Old Jun 11, 2010, 02:54 PM
Pilot28's Avatar
Joined Apr 2010
Apprentice 15e as a Towplane?
I have an Apprentice, and I was wondering if I could make it a towplane.
Pilot28 is offline Find More Posts by Pilot28
Old Jun 11, 2010, 03:47 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
How much trust do you have and are you still using the stock power setup?
Not 100% sure but I think you may need a plane with tons of power to pull another. Not sure the Apprentice falls in that category.
freechip is offline Find More Posts by freechip
Old Jun 11, 2010, 07:00 PM
fmw
fmw's Avatar
Joined Jul 2009
The apprentice has enough power to pull a couple of pounds of glider. It is significantly more powerful than most trainers.
fmw is offline Find More Posts by fmw
Old Jun 11, 2010, 07:17 PM
WARNING: May contain spam
Xpress..'s Avatar
Joined Oct 2007
Yes it'll do fine pulling a glider like the Easy Gliders and such
Xpress.. is offline Find More Posts by Xpress..
Old Jun 12, 2010, 05:12 AM
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Fort Carson
Joined Oct 2008
yup, you should be good up to about a 2m glider. After that you may be pushing the limits of the stock setup of the apprentice
verticalspark is offline Find More Posts by verticalspark
Latest blog entry: Getting into FPV while KISS
Old Jun 12, 2010, 04:58 PM
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Funny you should post about this idea....
Been doing just that, just last week...here are some pics of Richard Ng's stock power system Apprentice aerotowing his vintage Raven flying wing sailplane just last week in Little Rock at the SMALL Steps 2010 event. (GREAT event!) I am the big guy at the far right in the first pic, flying his Apprentice for the tow.
I also dug out a very old piggyback rack for launching small gliders from the back of a glow R/C model, rebuilt it and did some piggybacking as well. Piggybacking is much easier than aerotowing, with small models. A servo in the rack releases rubber bands that hold the glider to the top of the rack. As Richard had the stock AR500 RX and has already added flaps to the Apprentice, we used a y harness to hook in the piggyback release servo and simply activated the flaps to release the payload. Note the deployed flaps in the pictures of the piggyback gliders being released.
For towing, we opted for no release on the towplane. However, if you do not have a towplane release, you really ought to use a weak link of 4-6lb monofilament for the towline, which is what we did. That way, if the glider release fails, you can do a break-away and still escape the towplane. Our towline was made from some 12lb test Spiderwire, with a metalized mylar streamer on the glider end, for visual confirmation of glider release.
We left the piggyback rack on top during the tow...pics also included of the Apprentice piggybacking my Alula and a old Klingberg Rocket Wing, with an Estes D12P motor that ignites in mid air, using a brushed ESC as the ignition source.
The stock power system is only good for a couple of pounds of glider on tow. Weight and drag on tow it more of an issue than size actually is.....but it is not only that. No matter the power, when the weight of the glider gets to be a good portion of the mass of the towplane, the glider starts steering the towplane a little too much.
It hardly knows the Alula and rack are on top, with the stock power system. The stock landing gear was not quite up to the heavier Rocket wing, and it needed a hand launch for that one...
We are going to pump up the Apprentice with a better motor and a 4S pack here soon making at least 50-75% more watts, for somewhat heavier gliders and a quicker tow or piggyback to altitude...
Richard also flies this Apprentice as a float plane...it is one awesome multi purpose model!
We worked it pretty hard for three days at SMALL....
Thomas B is offline Find More Posts by Thomas B
Old Jun 12, 2010, 09:23 PM
laryctdummy's Avatar
colorado
Joined Apr 2009
I used one to pull a MP Easy Glider worked GREAT!!! PM me if you want good photos for an easy build tow release. I used a HS-55 and a home built hook that added next to no weight. -Joe-
laryctdummy is offline Find More Posts by laryctdummy
Old Jul 29, 2010, 06:26 PM
Pilot28's Avatar
Joined Apr 2010
Yeah, I use mine as a towplane too.
Discussion E-Flite Apprentice 15e replacement aileron servo arm, pushrod and clevis jono80 Beginner Training Area (Aircraft-Electric) 14 Feb 25, 2012 07:15 PM
Discussion Apprentice 15e crobar Foamies (Kits) 8 Apr 23, 2010 03:16 AM
Found WTB: E Flite Apprentice 15e RTF no radio sarasota_krash Aircraft - Electric - Airplanes (FS/W) 0 Apr 01, 2010 11:25 AM
Discussion e flite apprentice 15e as a first plane Xombie2000 Beginner Training Area (Aircraft-Electric) 15 Mar 23, 2010 02:54 PM
Discussion SuperCub LP BNF vs. Apprentice 15e RTF...opinions wanted mdwood Beginner Training Area (Aircraft-Electric) 33 Mar 15, 2010 02:36 PM
