Old Dec 30, 2010, 03:16 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by Visor View Post
By my calculations the wing loading of Cessna 400 is about 22 Oz/ft². Not exactly overloaded, but not a slow flier either.
As something to compare with - a Super Cub wing loading is roughly 13 Oz/ft²
Yes, I'm not overly impressed with this plane other than its unique looks. Stock motor is too wimpy and adding a stronger/heavier motor (also needed to get the CG where it needs to be) only makes it heavier.
Sammy70 is offline Find More Posts by Sammy70
Old Dec 30, 2010, 04:30 PM
Visor is offline
Find More Posts by Visor
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Yes, the stock motor is too wimpy. It will provide just enough power to fly, and not much more.
I am putting C3536 1100, it is heavier motor, but my home made motor mount is lighter. The stock motor/mount is 155g, my replacement is 150g. What will effectively (without adding extra weight) correct the CG is the battery relocation. When I finish all improvements I will post some pics.
Overall advise - if you are not comfortable with modifications/alterations of your new plane and looking for a well designed airplane straight out of the package - this one is not it.
I do love the way it looks, I must admit
Visor is offline Find More Posts by Visor
Old Dec 30, 2010, 04:42 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by visor View Post
overall advise - if you are not comfortable with modifications/alterations of your new plane and looking for a well designed airplane straight out of the package - this one is not it.
well said!
Old Dec 31, 2010, 07:14 AM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
This is what taxi light looks like. So far everything is going well. Still a few days away from maiden... weather pending
Old Dec 31, 2010, 10:29 PM
ninjafishable is offline
Find More Posts by ninjafishable
ninjafishable's Avatar
Joined May 2010
well ive been doing some research on motors, and was thinking about this one
http://hobbyking.com/hobbyking/store...dProduct=14847
would this be a good stock replacement? if i keep speedo and prop the same
wife will be cheesed if i order all new motor and esc and prop for my new plane she just bought me lol
im still new bare with me
ninjafishable is offline Find More Posts by ninjafishable
Old Dec 31, 2010, 10:49 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Yea, that motor would probably work, but it's still on the light side as far as moving the CG. If you're moving the lipo way forward you'll be ok.
I was NOT impressed at all by the stock prop. I would suggest a MasterAirScrew (MAS) 11x7x3 instead. You can still use the stock spinner with it too...
http://hobbyking.com/hobbyking/store...idProduct=8099
Good luck!
Old Jan 01, 2011, 10:03 AM
Joined May 2010
ok thanks! ive already got my cg @ 70 mm by moving the battery so i should be good
the 11x7x3 is outta stock i think ill just get the 11x8x3
Old Jan 01, 2011, 10:37 AM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I'd sure use a 40a esc as well with that motor & prop. The stock 30a is going to be iffy at best...
Get one of these:
http://hobbyking.com/hobbyking/store...idProduct=9482
The BEC inside is of the "switch mode" type which means it can safely power more servos when under a load.
Stick your stock motor & esc in the classifieds here on RCGroups and recoup some money
Have fun!
Old Jan 01, 2011, 10:50 AM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Here's a little heavier motor (same that I used):
http://www.hobbyking.com/hobbyking/s...idProduct=3884
Old Jan 02, 2011, 05:43 AM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
This motor is a good choice. 40A controller (up to 6 cells LiPo and 4A BEC... - nice!) is also a good one to use for this motor. It looks like a good combo
My first brushless motor I began learning to fly with my good old Super Cub later went through several planes (with some very serious mishaps in between ) and is still working - using it now in my ParkZone Spitfire.
Old Jan 03, 2011, 03:30 PM
Joined May 2010
well little more progress done. i stopped by the lhs and they had some master airscrew 11x7x3's, so i picked up one, along with some du-bro 2.25 r's. did a little rolling in the grass in the back yard and much better now (than foam wheels)
just waiting on a buddy and ill be ordering new motor/esc!
i did ditch the wheel scirts for now, to balance the weight change on the new wheels. plus they restrict it in grass i find
i only fly grass feilds around here so rog is big for me
Old Jan 04, 2011, 12:51 AM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
My plane is almost ready. Just a few minor things left to do. Here is what it looks like...
The CG is about 70mm. The main wing grew a liitle bit wider... oops! (I hope Scale Police will let me get away with that ) I did not like the trailing edge, so it is much sharper now.
Cessna 400 Corvalis (1 min 3 sec)
Old Jan 04, 2011, 12:55 AM
coinworker is offline
Find More Posts by coinworker
What's tomorrows forecast?
coinworker's Avatar
United States, IN, Goshen
Joined Jun 2009
wow that looks great!!
coinworker is offline Find More Posts by coinworker
Old Jan 04, 2011, 01:01 AM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
It is a good idea to have those wheel pants off...
I will keep mine for now, may take them off later... We'll see
Old Jan 04, 2011, 01:03 AM
Visor is offline
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
Thanks! We'll se how she survives the maiden flight...
Full throttle and up she goes!
Discussion Range problem with Airfield 182 Skytrainer from Nitroplanes WeeksFlyer Nitro Planes 1 Jul 31, 2011 08:52 PM
Discussion Nitro Brushless RC Planes + Ducted Fan Jets from Nitroplanes.com nitroplanes Nitro Planes 8 Jul 25, 2011 05:15 PM
Discussion ARF 4-Ch AirField RC Sky Trainer 400 RC Airplane w/ Brushless Motor+ESC Cabledawg1 Nitro Planes 6 Jun 13, 2010 06:08 PM
Mini-Review Airfield's "F5 Tactical Fighter" from NitroPlanes.com jmpdgs Electric Ducted Fan Jet Talk 23 May 23, 2010 01:44 PM
Discussion Nitroplanes Airfield 70mm F16 shakaka Foamy EDFs 4 Feb 07, 2010 12:24 PM
