Old Oct 03, 2010, 10:48 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Anyone in the UK looking for some video goggles? I just saw this in the latest CPC catalogue and it looks like a pretty decent deal.
http://cpc.farnell.com/q-london/ql92...?Ntt=av1840746
lovegroove is offline Find More Posts by lovegroove
Old Oct 03, 2010, 11:02 AM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
No bad at all Shame i dont have any money.
Does anyone here fly using goggles with glasses as i thought that that might be a problem if i get goggles.
ghost2212 is offline Find More Posts by ghost2212
Old Oct 03, 2010, 12:29 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
One of our members came up with this : http://www.fpvuk.org/forum/index.php?topic=820.0
Worth considerring
Coyote64 is offline Find More Posts by Coyote64
Old Oct 03, 2010, 12:47 PM
Bandarra is offline
Find More Posts by Bandarra
Bandarra's Avatar
UK, South Yorkshire, Sheffield
Joined May 2009
Anyone here in the UK has a "spare" CEOSD that they want to sell?
Is there any other place other than BEVRC that sells these? where/who do they come from originally does anyone know?
Bandarra is offline Find More Posts by Bandarra
Old Oct 03, 2010, 12:52 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
I belive that the original manufacturer is http://www.foxtechfpv.com/ it is also stocked at FPVhobby
Old Oct 03, 2010, 12:55 PM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
try lowpricerc they got them and cheap delivery
bignose13 is offline Find More Posts by bignose13
Old Oct 03, 2010, 01:03 PM
Bandarra is offline
Bandarra's Avatar
Joined May 2009
I suspect foxtech is somewhere in China and FPVhobby is apparently in Istanbul
Has anyone have particularlu good or bad experiences with either?
Old Oct 03, 2010, 01:10 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
I wear specs and to complicate it a bit more, they're varifocal.
My take on goggles using a ski mask designed for spectacle wearers.
http://www.fpvuk.org/forum/index.php?topic=635.0
Also, my ground station with 8" LCD TV + Archos 400 + SD/CF solid state recorder (records through static, so no 'blue screen').
Difficult to see the LCD's in daylight without a shroud.
Not shown is the tripod for mounting the VRx.
I got the LCD TV on eBay as the ones without built in FreeView go for next to nowt (15 for mine), runs on 12V and only consumes 1 amp when powered up. Has AV input too.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Oct 03, 2010, 01:45 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
I wear specs as longsighted (+2.50), but don't need them to wear goggles!! Just means have to launch / land with gogs on - or wear contacts.
Shikra is offline Find More Posts by Shikra
Old Oct 03, 2010, 02:20 PM
Bandarra is offline
Bandarra's Avatar
Joined May 2009
Say you have a lipo pack that is more than capable of delivering the max ampage of your motor or ESC, like a 35C discharge rate 2000mAh batery, so 2x35=70A right...
And your motor specs say max current 40A. Then what is the problem of getting a ESC of 40A? will you stress you ESC? will you not use your motor to its full potential?
Say you have that same motor, max current 40A and you get a 60A ESC. What can be the problems then? frying your motor because the ESC provides too much?
I still dont quite know how this all works but I would like to.
Also, what happens to a 50A current sensor on a OSD if you put 60A through it?
ps. just as an example I bought some time ago the grayson V3 motor, came with a 20A ESC. later because I thought the ESC could be giving me some issues i swapped the ESC for a 25A one. don't know if it was the ESC or the reving of the motor while stationary ( no air flow while range check) but I smoked it. Later tried it and it worked fine (on the old ESC tho)
anyway... just a few thoughts I've been having
ps2. what about connecting that same 60A ESC to a smaller 30A motor...
Old Oct 03, 2010, 02:39 PM
Devonboy is offline
SW England
Joined Aug 2009
Bandarra,
A 40A motor can only 'pull' upto it's maximum rating, even if you had a 90A ESC feeding it, you wouldn't hurt the motor under normal conditions.
You always need to use an ESC of more than the motor's max rating, in your example, a motor of max 40A needs to be supplied by an ESC of more than 40A - eg, 50A or 60A would be fine.
Nigel.
Old Oct 03, 2010, 02:43 PM
Bandarra is offline
Bandarra's Avatar
Joined May 2009
thanks! that is good news!
by the way... given your explanation I don't have that problem anymore (because I plan on buying a CEOSD [50A current sensor] and my motor will only pull up to 40A) but out of curiosity what do you think would happen to a current sensor if you go over? should be built fail safe and only display its maximum and not fry... lol not sure if that what they do
Old Oct 03, 2010, 02:48 PM
Devonboy is offline
SW England
Joined Aug 2009
As with any semiconductor, if you go over it's rated limits, it will almost certainly go pop.
I thought most current sensors being supplied now were rated at 100A, in this case, bigger = better (for a healthy safety margin).
Nigel.
Old Oct 03, 2010, 04:10 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by StealthWorkx View Post
Mike, no I did a day trip out to the iow and took off from alum bay. Took off by throwing the zeph over the side of the cliff!!!
I actually couldn't see the needles from where I was so didn't want to push my luck by actually threading them.
Yeah I worked out that there's 800 replacement cost, what with the zeph itself, gopro and all the gear.
Mike, I'm curious, what other vids do you want to make.
Monster I've uploaded a vid with a password to Vimeo.
Ha well i wondered if your usual launch place is within hitting distance of Ryde Pier... But you can do it first then maybe I'll follow you the next time
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Oct 03, 2010, 04:17 PM
undefined
Joined Jun 2008
got a 180deg digital servo from FPVHobby. the Servo is ok (nearly 180deg - maybe I need a radio with more endpoint adjustment) and arrived within a week. Adnan is on RCG and seems a pretty decent sort of fellow
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11046 Today 02:41 PM
Discussion UK to France FPV srjs FPV Talk 98 Jul 21, 2016 02:14 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
