Old Oct 24, 2010, 10:49 PM
RealMuhko is offline
Find More Posts by RealMuhko
Joined Sep 2010
May I ask a (probably stupid) question...
The "Motor Board" - Is that the white plastic board on which the metal motor mount is attached - right ?
And also the "Motor Board" has the nose wheel attached in these plastic "rings" - right ?
http://static.rcgroups.net/forums/at...g?d=1278369163
Cheers, Martin.
Originally Posted by Pono420 View Post
i have changed the motor board on my sky 400 about 5 times, 5 different ways,
till i found a fix to the prob's with the motor board.....
RealMuhko is offline Find More Posts by RealMuhko
Old Oct 25, 2010, 12:19 AM
coinworker is offline
Find More Posts by coinworker
What's tomorrows forecast?
coinworker's Avatar
United States, IN, Goshen
Joined Jun 2009
yes that's the motor board or what i call a firewall. it's the weak spot on this plane. it just doesn't hold up to hard landings.
coinworker is offline Find More Posts by coinworker
Old Oct 25, 2010, 08:44 AM
Joined Sep 2010
Tell me about it...
Already smashed mine when landing onto grass - but I guess that's life...
Oh well, luckely there is spareparts to buy....
Is it difficult to get the old motor board out ?
/Martin.
Old Oct 25, 2010, 10:41 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Nitroplanes has a new coupon code. Note that it's mispelled once on their main page.
It's EVERYPLANE, not EVERYPLANES
Here are current coupons:
Coupons
Melnic is offline Find More Posts by Melnic
Old Oct 27, 2010, 12:45 AM
Pono420 is offline
Find More Posts by Pono420
Pono420's Avatar
USA, CA, Bakersfield
Joined Apr 2009
Originally Posted by RealMuhko View Post
Tell me about it...
/Martin.
its ez to take out.
the mod that ive been working on is working out good. you should check it out. the stock motor board will keep braking in 2.
i just got a MONSTER POWER .10 (1100KV) today and i will maiden 2-maro, and i will make a vid
Pono420 is offline Find More Posts by Pono420
Old Oct 27, 2010, 07:54 PM
coinworker's Avatar
Joined Jun 2009
i gotta see this snap in mod!!! i glued mine in so well i had to make a cut an inch behind it just to get it off the plane to work on the back side of the wall. i've been eye'n that monster 10 for awhile, let me know what you think.
Old Oct 27, 2010, 10:27 PM
touchdown2 is offline
Find More Posts by touchdown2
Joined Oct 2010
sky trainer 400
Know anywhere I can get parts, I need a prop shaft that goes on the motor and a prop/spinner holder that attaches on the shaft.
touchdown2 is offline Find More Posts by touchdown2
Old Oct 28, 2010, 02:39 AM
Pono420 is offline
Pono420's Avatar
Joined Apr 2009
[QUOTE=touchdown2;16401784]Know anywhere I can get parts, I need a prop shaft that goes on the motor and a prop/spinner holder that attaches on the shaft.
Thanks[/
you can get all the parts for the sky400 from nitorplanes. but the motor has been out of stock for a long long time.
i havent found a spiner shaft for that motor anywhere.
when mine got bent i got a pice of metal and drilled a hole just
a little bit bigger than the shaft. then you put the shaft in the hole (lol)...
and tap with a hammer till the base of the prop adapter is flush.
it will be close to center, but this is just a cheep, simple fix till you can get a new motor.
i just got a monster power .10 from hobbypartz.com with a new spinner and a 10/7 apc prop, and some 3cell 2200mah 30c lipos.
i am going to run the new motor and lipos with the stock ESC on my wattmeter
2nite to see if the esc can take it. i will post the info and pics for the mod on the motor board, and the motor.
we are all here to help.
Old Oct 28, 2010, 10:58 AM
coinworker's Avatar
Joined Jun 2009
my guess is it would cost nearly as much to buy and ship the shaft as it would to just buy a new motor!
