Old Nov 02, 2011, 05:52 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Originally Posted by fpvnick View Post
That's nuts I would love to fly into work on one of them buzz past all the traffic with people looking out there car windows open mouthed.
Hope he had a fail safe set imagin if it lost rc and went to full power like shikras multiwiicopter did and went off into the clouds with
you on it.
I'd defanatly be wanting a hard wired control for shore!
I don't think I would be sittingin the middle of the blades ether what it it threw a blade ! Splat! Ouch! Death! Having all that over you would be far better and sitting under would also help the c of g be lower I would have thought.
Shall we all chip in and make one for the next meet lol.
You hit the nail on the head. I drew up, a year ago mind, a frame with underslung seat. Hard wired controls. Aluminium frame with magnesium motor mounts. X8 format with electric. Though I decided in the end for endurance I'd go with 4 petrol engines with a variable rotor speed (for yaw) and variable pitch props. Running by the hoverfly pro control board (as that can work with variable pitch props). Only issue I had was money and of course the legal side of things.
Carlos230023 is offline Find More Posts by Carlos230023
Old Nov 02, 2011, 06:06 AM
micarus is offline
Find More Posts by micarus
Joined Mar 2009
canard
Originally Posted by Upup View Post
First a thank you to Angelos for pointing me in the right direction to repair my vtx
Thanks mate
Also thanks to tec3dad for the inspiration of his deltastorm, Almost finished this scratch build of a delta with operational cunards
Did not hot wire the 3/4" blucore foam cut out the wing shape and measured 30% measured 3/4" each side of that marked the centre thickness and cut off the four thin wedges with a hacksaw finished it off with a orbital sander
Covering is packing tape from staples 55mm edf is from a XPD8, air intake =coffee cup thrust tube cut from a ginger beer bottle
Originaly the idea was to use some of my old brushed bits laying about.
But now I think this is crying out to be a fpv ship quite fancy building another very slightly bigger with a cam in the nose air intake as a poor mans funjet but with a hidden cam.
I think this 27" ws would take fpv with a better power system seems a candidate for that bullet cam I am testing.
Oh well do one job and make twenty
Regards Jeff
Great job Jeff, look forward to the bigger one and video.
Cheers MIKE.
micarus is offline Find More Posts by micarus
Old Nov 02, 2011, 07:49 AM
SkyEyes is offline
Find More Posts by SkyEyes
Multi Rotors Rule ! ;-)
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
Perhaps V2 (version 2) will include a central lightweight "pod" that the pilot sits in, so he can fly without danger of getting hit, should a blade break or anything.
Plus wonder how many blades it takes to reliably take the weight of the person sitting in it. So if 1, 2, 3... blades stopped spinning, could it still fly without dropping out of the sky (redundancy).
Obviously you wouldnt want a handful of blades to all stop at once, on one side of the craft, or it WOULD then likely just tip over!
(perhaps the clever way they wired up groups of motors prevent this happening should a partial power issue occur)
OK, now Im thinking into this too deeply!
SkyEyes is offline Find More Posts by SkyEyes
Old Nov 02, 2011, 09:32 AM
Joined Jun 2007
Lol. Thats exactly how I wasted 4 weeks sketching up technical drawings looking at material tolerances, weights and potential flight & landing stress. I had designed a 1 seated and a 4 seated with a central joystick and all passengers looking in. Ergonomically it meant that sat in any position a forward push on the control stick would make you move in that direction. Of course you'd need colour changing nab lights to compensate for the altering forward flight direction... :P. I've got pages of this stuff
CJ
Old Nov 02, 2011, 09:51 AM
SkyEyes is offline
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
Sounds impressive Carlos - perhaps you could send on some of your plans and designs to this company, who might look to implement features into their fabricated craft?
Either that, OR... Get your own "sit on" Quad developed ASAP, put a video up of YOU sat in its centre, hovering around Milton Keynes, then add me to the top of the Order list.
