Old Jun 10, 2010, 07:35 AM
Diesel 48 is offline
Find More Posts by Diesel 48
Diesel 48's Avatar
USA, MI, Zeeland
Joined Sep 2006
Wild Hare Slick 540 Build help
I am about to glue my vertical and horizontal stab to this plane. Are there any tips and tricks for making these square? How do I insure the horizontal stab is level with the wing? Do you eye ball it? If the angle needs to be changed slightly how do you do that? Thanks for the tips!
Diesel 48 is offline Find More Posts by Diesel 48
Old Jun 10, 2010, 12:41 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The eyeball is the best method. If you can, mount the wing and view the H stab for level, also view from on top to see if it looks cock-eyed.
The H stab need to be quite a way out to affect the flight. The V stab should be as in-line with the fuselage as possible. But again it has to be quite visually wrong to have much affect.
Same for the motor. For down thrust and right thrust, put the prop on, (or something flat with a hole in it), and just make sure you can visually tell that there is some slight angle in the right direction. Once flown, then the trust line can be changed to suit the flying characteristics, (usually by putting a washer space behind the motor mount, if you have one). There is no exact angle of down and right, each model can be different.
In a catastrophic mounting job, a knife and glue can solve most things.
eflightray is offline Find More Posts by eflightray
Wanted Wild Hare Edge 540 Cowel "new version" outofsight Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2009 09:31 PM
Wanted Wild Hare Edge 540 88" WS plane/parts outofsight Aircraft - Fuel - Airplanes (FS/W) 3 Nov 08, 2009 10:36 AM
Wanted FUSE for Wild Hare 28% Edge 540 version 1 les2097 Aircraft - General - Miscellaneous (FS/W) 0 Jun 20, 2007 12:17 AM
Video Wild Hare Edge 540 converted to electric feathermerchant Electric Plane Talk 2 Jan 15, 2007 03:43 PM
