Old Nov 14, 2012, 08:34 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
I am wondering which of the fuselages is being discussed for this Sukhoi 26m. Is it the short battery slot when first released or the longer battery slot sold with the last few planes (to use up the remaining inventory)? The longer slot appears to be the Sukhoi XP fuselage without the paint. Here is a picture of the latter. My short-slot Sukhoi also has had the slot lenghtened and I do not have a before picture to show.
Either way finding that CG sweet spot does wonders for the neutral handling. And I highly recommend the motor and prop from the Sukhoi XP, as well as 25c Lipos.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Nov 14, 2012, 04:59 PM
litehawkdown is offline
Find More Posts by litehawkdown
Joined Mar 2011
Yep that's my bird right there. I tried again today with just a prop change to the Champ one. I did not notice much of a difference except hand launching was Harder and I had to take her off on the runway instead. I did not even bother finishing the battery. It was than bad. I decided to buy a 1s brushless system too. I have a 7a 1s esc on the way now. And I have a 11000kv COM5 here. I would need to gear the motor for the 1s to work. Any suggestions? I have 8t and 9t on hand. Only thing is what would run times be? If it is anything like my MCPX it will be limited.
litehawkdown is offline Find More Posts by litehawkdown
Old Nov 14, 2012, 05:29 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
A number of people on RCG have done 1s & 2s bl conversions. There is a ton of info out there already. See the links below.
Here's a compilation of various bl conversions that people on here have done: http://www.rcgroups.com/forums/showp...17&postcount=1
Here's some static test data on some 1s & 2s bl setups vs. the stock motor: http://www.rcgroups.com/forums/showp...5&postcount=18
Here's a thread just for 1s & 2s brushless conversions: http://www.rcgroups.com/forums/showthread.php?t=1081138
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 14, 2012, 06:22 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
If you want a power increase buy a sx motor from rc babbel.
airpower is offline Find More Posts by airpower
Old Nov 14, 2012, 07:11 PM
Joined Mar 2011
I just traded in that MSR motor for a 4site one. Then I saw the MQX motor. That things pinion was huge in comparison. Anyone try it in a UM plane yet?
Old Nov 14, 2012, 09:05 PM
Joined Jul 2009
I just mentioned that a couple of posts back. If I were still messing around with 1s brushed planes, that's the way I'd go.
The mQX uses two pairs of Mossie motors, but with a different pinion. And the Mossie motors are the same as the 4-Site/P-51 motor, except that one is designed for reverse rotation. There's nothing to be gained from using an mQX motor.
Those of us who have been flying these planes for years have already gone through all of the drop-in motor options. If you want a drop-in brushed motor with significantly more power than the 4-Site/P-51/XP motor - get a Bravo SX motor that already has the right pinion & connector from RCBabbel, and use a GWS 5043 prop. With top-notch batts, you'd get nearly 60 grams of thrust. If you stick with the 4-Site motor, be sure to switch to the 5043 prop. It performs far better than the Champ prop.
Joel
Old Nov 14, 2012, 09:55 PM
Joined Mar 2011
Joel
Straight to the goods that"s what I need. I figure this plank is a fossil in the world of RC and I know all the work has been done already. That"s why I ask for the help. Thanks again by the way.
I find RC groups tough to follow. There is a ton of posts of chatter and coffee talk. If you where not around when page 10 was just started then 300 pages of What did you do today John gets in the way of the meat. Just the way it is I guess. Too use to the HF format. Too bad more of you plank guys don`t hang in those parts. The park fliers and foamies section is a ghost town there.
I brought up the MQX motor because of the bigger pinion. Was wondering if it is known what it would do on a UM plane.
Edit. I am a dumbass. I never thought I would be that guy. But it turns out I had the Champ prop on backwards. LOL I will give it a go tomorrow if I can. Just though I would share as it made no sence to me at how bad it was flying with the prop change. (hangs head in shame)
Old Nov 14, 2012, 11:48 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
You would be surprised how many people make the same mistake!
Did it myself once.
Old Nov 15, 2012, 01:34 AM
Joined Mar 2011
Going to try something new I think. Going to take a old MCPX frame and make a bearing ran 2mm CF shaft with a home made prop adapter. On the end. I will stick the C0m5 in there like it would be on the MCPX with a 8 or 9 t pinion. Should be interesting to see how it ends up.
Old Nov 15, 2012, 06:53 AM
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
If one is handy with replacing pinions and connectors then this SX motor is also sold from Hobby King under the Nine Eagles P-47/P-51/Spitfire replacement parts.
Old Nov 15, 2012, 06:12 PM
Joined Mar 2011
Having the Champ prop on the right way makes a world of differenceno real vertical though. I will play with that for a while then go beast prop then more powerful brushed motor then 1s brushless. I have a feeling this winter will be slow in the work department. This should keep me busy.
Old Nov 15, 2012, 07:10 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Dont use the beast prop, use a gws 5043 then balance it.
Old Nov 15, 2012, 10:06 PM
Joined Mar 2011
I had some of those on order since I got the plane. Just experimenting. Had to give some cash to the LHS so I buy what they have on hand. I have been giving way to much to the online stores as of late.
Old Nov 19, 2012, 12:55 PM
jdr00ejr is offline
Find More Posts by jdr00ejr
United States, IN, Indianapolis
Joined Oct 2012
Hey Everybody...I have a Champ that I learned to fly on. I was looking to trade/sell one of my Helicopters to get a UM T-28 when someone offered to trade me for a Sukhoi SU-26XP. Doing some quick online searching - I'm nervous. I have a DX6i. Does anyone have settings that can dumb this down enough to be a next step up from my Champ? If I can make it "dumb" for a while and then tweak my way back - I think it would offer me great growth potential - but I'm just not sure where to start to make it dumb. Please let me know your thoughts. Also - I've flown the champ in <10mph wind - is the Sukhoi going to be similar flying weather?
jdr00ejr is offline Find More Posts by jdr00ejr
Old Nov 19, 2012, 03:28 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I wouldn't say it's the next step up from the Champ. The T-28 would have been that. However, if you use the low dual rates and high expo, you should be fine. I set my low rates down to 60 and it straightened out my problems with keeping control. I would suggest flying in no more than 3mph winds when starting, but I've had it in 7+mph with no problems.
Saxguy1000 is offline Find More Posts by Saxguy1000
Discussion The Sukhoi Su-26xp Has Arrived earthling1984 Scratchbuilt Indoor and Micro Models 555 Jul 13, 2011 06:40 PM
New Product New Parkzone Sukhoi Su-26xp!!!! A-10_Flyer Scratchbuilt Indoor and Micro Models 6 Jul 26, 2010 12:03 PM
New Product Updated ParkZone ultra-micro Sukhoi SU-26XP jeffsch Scratchbuilt Indoor and Micro Models 26 Apr 13, 2010 12:01 AM
Discussion NEW....Sukhoi SU-26XP BNF by ParkZone Kilo60 Micro Ready-to-Fly 2 Mar 20, 2010 11:14 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
