Old Sep 05, 2010, 02:36 AM
Rogier is offline
Find More Posts by Rogier
The Neterlands, Europe
Joined Apr 2010
Nice landing, but why is the nose wheel twisted around after the landing???
Rogier is offline Find More Posts by Rogier
Old Sep 05, 2010, 02:59 AM
DougKierc is offline
Find More Posts by DougKierc
Joined Jan 2004
I was wondering the same thing
DougKierc is offline Find More Posts by DougKierc
Old Sep 05, 2010, 03:05 AM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Howdy,
This is one fast little scale bird! Yuri has a Scorpion in his with a 10x10 bolted to it. It really flies on rails.
Enjoy the AZ evening photos,
-Buzzed
Buzzed is offline Find More Posts by Buzzed
Old Sep 05, 2010, 04:01 AM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
If you have a less than perfect landing where the nose gear takes an excessive impact or even hit a rock or piece of debris on takeoff, the entire nose gear assembly can spin 180 internally by flexing the steering push rod to the point where it flops the steering arm to the other side of the assembly.
Bajora is offline Find More Posts by Bajora
Old Sep 05, 2010, 01:00 PM
iRun4Love is offline
Find More Posts by iRun4Love
Love seeks nothing in return.
iRun4Love's Avatar
Maple Ridge, BC, Canada
Joined Dec 2009
Originally Posted by Superem View Post
Mine is still stuck in a tree. Wish it would come down
Have you tried a fishing rod with a sinker weight on it? Some friends of mine basically cast a heavy weight "over" the plane, and then were able to pull the plane down because the fishing line was then "looped" over the plane (they grabbed both ends of the line - the one with the weight and the one to the rod).
Another friend got his golfing buddies out with 100 golf balls, and whacked at his foamy in a tree until it came down... in pieces.
Would recommend fishing line method, personally.
iRun4Love is offline Find More Posts by iRun4Love
Old Sep 05, 2010, 05:32 PM
jhardman is offline
Find More Posts by jhardman
magna,utah
Joined Oct 2009
i didnt have lock tight on the screw that holds it in place not the servo arm but the arm that holds the wheel rod
jhardman is offline Find More Posts by jhardman
Old Sep 09, 2010, 09:19 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Well, I started my SR22 last night at 700pm and finished it 6 hours later. Never done that before, but it was a fun build and I was on a roll.
I mounted a Scorpion motor on it with a Hacker esc. Also, I am using a 40C Zippy 4cell on this little bird and it just screams! The prop is an APC 11x8. It's pretty much a pylon racer now.
First flight was a blast. Straight up with some rolls and click of down elevator. I need to move the battery back a half inch on the next flight. It was a little nose heavy, but it worked out great due to the gusty winds here in Phoenix this morning.
Well, enjoy the photo and fly safe!
-Buzzed
http://www.rcdude.com/servlet/the-12...ushless/Detail
Old Sep 12, 2010, 10:20 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
I tried a different motor in mine today and love it! The Park 480 motor was OK but it was a little slower than I like so I put in a Tower Pro 3015-7 motor with a 10x9 prop and what a difference. Great climb rate, loops from half throttle with ease, really good speed now and it's dirt cheap!
http://www.hobbyking.com/hobbyking/s...idProduct=5113
raz is offline Find More Posts by raz
Old Sep 14, 2010, 12:07 AM
pestrada is offline
Find More Posts by pestrada
FLA
Joined Jan 2000
How is the fit with that motor? Any mods needed or does the motor fit right in?
I was thinking about going with a TR 35-36A 1450kv http://www.hobbyking.com/hobbyking/s...idProduct=4916 . It's a little lighter. I would run a 9x6 probably..
pestrada is offline Find More Posts by pestrada
Old Sep 14, 2010, 11:39 AM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
I had to drill out the center hole a little because the locking collar is bigger due to the 5 mm shaft size but other than that it went right in. That 35-36A Turnigy motor looks like a good choice too, especially if you want a little smaller, more scale prop.
Old Sep 16, 2010, 04:04 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
The more I fly this plane the more I love it, especially now with the more powerful motor and an APC 10x10 prop. I'm guessing the speed at WOT is around 65 to 70 mph and it now easily cruses at 1/2 throttle. Great Planes sure got this on right. I'm just surprised it isn't more talked about?
Old Sep 16, 2010, 04:17 PM
Bajora is offline
KA6KHM
Bajora's Avatar
Joined Sep 2004
The Ezonemag.com review was completed and turned in for editing a week or two ago. Hopefully it will go live very soon,
Old Sep 16, 2010, 05:11 PM
Aros is offline
Find More Posts by Aros
Shameful Warbirdaholic.
Aros's Avatar
Maple Valley, WA
Joined Apr 2006
This plane is definitely on my radar.
Aros is offline Find More Posts by Aros
Old Sep 17, 2010, 02:20 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
You won't be disappointed.
Old Sep 18, 2010, 10:07 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Well on the 4th takeoff my prop suddenly hit our paved runway. I thought maybe the grub screw came loose, but I had used thread-lock, and that wasn't the case. The nose gear did what was described above.
I had a metal-gear servo lying around so I decided to shorten the long linkage to the stock rudder servo. I have this new servo connected to its own channel and can trim it independently. I hope this solves, or at least, minimizes THAT problem.
nioa is offline Find More Posts by nioa
For Sale KMP Cirrus SR 22 ARF Kit (NEW IN BOX) JuanRodriguez Aircraft - Fuel - Airplanes (FS/W) 1 Jan 17, 2010 08:37 PM
Discussion Looking for plan or any draw of layout of CIRRUS SR22 airplanee RafalM The Builders Workshop 6 May 03, 2008 09:26 AM
Discussion Converting a Cirrus SR22 by KMP Keith43221 Sport Planes 4 Nov 05, 2006 02:30 PM
Discussion Cirrus SR22-G2 Keith43221 Giant Scale Airplanes 0 Nov 04, 2006 01:16 PM
