Old Apr 26, 2011, 09:43 PM
celm is offline
Find More Posts by celm
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
i recently got this plane and i like how it flys,just GP didnt do a great job in glueing it together.i had a little oops on take off on sunday,the motor mount detached from the FG fuse.and the servo tray came undone, i had to epoxy the motor mount back on as well as reglue the servo tray.im starting to see cracks form where the 2 sides of teh fuse meet together
celm is offline Find More Posts by celm
Old Apr 27, 2011, 09:21 AM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Good to hear it went well for you gewiens. You may want to try a APC 10x10 prop if you want more speed. The 121x8 will give more thrust and drain the battery faster but won't increase speed a lot.
raz is offline Find More Posts by raz
Old Apr 27, 2011, 10:10 AM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Next trip to the LHS i'll have to pick one up. I had to give a lot of trim to maintain level flight and this mornig realized my ailerons had quite the deflection on them to maintain level. Everything is bang on straight and lining up correct so i have no idea whats up with that. My balance is bang on also. Wonder if there is a twist in the wing that i can't see or something.
gewiens is offline Find More Posts by gewiens
Old Apr 27, 2011, 11:33 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Took this pic and sent it to great planes. I put tape on the wings so you can tell the difference. Both wings have tape on same location and length. You can also see how much deflection there is. Not the best pic but you get the point. You can see more tape showing on right wing.
Old May 05, 2011, 11:18 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Just Bought a nanotech 3000mah 4s batt to test out on this thing. Weighs as much as the blue lipo 3300 3s i have been using so hope to have some good speed soon.
Old May 06, 2011, 03:03 AM
Rogier is offline
Find More Posts by Rogier
The Neterlands, Europe
Joined Apr 2010
Is this plane anywhere available? Can't find it in an online shop...
Rogier is offline Find More Posts by Rogier
Old May 06, 2011, 08:40 AM
boydboy is offline
Find More Posts by boydboy
USA, CA, Waterford
Joined Jan 2009
Tower Hobbies has it and ships internationaly. Someone there may stock them as well
http://www3.towerhobbies.com/cgi-bin...?&I=LXZGX7&P=7
boydboy is offline Find More Posts by boydboy
Old May 07, 2011, 09:26 AM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Maybe it's the camera angle but it looks like it has left rudder or the vertical stab is pointing left. If it is that would explain all the 'right' aileron trim. Try putting a straight edge along side of the stab to see if it's twisted and aiming off center.
Old May 07, 2011, 10:56 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
The picture was at just a slight angle and not straight on. Gonna measure a bunch of stuff. Great planes support never got back to me.
Old May 08, 2011, 10:23 AM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
It's fairly common to have one wing twisted a little or at least it is for me. I have had some with tons of wash-in in one wing and wash-out in the other. Have you tried heating and twisting the wings to match? I would try to twist the right wing to add some WO to match the left.
Old May 08, 2011, 11:13 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
I might have to give the wings a twist and see how that goes.
Old May 08, 2011, 05:27 PM
madatme is offline
Find More Posts by madatme
Bellbrook, Oh
Joined Jul 2008
wing warp
what worked for me last year is I had a twisted wing, I removed it and soaked it in water(makes it soft) for a minute, poured out the water, then layed it on the bench, see which way the twist needs to go too remove the twist, I covered the spots with thin towels so it would not mark the wing, then used a few barbell weights too weight it down, then used a piece of wood too prop up the other side. I put a little more twist the other way because the wood will spring back a little, let it dry for a week. In your case it looks to be in the middle, so wood in the center underneath, weights at the outer edge on top. Done
madatme is offline Find More Posts by madatme
Old May 08, 2011, 06:00 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
When i get a chance i might have to give that a try. Going to take a bunch of measurements to see which wing is the most twisted.
Old May 09, 2011, 09:28 AM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
From the picture it's the right wing that should be twisted to match as it looks like it has wash-in and you sure don't want to add wash-in to the other wing too.
Old Jun 01, 2011, 06:10 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Have you figured out what's wrong?
For Sale KMP Cirrus SR 22 ARF Kit (NEW IN BOX) JuanRodriguez Aircraft - Fuel - Airplanes (FS/W) 1 Jan 17, 2010 07:37 PM
Discussion Looking for plan or any draw of layout of CIRRUS SR22 airplanee RafalM The Builders Workshop 6 May 03, 2008 08:26 AM
Discussion Converting a Cirrus SR22 by KMP Keith43221 Sport Planes 4 Nov 05, 2006 01:30 PM
Discussion Cirrus SR22-G2 Keith43221 Giant Scale Airplanes 0 Nov 04, 2006 12:16 PM
