Old Jun 25, 2010, 11:47 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Originally Posted by Razors edge 29 View Post
how does one make this baby hover?
Tons of practice.. easiest way to get started imo..
Hold the plane for a hand launch and point the plane straight up, throttle up till you feel the weight of the plane neutralized by the props thrust... add a hair more throttle, then let go.. you'll likely roll right out of it the first dozen tries.. till something just clicks and you can hold that hover.. When you start to "feel" the plane coming out of hover, just hammer the gas and climb out..
Once you can regularly hand launch into a prop hang, it just becomes a matter of knowing the throttle range to do it, and flying the plane into a nose up attitude and decreasing the throttle until the climb stops and the hover begins..
Also, a good idea once you are learning to "Fly into" the hover, is to do it higher up then a few feet.. that way you have more escape time if stuff goes bad lol..
Once you have the hang of entering hovers from flight, especially with the advanced control throws, you can almost snap the plane from level flight or other maneuvers into a nose up near instant hover.
~Kev
darksiede is offline Find More Posts by darksiede
Old Jun 26, 2010, 12:09 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Kev
Thanks for great info. You don't need to use any control surfaces to keep it there?
~Kev
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jun 26, 2010, 12:12 AM
DGrant is online now
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
Originally Posted by dribbe View Post
They are linear servos. No conventional arm, no 'circumference' in the output.
David
Got it... I wasn't even thinking linear.. I'm not too familiar with the brick system yet. Thanks for clarifying that..
RCBABBEL.. thanks also for the pics.. it all makes sense. I've not seen the inside of my Suki yet.. hopefully won't have to for a loong time... especially now that I've got these pics to go by..
DGrant is online now Find More Posts by DGrant
Old Jun 26, 2010, 12:15 AM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Kev
Oh yeh.. You will be moving everything to keep it there.. rudder, elevator mainly, for pitch, and ailerons just to make it rotate and look pretty lol..
~Kev
Old Jun 26, 2010, 03:44 AM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Originally Posted by lightspeeddud View Post
well let just say we're comparing the old sukhoi to the new sukhoi:
and I dont own one but I talked to the developer who built it so I know all the tech specs on it
Bit late in the thread, but specs don't mean jack on how it actually flys. I'm in the car business and if i get the spec on a new car coming out, there is no way in hell even the most experiance car enthusiast can tell how it would drive for sure.
Bowerz is offline Find More Posts by Bowerz
Old Jun 26, 2010, 11:54 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Horizon Keeps Me Happy Again
Well, I had to call HH today regarding my Sukhoi. Today for some reason, whether it be gear box or motor, my plane when climbing in particular at 90-100% throttle would make a god awful screeching noise (it did this a few times last night and I didn't think much of it), and was doing it quite frequently. So, I was bringing her down when all of a sudden the motor stopped and down came my plane, luckily I wasn't that far from the grass but it still bent the fuse a little and the landing gear bracket came flying off. Inspection of the fuse shows a little cuts from prop I guess but overall not too bad thank god. So I packed it up and came home. I am not sure if its motor or gearbox but something is locking up. So, I called HH and they're sending me a new motor and gear box so my plane will be down for a while unfortunately.
I would try to power up the plane and test the throttle indoors but I am afraid the binding issue may cause damage to the brick.
This sucks, , BUT its great that HH hasd once again provided great customer service.
Old Jun 26, 2010, 02:44 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Re,
It's just a bad motor.
Save yourself some time and just replace it when the new one arrives.
Leave the gearbox alone.
Only about a five~ten min job.
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Jun 26, 2010, 03:27 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Okay thanks
I have bad luck with these cordless motors lol
Originally Posted by RCBABBEL View Post
Re,
rc
Old Jun 26, 2010, 04:09 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Someone may have pointed this out, or it may just be me, but is this one minus the landing gear?
Old Jun 26, 2010, 04:10 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Sorry, just answered my own question by using google
Old Jun 26, 2010, 05:02 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Flying the XP with Hyperion 180 mAh flat-packs
All,
Just got back from flying the XP with Hyperion 180 mAh 'Babbelbatts'. I used masking tape to hold the battery in place for the test-flights.