Pono would it be dirty of me to suggest you supply pics of you inserting your shaft in the hole
in all seriousness that is smarter than trying to bend it back with channel locks and a clamp i'll have to remember that ...technique ... next time i'm in need
Old Oct 31, 2010, 02:11 PM
Pono420 is offline
Pono420's Avatar
Joined Apr 2009
i went out for a maiden flight with my new MONSTER POWER .10 with the stock ESC and a 10/5E apc prop and a SKY LIPO,2200mah 30c and it pulled
32.5amp and about 325watts. this is a good setup for this bird, its alot better the the stock motor. iam going to try useing a 40amp esc with a 10/7, or a 10/4.5 with a 4cell.
iam going out to fly 2day with my cam, and i will post a vid...
ps.
the motor board mod that i made is workinng out very very good.
IT'S UNBRAKEABLE
Old Nov 06, 2010, 01:24 AM
Pono420 is offline
Pono420's Avatar
Joined Apr 2009
i've put about 20 flights on my 400 with the new monster power .10 and the motor board mod i made. and she is flying GRATE!....
iam using a 10/5apc, and stock ESC, and a 2200map 30c lipo.
shes fast, about 55-65mph.
THE STOCK MOTOR AND PROP IS CRAP!!!
my mod is still in 1 pice, no bend, no crack's... THIS MOD ROCKS
looks like i will never have 2 fix the motor board again.
if you dont wunt 2 keep changeing the motor board over and over again,
try my mod out, its cheep, ez, and under 10 buck.
it took me about 1-2hr. 2 do.
ps.
if you use this motor on the stock motor mount, reduce some of the angle on the torque roll.
Old Nov 12, 2010, 01:39 AM
motogolfer is offline
Find More Posts by motogolfer
motogolfer's Avatar
Joined Mar 2010
ps.
what spinner are you using with this setup? and could you post some pics please?
motogolfer is offline Find More Posts by motogolfer
Old Nov 21, 2010, 05:35 PM
Pigeonflyer is offline
Find More Posts by Pigeonflyer
Pigeonflyer's Avatar
Hungary, Europe
Joined Feb 2009
This is the setup in my mod. The stock motor is a 2836 900 kv "FMS Models" type (seen on the left) the new is a Turnigy C4240 900kv. The prop dimensions for the original 3-blade setup were said to be 13x9 which is nonsense: diameter is actually 11, pitch probably also less then what is said. Moreover, this size indication is not printed or attached as a label but it was created when the prop was moulded. Shame...
I gave this weakish motor and prop to my 1200 mm biplane and test-ran it on 3 cells. Very moderate thrust, lots of resonance from the ill-balanced prop, and heated up motor after the static test...
Nevertheless, what the Cessna has now looks nice, and now I will replace the nylon firewall with a ply one, with a longer front gear shaft and additional upper gear bearing.
Pigeonflyer is offline Find More Posts by Pigeonflyer
Old Nov 21, 2010, 11:58 PM
miksta115 is offline
Find More Posts by miksta115
**RC MANIAC**
miksta115's Avatar
USA, CA, Rohnert Park
Joined Jul 2010
I was debating between this and the new Flyzone Corvalis that is coming out and now i know I'm gonna get the Flyzone. Nitroplanes just has too many quality issues, just for a little more money I can get flaps, lights and better quality with a Flyzone Corvalis
miksta115 is offline Find More Posts by miksta115
Old Nov 22, 2010, 10:07 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
What's the diff between the skytrainer 400 originally posted and this one?
http://www.nitroplanes.com/60a-dy893...rf-silver.html
One buddy has a big Lancair and these look very much like it. Another buddy is interested in the skytrainer 400 and I"ve been pointing him here to this thread.
Discussion Range problem with Airfield 182 Skytrainer from Nitroplanes WeeksFlyer Nitro Planes 1 Jul 31, 2011 07:52 PM
Discussion Nitro Brushless RC Planes + Ducted Fan Jets from Nitroplanes.com nitroplanes Nitro Planes 8 Jul 25, 2011 04:15 PM
Discussion ARF 4-Ch AirField RC Sky Trainer 400 RC Airplane w/ Brushless Motor+ESC Cabledawg1 Nitro Planes 6 Jun 13, 2010 05:08 PM
Mini-Review Airfield's "F5 Tactical Fighter" from NitroPlanes.com jmpdgs Electric Ducted Fan Jet Talk 23 May 23, 2010 12:44 PM
Discussion Nitroplanes Airfield 70mm F16 shakaka Foamy EDFs 4 Feb 07, 2010 11:24 AM
