3X; Oct 19, 2010 at 10:58 AM. Reason: more appreciation for Nic Wright's post
Old Oct 19, 2010, 09:30 AM
North Wales, UK
Joined Oct 2010
Reto
True, but that was never the intention. I only ever used this technique for speed and occasionally in distance when I was lucky enough to be at the end of the winch line with a cross-wind which would allow the model to be weaved and circled outside of the winch lines. This was more difficult but when the launch was eventually commenced it would be like starting from say 200 m. away directly into wind with nearly all the line still on the drum with the added benefit of being able to watch the launch 'side-on' and therefore better judge the release point.
Also there were murmurs about banning circle towing on safety grounds. I didn't want to do anything that might antagonise the murmurers !
Cheers,
Nic
Old Oct 28, 2010, 09:18 AM
Joined Mar 2007
Hi Nic,
Nice to have some input from one of the most gifted and natural pilots I have had the pleasure to witness and fly with.
Have witnessed the circle tow, got to admit, really does build that energy.
Paul Garnett is offline Find More Posts by Paul Garnett
Old Oct 28, 2010, 10:44 AM
Stamford, CT
Joined Feb 2002
Circle towing sounds very similar to what I posted earlier about the 1981 trials and circle towing with bungees. Launch heights were awesome. They used captured tow hooks in those days, which allowed them to fly downwind on launch. I don't know if they are legal today? Conceivably a modern day plane with a captured hook could fly down wind on tow and pull line off the winch before heading upwind for the launch. Don't know much about F3B winches. If they have one-way rachets this wouldn't be possible. Might be an interesting strategy for TD, however.
George
SaltyOne is offline Find More Posts by SaltyOne
Old Oct 28, 2010, 11:04 AM
RetoF3X's Avatar
Joined Mar 2009
Hi George
We do downwind launches today in F3B, but not with captured hooks (but we slightly bend the hook upwards).
You built up line tension, turn the plane on knife edge after release and go downwind. In this part you only tack the winch to not use up to much line. Some stop completely pulling line for a short time. When you are beyond the pulley, the helper starts the winch again and you very gently start the climb upwind using rudder.
You can also circle tow with a non captured hook, you just need to make sure that you don't run out of line tension.
Todays winches have a ratchet/reverse stop (you can stop pulling in line and the drum is blocked). But what you have spooled on the drum you don't get back. The turnaround pulleys need another rotational degree of freedom to do crosswind/downwind launches.
Reto
Latest blog entry: Gator F3B and IHLGF
Old Oct 28, 2010, 03:44 PM
Joined Mar 2008
I also remember seeing that run. I was a member of the South African F3B team who shared a tent with Nic and the UK team. We had just been allowed back after a ten year gap due to the international sports boycott. Our best time was about 18 seconds at that stage :-)
I'll have a look for similar footage I have in some videos of the 1993 WC - some taken by Craig Goodrum who came to watch ... and hasn't missed a WC since.
As regards the circle towing techique, If I remember correctly Daryl and Nic put on a syncronised circle tow demonstratio much to the crowds amusement.
Good memories, thanks Nic, Reto
John Monk is offline Find More Posts by John Monk
Old Nov 03, 2010, 12:23 AM
R/C Soaring "Lifer."
stevecondon's Avatar
Oceanside, CA
Joined Mar 2006
[QUOTE=
[/QUOTE]
Hi John,
You may remember me as a crew member with the US Team back in '93. The Circle tow was a big deal back then (thanks to Nic). The demo you mention was actually put on by Daryl and Joe Wurts. Daryl had just repaired the F3B Eagle that he landed safely with only half a wing (remember THAT?!) after a mid-air with--I think--one of the Dutch pillots. I recall he was really upset at that time because only an hour or so prior, he had just (essentially) lost the WC in which he was dominating the competition because the crystal dislodged from the receiver during the "bucket" part of his launch causing his only remaining airplane to do outside loops until it died quite a distance downwind. This was back in the days when you had to throw out a whole round--not your three lowest tasks. The circle tow "demo" was largely Daryl taking out his aggression on a freshly repaired model and not really caring if it 'blew up' since in his mind, the contest was over for him anyway.
This was just my perspective as his friend and teammate but it made for one heck of a circle towing demo! He and Joe use to do the 'tandem tow' at the SULA field where we practiced quite a bit and it was really cool to watch two models on tow like well-controlled stunt kites that made a neat noise when they ran downhill. Ah, the memories...
stevecondon is offline Find More Posts by stevecondon
Old Nov 03, 2010, 11:32 AM
Joined Mar 2007
Well, after my model went in in Speed, I was maybe a bit distraught. I've NEVER flown better than I flew in 93. The model that went in in Speed was my backup, and was toast. The primary model was the one I midaired the day before, and was pretty trashed too, but the team had stayed up all night fixing it. I wasn't going to bother... why would i need it? Duh!!! So I did do a little stress relief towing... ummmm... I mean model testing ... you could build sooooooo much tension circle towing. Joe and I used to tandem tow quite a bit, and it was so cool.. it was so elegant, we were quite in tune... almost like a side by side ballet.
After the comp, they did ask Nic and I to do a tandem tow, and we did, but my model was set up a bit aggressive for the lighter winds on that day, and it didn't come off as well as it could have. But it was fun.
On a side note, I believe my losing in Israel was a blessing in disguise. You have to learn how to lose, before you learn what it takes to win. I've never flown again as well as I flew in Israel... but I have flown smarter since...
Old Nov 09, 2010, 05:01 PM
RetoF3X's Avatar
Joined Mar 2009
Fast, faster, Cal Valley
Hi Guys
I had to update the list, 7 speed runs below 14s in Cal Valley at the US TS!
Daryl was so close to the world record...
Reto
Old Nov 13, 2010, 01:07 PM
Joined Mar 2007
Reto - I was looking at the list. I'm 99.99999% sure Denis was flying an Ellipse 2V in Romania in 95.
Thanks for putting this list together. It's fun to see. Nice flying in CV last weekend. Nice to meet you...
D
Old Nov 14, 2010, 04:11 PM
RetoF3X's Avatar
Joined Mar 2009
Hi Daryl
It was nice to meet you too! It was great to hear some of your stories and to see what you could do in speed with one of todays plane.
Reto
Discussion Complete Speed Report For All Planes, Speeds And Pilots (Friday, June 18, 2010) daboz Dynamic Soaring 16 Jun 24, 2010 01:46 PM
Discussion Unworthy speeds marfish Dynamic Soaring 17 May 27, 2010 08:34 PM
Discussion Crazy new speeds daboz Dynamic Soaring 1 May 13, 2010 06:46 AM
Discussion Fastest DS Speeds update, need info. d.noland Dynamic Soaring 6 Jun 20, 2007 02:37 PM
