Latest blog entry: 3DHS 48" Extra Windy Day Flying
Time to ring you up again!
Guys: tip:
Put the steering arm on the top of the mounting bracket instead of in the middle. Put a spring on the bottom of the mounting bracket on the wire. Shock absorber. |
Don't worry about the bending, be thankful it is. Just keep on bending it back till it breaks and get a new one for $3. Look what happened to mine.
But, I do have a tip for you. If you land and you find that the nose pops back up again and the plane skips, here is a mod to fix that. Also shown is a metal gear steering servo setup with a 6" threaded rod and two Dubro easy clips or somthing like that! I just put the servo in the optional cut out for the elevator servo. I used the farther back hole for the actual control surface servo. Just popped a TPro MG90 in the foorward hole! This works amazing. Now for the nose gear shock absorber -(someone here did this or tried this I think? Not sure but it works great!) Put the steering arm on top. Put a spring on the bottom between the fairing and the bottom of the nose gear mount. See pics! This works amazing! Just take a crappy old pen and steal the spring and slide it on! Try all of the pens you have, so springs may work better than others, some may not fit-etc. Get a cap head screw for the control arm that way you can tighten it more, and it won't slip. I dont even need a flat spot on the shaft. |
| Thread Tools | |
| For Sale KMP Cirrus SR 22 ARF Kit (NEW IN BOX) | JuanRodriguez | Aircraft - Fuel - Airplanes (FS/W) | 1 | Jan 17, 2010 07:37 PM |
| Discussion Looking for plan or any draw of layout of CIRRUS SR22 airplanee | RafalM | The Builders Workshop | 6 | May 03, 2008 08:26 AM |
| Discussion Converting a Cirrus SR22 by KMP | Keith43221 | Sport Planes | 4 | Nov 05, 2006 01:30 PM |
| Discussion Cirrus SR22-G2 | Keith43221 | Giant Scale Airplanes | 0 | Nov 04, 2006 12:16 PM |