With the 180 nmAh battery to the rear of the slot, the CG is @ 38mm, vs. 37mm with the Hyperion 160 UM cell. With the battery over the first cooling hole, the CG is @ 40mm.
With the CG @ 40mm, hovering & harriers were much easier. It was relatively easy to hold hover, and wing-rock during high-alpha maneuvers was greatly reduced. Unfortunately, the rudder/pitch coupling during knife-edge was much worse.
My V1 & V1 were relatively uncoupled during knife-edge when balanced at the pitch-neutral neutral point (trimmed for level flight, roll inverted, little to no elevator required to maintain level inverted flight). With my XP, if I set the CG using the right-side-up/inverted test, the rudder/pitch-coupling to the belly during knife-edge is very strong. This indicates an aft CG or improper wing incidence. If I set the CG to minimize the rudder/pitch coupling during knife-edge, the plane acts like it's nose-heavy in all other respects.
With my V1 & V2, it was relatively easy to set the CG for a balance between precision flight and 3D performance (no pun intended!). I have not been able to find that balance with the XP. This has me thinking that the wing incidence on my XP is a bit different than it is on my V1 & V2. No big deal - it's easy to adjust the CG to suit my flying mood. Just something worth noting.
At 5.6g vs. the Hyp 160 mAh UM cell @ 4.95g, the extra weight of the Hyp 180 mAh cell is enough to notice. Elevators are not quite as lazy, and vertical performance is just slightly off - as compared to the 160 mAh UM cell. I did not attempt to assess endurance or static RPM, as it was starting to rain. If we get a break from this crappy wx this afternoon, I plan to do some testing with the GWS 5043 prop.
Joel
turboparker is online now Find More Posts by turboparker
Old Jun 26, 2010, 06:58 PM
jmrust is offline
Find More Posts by jmrust
Once-ler
United States, FL, Gainesville
Joined Jul 2008
Just got the Hyperion from Japan today
It amazes me that you can get amazing quality merchandise in a week for $2.00...I wish Hobbycity were in Japan..but anyway. I got the CX G3 25c 240mAh. Any recommendations as to where to start for correct CG. I was going to trim some foam off both sides of the battery tray and go from there.
I crashed her 2x today due to shi__y velcro, so that's replaced.
jmrust is offline Find More Posts by jmrust
Old Jun 26, 2010, 07:12 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
jm,
Just use a little masking tape at first to find the best cg location for the 240.
There is another good option if you don't want to cut into the foam:
http://www.rcgroups.com/forums/showp...postcount=4471
The Hyp 240s rock!
Enjoy,
rc
Old Jun 26, 2010, 07:16 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
ps......
Killer lifetime supply of quality sticky-back velcro here:
http://www.hobbycity.com/hobbycity/s...idProduct=9374
rc
Old Jun 26, 2010, 07:27 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
i just built up the battery with a couple of bits of double sided foam, like the stuff used to stick a tooth brush holder to the wall got it from a $2 shop then stuck my "Hobby King" Velcro to the batt, no ruining the airframe for this mod
also i replaced the "babys bum fluff" stuff that PZ use and replaced it with Hobby King Velcro
did i mention Hobby King Velcro
http://www.hobbyking.com/hobbycity/s...G___%281mtr%29
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Discussion The Sukhoi Su-26xp Has Arrived earthling1984 Scratchbuilt Indoor and Micro Models 555 Jul 13, 2011 06:40 PM
New Product New Parkzone Sukhoi Su-26xp!!!! A-10_Flyer Scratchbuilt Indoor and Micro Models 6 Jul 26, 2010 12:03 PM
New Product Updated ParkZone ultra-micro Sukhoi SU-26XP jeffsch Scratchbuilt Indoor and Micro Models 26 Apr 13, 2010 12:01 AM
Discussion NEW....Sukhoi SU-26XP BNF by ParkZone Kilo60 Micro Ready-to-Fly 2 Mar 20, 2010 11:14 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