Old Nov 02, 2011, 09:58 AM
StealthWorkx is offline
Find More Posts by StealthWorkx
What was that...
StealthWorkx's Avatar
UK
Joined Nov 2009
Huskey, Your package is in the post
UniAlfieBoy, Your package is in the post
Barney, Nicley done keep up the good work
Liam, Answer your txt's
German guys straping burshless motors to themselves - also nicely done here's a link for ya if you go any higher http://brsparachutes.com/
StealthWorkx is offline Find More Posts by StealthWorkx
Old Nov 02, 2011, 11:19 AM
Joined Jun 2007
Honest to god if I had figured out how much the damn thing would cost I'd be building it now. Roughly 3500 just for the materials to build the frame! Not to mention motors (gas or electric) digital servos man enough to do pitch control. It's a job for when I win the lottery .
CJ
Old Nov 02, 2011, 11:28 AM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
I don't think the cost for building a full size multi-rotor is awfully forbidding but after the initial achievement it is a totally useless project. You probably don't want to fly it more than 2m off the ground and who knows what type of licensing restrictions it has. It is possible that manned flying it nor permitted altogether. It is also possible that the packs only last 2-3 minutes so no much fun either.
-Angelos
Angelos is offline Find More Posts by Angelos
Old Nov 02, 2011, 11:40 AM
Joined Jun 2007
Well if I use gas and variable pitch props I'd be alright on endurance. And I can think of alot of commericial uses. Site servays. Airel observation platform. It has potential as a light commercial lifting tool. I'm sure applications could be found for it. It'd have far less complexity than a helicopter despite having 4 motors or more. as far as I'm concerned it's a route I wouldn't go down. But I can tell ya. I'd rather be 200 meters off the ground instead of two. More thinking/bailout time :P.
CJ
Old Nov 02, 2011, 12:03 PM
SkyEyes is offline
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
How about this guy (sorry its off-topic). But its still "hovering"? lol.....
Water Jet Pack: Get High with Jetlev! (3 min 14 sec)
Old Nov 02, 2011, 12:08 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
http://www.youtube.com/watch?v=im1iNq02Kz0
was that Jesus at 0:29 ??
rcmonster99 is offline Find More Posts by rcmonster99
Old Nov 02, 2011, 12:47 PM
unialfred is offline
Find More Posts by unialfred
unialfred's Avatar
Joined Oct 2009
To do that you need a boat top follow you with the pump in.
unialfred is offline Find More Posts by unialfred
Old Nov 02, 2011, 02:20 PM
SouthPawPaul is offline
Find More Posts by SouthPawPaul
Electronics slayer
SouthPawPaul's Avatar
Reading, UK
Joined Jul 2008
It seems it's my turn to have angered the VTx gods today. Not sure what I did to make the magic smoke come out as I pulled everything apart in a panic when I heard that dreaded "fssssst" sound.
Anyone with the 500mw Airwaves 2.4ghz Tx take a look at the burnt component in the image I've attached and tell me what it should be. I'm fairly sure it's a capacitor, but it's not a type I've seen before.
SouthPawPaul is offline Find More Posts by SouthPawPaul
Old Nov 02, 2011, 02:22 PM
Angelos is offline
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
I enquired about the JetLev (water jet pack) early 2009 because my uncle had a water sports business and I thought it would be a good addition. Their exact reply:
> We offer 3 different engine types 150hp=€99.000, 220hp=€119.000, and 300hp=€129.000
IMO they lost the plot! I can understand if the price was twice the cost of a top end jet ski but for that money they will only sell them to very few people that have more money than know what to do with it. And quite frankly there isn't much more hardware in it than a jetski has.
-Angelos
Old Nov 02, 2011, 02:57 PM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
it has 336C on the top line of text and 80B31 on the bottom
fpvnick is offline Find More Posts by fpvnick
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11263 Today 09:40 AM
Discussion UK to France FPV srjs FPV Talk 98 Jul 21, 2016 02:14 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
