Old Dec 27, 2012, 01:11 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
What I did was cut a Popsicle stick and add gussets between the motor mount and the nose gear bulkhead. It's taken a ton of hard hits with no damage.
Alex Schauer is offline Find More Posts by Alex Schauer
Old Dec 27, 2012, 05:17 PM
OKJeepin is offline
Find More Posts by OKJeepin
Controlled Chaos
OKJeepin's Avatar
United States, OK, Poteau
Joined Jul 2012
I hooked up my watt meter to get some info and almost died! Well not really, but the motor mount broke off, and it almost scared me to death!
Epoxy time!
OKJeepin is offline Find More Posts by OKJeepin
Old Dec 27, 2012, 05:53 PM
Joined Feb 2011
Yeah you will get that
Old Dec 27, 2012, 06:06 PM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
LOL, well she is epoxied HEAVILY now! I also layered another piece of thin ply to the inside of the mount w/ epoxy to offset the spinner/cowl gap and to help reinforce it. I am going to let it dry 24hrs then drill out the motor mount and vent/cooling holes and mount the motor for another try!
Old Dec 27, 2012, 07:23 PM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
Joined Jul 2012
Houston,,,, we have a problem!!!
hoghead5150 is offline Find More Posts by hoghead5150
Old Dec 27, 2012, 09:12 PM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
And before I even got off the ground!
I got her fixed now, the motor mount anyway...front landing gear to be addressed this weekend time permitting.
I decided to leave it all white (probably regret that the first time I lose it in the sky). I went ahead and put the stickers on, and those long ones were fun! ,but thanks to my son we got them all on and it looks great.
I never posted my watt meter readings so I will add them here:
37A and 422 watts with a fully charged 3s 3300mah 40c battery, an APC 10 x 7 Thin Electric Propeller, and a ready to fly weight at 2lbs 15.75oz.
Old Dec 30, 2012, 12:25 AM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
Looks like I'm going to take it up on it's maiden voyage tomorrow.
The weather is supposed to be clear with a light wind of 3-7mph and i am getting excited!
Old Dec 30, 2012, 09:52 AM
Joined Feb 2011
37A and 422 watts with a fully charged 4s 3300mah 40c battery, an APC 10 x 7 Thin Electric Propeller, and a ready to fly weight at 2lbs 15.75oz.
4s on a 10x7?!?
It also seems as 4s3300 is too big.... Most guys run 3s 2650-3300
Old Dec 30, 2012, 09:57 AM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
4s on a 10x7?!?
Dangit, that was a typo! 3s!! lol. The 3s 3300mah is a perfect fit.
Old Dec 30, 2012, 12:31 PM
Joined Feb 2011
Oooh okay that makes more sense!
Old Dec 30, 2012, 07:09 PM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
Maiden flight went good, landings were so so...going to have to work on that a little.
Orientation in the gray overcast sky we had today was pretty tough, going to have to work on that also.
It's one FAST plane, flew very easy once I got her trimmed, but man did she want to come in hot for the landings. A little bit of tip stall on the slow turns I made, but very easy to control. I am very happy so far.
I ordered some red monokote and a new sticker set. I am thinking of adding some red to the underside tips of the wings, maybe 6" or so, with a hole cut in the middle and the "Turbo" stickers in the that hole. The flat edge of the turbo sticker will butt up to the wing/aileron joint. Just a thought...
Edit :
Well...not my best work, but it will do I think!
Old Jan 25, 2013, 07:02 AM
Spudz27 is offline
Find More Posts by Spudz27
Australia, WA, Perth
Joined Mar 2012
Hey guys, just bought one of these, what is an alternative to the rimfire .10? I notice the rimfire has front mounting holes, I guess so the spinner sits flush. So is there an equivalent motor around that has the same front mounting holes? Or has everyone created a new motor mount?
Spudz27 is offline Find More Posts by Spudz27
Old Jan 25, 2013, 08:19 AM
tbeller is offline
Find More Posts by tbeller
DronePilot6
United States, OH, Elyria
Joined Oct 2012
I use the rimfire .10 on a three blade 10X5 MASTER AIRSCREW. I can cruise around at 1/2 throttle for 11 minutes and still have at least a 1 minute reserve with a 3 cell 3300 mah battery. I added a 1/8 inch plywood spacer between motor and mount to close gap of the spinner.
tbeller is offline Find More Posts by tbeller
Old Jan 25, 2013, 08:29 AM
Joined Feb 2011
Turnigy 3530
Joined Feb 2011
Edit :
Wow not too shabby!! I like it
For Sale KMP Cirrus SR 22 ARF Kit (NEW IN BOX) JuanRodriguez Aircraft - Fuel - Airplanes (FS/W) 1 Jan 17, 2010 08:37 PM
Discussion Looking for plan or any draw of layout of CIRRUS SR22 airplanee RafalM The Builders Workshop 6 May 03, 2008 09:26 AM
Discussion Converting a Cirrus SR22 by KMP Keith43221 Sport Planes 4 Nov 05, 2006 02:30 PM
Discussion Cirrus SR22-G2 Keith43221 Giant Scale Airplanes 0 Nov 04, 2006 01:16 PM
