Old Jan 04, 2011, 03:16 AM
Pigeonflyer is offline
Find More Posts by Pigeonflyer
Pigeonflyer's Avatar
Hungary, Europe
Joined Feb 2009
Originally Posted by Visor View Post
My plane is almost ready. Just a few minor things left to do. Here is what it looks like...
Oh my...
That navi-light system is brilliant!!! With those bright strobes flashing the plane appears even more scale... Is it a home-made light system or the one from HK? Cooooooooool
Pigeonflyer is offline Find More Posts by Pigeonflyer
Old Jan 04, 2011, 10:19 AM
ninjafishable is offline
Find More Posts by ninjafishable
ninjafishable's Avatar
Joined May 2010
yeah +1 on those lights looks awesome man
ninjafishable is offline Find More Posts by ninjafishable
Old Jan 04, 2011, 01:32 PM
Visor is offline
Find More Posts by Visor
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Thanks, I'm glad you liked it Those lights and flashers are home built. Landing light switch is a modified stripped HXT500.
Description: paired green LEDs Name: PICT4093.jpg
Description: Paired red LEDs Name: PICT4100.jpg
Description: Flasher component Name: PICT4111.jpg
Description: Modified wing
Visor is offline Find More Posts by Visor
Old Jan 04, 2011, 01:37 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Originally Posted by Pigeonflyer View Post
Oh my...
That navi-light system is brilliant!!! With those bright strobes flashing the plane appear even more scale...
I had to do that flashy lighting to divert attention of Scale Police from altered wing
Old Jan 04, 2011, 02:49 PM
Joined May 2010
well i just ordered my 3642, and my esc... excited! did u fly it stock with out the modifed wings? wonder how much it will change flight characteristics
Old Jan 04, 2011, 03:55 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Congrats on your order - you will be able to use that combo on many other planes too. Its a good size motor
No I have not tried my plane yet. I hope it will fly good. My main worry is not to worsen the tip stall tendency. This plane from what I saw on Youtubes does like to stall on one side.
I will definitely post the video, and share my experience of the flight...
Hopefully soon! We had the most awesome weather while I was working on the plane. But tonight we are suppose to have a big dump of snow
Old Jan 04, 2011, 05:59 PM
Hungary, Europe
Joined Feb 2009
Still not sure if I get it right. You turn on the light system by switching on the landing gear channel on your transmitter which causes the HXT500 to make its 5V power supply available for your light circuit? Then you have the Philippino flasher circuit to provide intermittent signal for the strobes and the required resistance for each LED?
Or does the servo trigger only your landing light?
I have lights in my schratch-built An-2 Colt: that one has a circuit that monitors thrust level and switches on landing lights when thrust stick is anywhere between 50% and idle. All other lights are on as soon as power pack is connected to ESC. Strobe blinking rate options are programmable with throttle transmitter stick. The whole circuit is powered from one Lithium cell (used small cellphone battery).
Your system seems to be simpler and i might want something simmilar for the C-400 too, that's why I would like to know.
Old Jan 04, 2011, 07:58 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
It is somewhat similar to your An-2 setup. As soon as you plug in the battery, all lights come on except for the landing one. The servo is triggering landing light, and it is also providing 5 volts for operating flashers. All LEDs are powered by main LiPo, they all have their own current limiting resistor.
What I did to the servo is took the circuit board out of the case, threw away the case along with the motor and gears. Adjusted the POT so it is in its mid travel. This way the servo is "stuck" in the middle. In this configuration when you activate your landing gear switch, you will get power (+5V) on one of the motor wires, and the ground on the other. You can take either one of the motor wires to activate your LED they both provide either power or ground depending on the Landing Gear Switch position. You can hook up a white LED straight to the motor wire (through a resistor of course), or you can use a transistor to trigger your light (this is how mine is hooked up). The landing gear switch will either turn your light ON or OFF. It is pretty simple to do.
The flashers are made with 3 ICs - two 4093 NAND gates and one 4029 counter.
4093 and 4029 are set to give a double flash. A capacitor and a couple of resistor provide the timing. Another 4093 keeps the single red tail LED flashing. It has its own capacitor and resistors for timing.
The circuits are quite simple as well, but I used surface mount ICs - they are very small to work with.
The total weight of all these circuits and wiring is about 20g.
Old Jan 04, 2011, 09:04 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Here is a simple way to fix landing gear:
Drill holes on a slight angle (its easier if you drill a small pilot hole first)
Description: Drill holes
Use a cable tie (tie-wrap)
Description: Cable tie fix
This is the battery relocation - it can be accessed through the hatch in the roof.
Description: Battery access hatch
The hatch is closed
Description: Battery hatch closed
Old Jan 04, 2011, 09:07 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
VERY nice battery location mod!
With the much heavier 35-42 motor on mine it balances right at 70mm with a 2200mah 3s in the stock location.
Sammy70 is offline Find More Posts by Sammy70
Old Jan 04, 2011, 09:23 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
This is the motor mount - foam, ABS plastic (as its base), plywood and hot glue. It is lighter than the metal one and it absorbs the vibrations. It also saves the motor during a vertical power dive into the pavent
I use it on all my planes
Description: Shock absorbing motor mount
Old Jan 04, 2011, 09:25 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Thanks!
My CG is at 70mm now. I may do some adjustments after the actual flight.
Old Jan 05, 2011, 04:49 PM
Hungary, Europe
Joined Feb 2009
Well, if not simpler , it DOES include a brilliant piece of innovation i.e using the servo as power and signal source for LED lighting system! Thanks for the idea.
Roof hatch. It looks so original! I feel inspired to move along with my Cessna before finishing any of the other ongoing projects. Not as if weather would be inspiring, or even just suitable, for flying I am not a winter man...
Old Jan 05, 2011, 09:19 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
No problemas! Ummmm... a broken servo can be used and for other things... like ummm..
Check this one out - it ALWAYS makes me smile every time I watch it
Rocket assisted takeoff (1 min 58 sec)
We are suppose to have sunny weekend... and if it is not too windy... we may see some maidening action very soon! I hope so
Old Jan 08, 2011, 07:32 PM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Yay! Today was the first flight
The video is not great, but you can see the takeoff and landing.
I had to trim ailerons a lot to compensate fot its left banking. Why is it banking so much I am not sure yet, but I will find out.
It could handle a bit more power, I am thinking of getting yet a bigger motor... Though this stock 3 bladed prop is not the best choice here. 3 blades look good, but they are not very efficient.
Overall - it took off, it flew, and it came down in one piece. Actualy it landed quite nicely. And as a bonus - the front gear survived the landing. Not too bad for today
Cessna 400 maiden flight (3 min 26 sec)
Discussion Range problem with Airfield 182 Skytrainer from Nitroplanes WeeksFlyer Nitro Planes 1 Jul 31, 2011 07:52 PM
Discussion Nitro Brushless RC Planes + Ducted Fan Jets from Nitroplanes.com nitroplanes Nitro Planes 8 Jul 25, 2011 04:15 PM
Discussion ARF 4-Ch AirField RC Sky Trainer 400 RC Airplane w/ Brushless Motor+ESC Cabledawg1 Nitro Planes 6 Jun 13, 2010 05:08 PM
Mini-Review Airfield's "F5 Tactical Fighter" from NitroPlanes.com jmpdgs Electric Ducted Fan Jet Talk 23 May 23, 2010 12:44 PM
Discussion Nitroplanes Airfield 70mm F16 shakaka Foamy EDFs 4 Feb 07, 2010 11:24 AM
