Old Jun 25, 2011, 12:58 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by apothecarion View Post
dx6i, sorry meant to add that
Then it's totally doable.
Have him the Expos on 60% on aileron and 30% on elevator (you want very little travel around neutral, with much more travel at the limits), put the battery towards the front of the slot and just practice flying it around in big circles up high first (circling right and left), to get the feel for it, then ovalize the circles so they are eventually straight, turn, straight, turn at a constant altitude.
Once constant altitude can be maintained, bring the altitude down. once a comfort level is achieved, then the flying can begin. Pratice stunts on the simulator so you know what to expect, and always try them high, before bringing them down.
As confidence builds, move the battery back in the slot... but only in the calm. If there is wind, move the battery forward.
I hated the original Sukhoi, but I love the XP... I think one of these days I'll bust out my Original Sukoi, put a Mustang motor/prop on it, add a gram to the tail and see if I still hate it.
UNGN is offline Find More Posts by UNGN
Old Jun 25, 2011, 01:08 AM
apothecarion is offline
Find More Posts by apothecarion
Joined Jun 2011
I'm pretty sure he never even fooled with the expos... too excited to fly... this should help a lot. thanks a ton can't wait to get him back up
apothecarion is offline Find More Posts by apothecarion
Old Jun 25, 2011, 01:16 AM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
I agree with UNGN, expo is where it is at on very maneuverable planes. I might even up the elevator to 40 or 50% at the start. Make sure he is flying over grass and above all, if he feels he is losing control, cut the power to the motor before it hits the ground. That can save a lot of damage from being done simply by following those two steps.
DoomsDay is offline Find More Posts by DoomsDay
Old Jun 25, 2011, 05:20 AM
richos is offline
Find More Posts by richos
richos's Avatar
Joined Mar 2008
Intellect 1S 160mah 25C Lipo Twin Pack
Originally Posted by BryanEW710 View Post
Where would one find the Intellec batteries (are you sure it's not "Intellect?")
Sorry! BryanEW710 here are the generic hyperion 160mah lipos with the Intellect stickers on them.
You can get a twin pack of the same generic factory lipos as hyperion use but with the Intellect stickers on for 7.75p over here..http://www.kingslynnmodelshop.co.uk/...duct_info.html
Im not sure if you can get the generic Intellect factory lipos over in the us but you can in the uk.
Hope this helps BryanEW710
richos is offline Find More Posts by richos
Old Jun 25, 2011, 07:08 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I found them at Miracle Mart. Don't know if I'm willing to pay 4x what I'd pay for a 160 Nanotech, though.
BryanEW710 is offline Find More Posts by BryanEW710
Old Jun 25, 2011, 09:46 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I agree on the elevator expo. I had mine too low at first (around 25%) and found that I was inadvertently using elevator on my rolls. I bumped it to 40% and the problem (problem being my stubborn fingers) is resolved.
DoomsDay - you in Charlotte, NC? I live just south of Charlotte in Fort Mill, SC but I spend WAY too much time in and out of Charlotte Douglas Airport!
turnerm is offline Find More Posts by turnerm
Old Jun 25, 2011, 11:05 AM
DoomsDay is offline
DoomsDay's Avatar
Joined Sep 2003
Yep, I live about 2-3 miles from the airport lol.
Old Jun 25, 2011, 01:13 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by lord chris View Post
hi, they are made by miniaviation.com thats all it has on them.
cheers cheese5. are your 240mah packs the wider ones designed for the mosquito ect?
Originally Posted by Cheese5 View Post
Here are the hyperion packs that I usehttp://www.allerc.com/hyperion-g3-cx...or-p-5438.html
They are about twice the width of the stock batteries, with the length being about the same as a 120mah.
Chris,
Contrary to what Richos says, you don't have to gouge out anything to use the Hyp 180 or 240 cells. A small block of foam is all you need. Plus, they can be charged @ 5c for 300-400 cycles with zero loss in performance. If you can solder - you can buy bare Hyp 180 or 240 cells for $4 USD each & the connector w/wires for around $1.50 each, and then make your own lightweight cells. They'll be a couple of grams lighter than Hyperion's shrink-wrapped 'M' cells.
When it come to performance, voltage under load is the only thing that matters with LiPo cells. Advertised capacity has very little to do with it. Internal resistance is what determines the true discharge & charge c-ratings. A lower internal resistance means there is less voltage-drop within the cell. This reduces the power lost within the cell as heat, which increases the voltage under load. Lower internal resistance also increases the safe discharge & charge current, due to the lower cell temp.
A key indicator of true LiPo ratings is charge c-rating. A number of LiPo manufacturers inflate or blatantly lie about their discharge c-ratings. However, due to liability issues with fires, they will not inflate their charge c-ratings. Any true 25c or 35c modern LiPo cell should be able to be safely charged @ 5c without loss of performance. If the manufacturer advertises a discharge rating of 25c, 30c, or 35c, yet specifies a max charge of only 1c or 2c - beware! They are most likely hiding something.
