Old Dec 06, 2010, 03:03 AM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by rcmonster99 View Post
Don't know about angle of view but I use 3.6mm (most common amongst mini cameras or 2.8 for a wider field of view.)
thanks Bernhardt. I used 3.6 for the first time this weekend and found that everything looked a very long way away. I guess there's aperture to consider too. I think I'll get a few and do some experiments.
cheers
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Dec 06, 2010, 05:06 AM
StealthWorkx is offline
Find More Posts by StealthWorkx
What was that...
StealthWorkx's Avatar
UK
Joined Nov 2009
Nick Bud,
Can you give me a link to the cam you used on your Xeno, the one you got from ebay.
Cheers, i was thinking of getting one as when i look at the vid i recorded of your flights compared to the skywalker flights, your's are much better.
Also, Liam, i think you mentioned theres somewhere on the forum someone has got the settings of how to set the osd cam so it works much better. Any chance of that linky link?
Also Paul,
Can you give us a lesson in the use of a ferrite ring......please
as you know i was getting failsafes left right and center on both the stealthwing and the skywalker. now it could have been local RF issues (but then why was nick not effected when he was chasing drifters) or my setup. (more likely). So what i was gonna do is bung in a load of ferrites and see what happens, trouble is i dont know how to (well i sort of do but i'd like to hear it from the ferrite ring king)
So, where do i put then, how do i install them, how do they work.
Many thanks
Owen
StealthWorkx is offline Find More Posts by StealthWorkx
Old Dec 06, 2010, 05:15 AM
What was that...
UK
Joined Nov 2009
Oh and guess what i just got in the post.......yup some thermal underwear just in time for next years meet.
Old Dec 06, 2010, 05:28 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Stealth - firstly try to slip your finger inside your ring. If it goes in easily, then you will need a tighter one for better performance. If you enjoy it, then you might be better off in one of the other forums on the web...
Sander explain it all somewhere. And with nice pictures too.
In a nutshell, 5 or more winds around a coil should be enough
To help stop a device sending interference over power lines (e.g. cam causing poor radio range) put it as close to the device as possible on it's signal output.
To help stop a device receiving interference (e.g. video tx - lines accross the screen), put the coil as close to the inputs.
I'd range test first, but if can't be arsed, go for the cam first....
Shikra is offline Find More Posts by Shikra
Old Dec 06, 2010, 05:41 AM
What was that...
UK
Joined Nov 2009
I'll ignore the first bit, dirty boy.
so, cam, vtx get a ring. ESC too?
and that goes for flying off the GoPro too. With my GoPro StealthWing (which i think you said you wanted one - right ) it's knocking out GPS sats too. and also got a failsafe close to the tower. almost had to do a walk of shame
Old Dec 06, 2010, 06:07 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Hmm interesting, i never considered it knocking out the GPS but on my last flight half way through my gps lost all connections. But then it was fine. I then extended my gps semsor back away further from 2.4ghz vtx and gorpo but ive not tried it yet
I know if you power the gopro rather than run off its own battery its rf noise reduces drastically
Coyote64 is offline Find More Posts by Coyote64
Old Dec 06, 2010, 06:13 AM
What was that...
UK
Joined Nov 2009
I'm powering the GoPro from it's own battery. A read stories of it doin what you said so chose to run off its own battery.
I'm running EzOSD and i'm reluctant to cut into the heat shrink and extend the gps out. I think i'll try a few toroids, if no good i'll try flying off a fpvnick 600tvl ebay cam
Old Dec 06, 2010, 06:18 AM
undefined
Joined Jun 2008
in the DOSD+ thread, Daniel recommends putting a ferrite just next to the GPS to counteract all the RF coming out of the cameras, and it works a treat. I get sat lock MUCH quicker and the lowest HDOP I've ever seen since I did this.
I also put them on the ESC wire and near the camera and on the camera+VTx power lines too. got rid of ESC noise on screen. My plane is a flying ferrite!
Old Dec 06, 2010, 06:25 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
I extended mine with supplied gps extension on all the others. The longer cables much more practical, gets the sensor away from all the metal on board. Just a tiny slit in the heat shrink unplug and plug. Its still under warrenty too if that worries you ?
Old Dec 06, 2010, 06:28 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Hmm think ill give the ferrite close to the gps after i try again with sensor further away and report back. I like the idea of quicker locking although mines not too bad, but if it locks quicker on startup it means quicker lock if its lost again
Mind you on the flight i lost the link i broke many fpv records According to the google earth play back i went to italy for a minute. Thats fpv range record smashed, fpv speed record smashed and 2200 mah 3 s lipo endurance record smashed in one flight lol
Old Dec 06, 2010, 06:31 AM
undefined
Joined Jun 2008
when I flew in France I visited Algeria and back in under 30 seconds, beat that!
Old Dec 06, 2010, 06:33 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
Owen here is the link to the cam i got off ebay you get free shiping if you buy it directly from them there are 2 links cant realy see any difference so take your chose
http://www.securitycamera2000.com/pr...-OSD-Menu.html
http://www.securitycamera2000.com/pr...rd-Camera.html
I have toroids on the control wire from the esc close to the esc, on the cam out line again close to the cam I also put one on the servo lead of the servo I am using for pan on the fj just encase it picks up any noise from the cam.
fpvnick is offline Find More Posts by fpvnick
Old Dec 06, 2010, 06:40 AM
undefined
Joined Jun 2008
(jumps in) I think the difference is that one has a plug-in OSD, the other doesn't
bought one this morning!
Old Dec 06, 2010, 06:46 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Sounds like you need one on the cam - as close to the cam as you can get it. And another on the gps wires again, right next to the GPS.
Or replace the cam (assuming thats the prob!)....
if you can get them further apart - even better.
What cam are you using?
Old Dec 06, 2010, 06:47 AM
What was that...
UK
Joined Nov 2009
Cheers bud, have you got the eBay linky link? you know what im like, i wanted it yesterday.....
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10795 Today 05:26 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion UK to France FPV srjs FPV Talk 95 Oct 11, 2014 12:10 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
