Old May 10, 2011, 06:05 PM
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
just ordered mine today
celm is offline Find More Posts by celm
Old May 10, 2011, 11:19 PM
Electric foamy flyer
fly Frontier's Avatar
Chandler, Arizona
Joined Apr 2010
Where is a good place to buy some bright leds? i got abunch capacitors. What should I power them off of? plane battery? Rx 5v? or seperat bat?
fly Frontier is offline Find More Posts by fly Frontier
Old May 11, 2011, 06:22 PM
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
Originally Posted by fly Frontier View Post
Where is a good place to buy some bright LEDs? i got a bunch capacitors. What should I power them off of? plane battery? Rx 5v? or separate bat?
Try www.lazertoyz.com.
The prices are good, the LED systems are better, and the service is tops.
I doubt you will need the capacitors for their LEDs.
CurtissP40 is offline Find More Posts by CurtissP40
Old May 11, 2011, 06:43 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
If you are doing enough for night, I prefer to power them from a seperate battery. Many you get are for 12V (3S). You can power by the flightpack but your taking chances your not gonna have a problem. Of course, if it's at night and you loose your LED battery, it's going to crash anyway hugh?
Melnic is offline Find More Posts by Melnic
Old May 11, 2011, 07:48 PM
Swinger. Heli and planks!
United States, OR, Foster
Joined Mar 2007
The LED's from Hobbypartz are pretty good. Powered by 2 or 3s. If you want for night flying. http://www.hobbypartz.com/ledlights.html
if you want scale lighting I have this and it awesome http://cgi.ebay.com/GT-Power-flight-...item3f0912d66c
BennettOZ84 is offline Find More Posts by BennettOZ84
Old May 12, 2011, 12:11 AM
Chandler, Arizona
Joined Apr 2010
oops. i dont have capacitors, they are resistors. anyway... if it get a kit like that one above, can i sodder on more LED's?
Old May 12, 2011, 10:47 AM
Joined Mar 2007
Sure, you could solder on more LEDS.. Whatever lead you attached it to it will have that programmed feature... You can't attached standard LEDS to the LED strips from hobbypartz, but you can attach more strips easily
Old May 17, 2011, 10:52 PM
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
are you guys going by the CG whats in the manual of 80 mm back from leading edge of wing? i put a 2200 mah sky-lipo in mine and it seams nose heavy, you guys suffering same?
Old May 17, 2011, 11:14 PM
Joined Mar 2007
I sit at 64mm from the leading edge. I also have the nose heavy issue, I just pushed battery as far back as possible and switched out the stock nose cone and prop for much lighter ones.
Old May 18, 2011, 04:16 AM
Pigeonflyer's Avatar
Hungary, Europe
Joined Feb 2009
CG on mine is at about 65mm or even less. Still a tad too nose heavy due to a much larger motor and bulkier prop that I am using. For a while I was considering implanting a 9g steel ball into the base of the tail part for better balance (this would bring back CG to 65-68mm), but the plane flies nicely without it, so idea is dropped for the time being.
Pigeonflyer is offline Find More Posts by Pigeonflyer
Old May 18, 2011, 07:12 AM
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
Airfield is saying the CG is 80 mm from leading edge, then why are you guys setting it less?
Old May 18, 2011, 05:01 PM
Joined Mar 2007
Because it doesn't fly at 80mm from the leading edge without major trim.
Old May 19, 2011, 11:51 AM
Seattle, Washington
Joined Dec 2007
Does CA work on this foam or should I use epoxy?
unshackledbuzz is offline Find More Posts by unshackledbuzz
Old May 19, 2011, 02:35 PM
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
make sure its foam safe CA
Old May 19, 2011, 07:45 PM
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
flew mine for the first time today,not a bad plane but so under powered. going to put a 2 blade prop to get some more speed out of her,dont like that you have to fly with 3 quarter to full throttle to keep it stable
Discussion Range problem with Airfield 182 Skytrainer from Nitroplanes WeeksFlyer Nitro Planes 1 Jul 31, 2011 07:52 PM
Discussion Nitro Brushless RC Planes + Ducted Fan Jets from Nitroplanes.com nitroplanes Nitro Planes 8 Jul 25, 2011 04:15 PM
Discussion ARF 4-Ch AirField RC Sky Trainer 400 RC Airplane w/ Brushless Motor+ESC Cabledawg1 Nitro Planes 6 Jun 13, 2010 05:08 PM
Mini-Review Airfield's "F5 Tactical Fighter" from NitroPlanes.com jmpdgs Electric Ducted Fan Jet Talk 23 May 23, 2010 12:44 PM
Discussion Nitroplanes Airfield 70mm F16 shakaka Foamy EDFs 4 Feb 07, 2010 11:24 AM