I have yet to see any discharge comparison graphs of the new MA 190 25c vs. the Hyp 180 25c. However, Natterjack tested the MA 180 15c & the Hyp 180 25c, and MA has a graph of the MA 190 25c vs. the MA 180 15c. Looking at Natterjack's graph, it is evident that the Hyp 180 outperforms the MA 180 by a significant margin. Of course, one would expect this, since the MA 180 is only rated @ 15c. Looking at the MA's graph of their 180 15c & 190 25c, one can see that the MA 190 outperforms the MA 180. Since MA didn't specify the discharge current used for their tests, it's not easy to do a direct comparison.
That said - going by MA's data, the MA 190's voltage under load @ the 450 second mark is about the same or just barely higher than the Intellect 160 (just under 3.5V). Looking at Natterjack's data, one can see that the Hyp 180's voltage at the 450 second mark is 3.6V. The MA 180 is sitting just above 3.5V, while the Hyp 160 is only a couple hundredths of a volt below the Hyp 180 at that point.
If MA's test was done at or below 1.6A, the Hyp 180 will hold voltage under load a bit better than the MA 190. If so, a lightweight Hyp 180 will likely be the better performer, but the difference in power would be maybe 5%, at most. What needs to be seen is whether the MA cells can deliver the long cycle-life of the Hyp cells. Richos - do you happen to know the discharge current in MA's test?
BTW - I have a couple of MA 180s. In the Sukhoi, they had noticeably less power than my Hyp 160s, and they're considerably heavier. So, I use them in lower-current apps, such as the UM J-3 Cub. They're about two years old. I have over 100 cycles on each of them, and they still perform as well as they did after break-in. But they live an easy life in my stock J-3 at our winter indoor sessions.
Joel
turboparker is offline Find More Posts by turboparker
Old Jun 25, 2011, 03:58 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Great info and graphs. Much appreciated. I am still trying to weed through this whole thread before I start asking questions that have already been asked and answered several times. I installed a GWS 5043 and an RCFunlabs prop saver on my 8 day old xp this morning. I hate switching props on these micros using needle nose or hemostats to grip the shaft. So this morning I came up with an easy way. I took a 2mm allen wrench and slipped the short end through one of the holes in the gear. That made removing the stock prop and installing the prop saver much easier for me. Probably not an original idea but it worked well. Hope this little tip helps someone. Oh and the GWS 5043 kicks butt on this little bird.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jun 25, 2011, 05:31 PM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
Thanks for every1s in put and help
My 190mah packs arrived this morning.... :P
and today whilst stopped to feed the little one. i took the 26 up for a blast! altho it was crazy windy it was nice to hit full throttle and fly arrow straight where ever i pointed it!
mainden the sukhoi over a tank monument for the desert rats in Thetford forest
cant wait for a nice calm day now.
iv read up on a gws prop conversion done quite a while ago and wondered what peoples thoughts were now? are there any better props out there? or is gws the way to go?
cheers for all the help
chris
lord chris is offline Find More Posts by lord chris
Old Jun 25, 2011, 06:38 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
This is fun little plane! I picked mine up the other day, took it to the park and had a ball with it. It certainly flies different, and does things that almost defy physics :-)
I've been using the Thunder Power 160MAh batteries in my UM's with good success.
ViperZ is offline Find More Posts by ViperZ
Old Jun 25, 2011, 08:18 PM
kobkobico is offline
Find More Posts by kobkobico
Lucid Dreamer
kobkobico's Avatar
USA, CA, Temecula
Joined Jul 2005
Can you buy JUST the gearset for the linear board servos? My slow elevator seems to be due to a gearset that doesn't mesh perfectly.
If anybody has one they could sell to me that would be good too.
kobkobico is offline Find More Posts by kobkobico
Old Jun 25, 2011, 08:27 PM
Joined Jul 2009
chris
Chris,
Congrats on the maiden! The GWs 5043 is currently the best prop for outdoor flying. With the 5043 & a top-notch cell, the XP is capable of essentially unlimited vertical even 5 minutes into the flight.
Joel
Joined Jun 2011
i sent someone a link to these today... kobkobico
http://compare.ebay.com/like/2905042...=sbar&_lwgsi=y
i bought them for my msr when it was chewing through the servo gears, also used them on my champ when i got a bit of glue on the rudder gears some how, they are the exact same gears i just went and checked on my sukhoi. though, the 2 bucks is a bit much since you gotta pay shipping, id suggest buying a few packs to make it a little more worth your while.
Old Jun 25, 2011, 08:38 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
No but all the gears are the same between the Regular and L servos.
Post a wanted add in the Micro classified section and you should be able to get a good pinion/spur for $3 or so.
Discussion The Sukhoi Su-26xp Has Arrived earthling1984 Scratchbuilt Indoor and Micro Models 555 Jul 13, 2011 06:40 PM
New Product New Parkzone Sukhoi Su-26xp!!!! A-10_Flyer Scratchbuilt Indoor and Micro Models 6 Jul 26, 2010 12:03 PM
New Product Updated ParkZone ultra-micro Sukhoi SU-26XP jeffsch Scratchbuilt Indoor and Micro Models 26 Apr 13, 2010 12:01 AM
Discussion NEW....Sukhoi SU-26XP BNF by ParkZone Kilo60 Micro Ready-to-Fly 2 Mar 20, 2010 11:14 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
