Old Nov 22, 2012, 12:47 PM
DodgeRC is offline
Find More Posts by DodgeRC
Cable ties & ductape
DodgeRC's Avatar
United Kingdom, Wilmslow
Joined May 2011
Originally Posted by mjc1970 View Post
I use 2 4S 2200's on mine. Have a look at the build log, it shows all the other kit I have used.
This is abit of a noob question as i've only ever flown with 3000mah flight and 500mah camera, but when running 2 x 2200 lipos, I guess they are run in series, so in essence creating 4400 mah?
And this powers the flight and the camera/vtx etc?
Cheers =]
DodgeRC is offline Find More Posts by DodgeRC
Old Nov 22, 2012, 12:55 PM
SouthPawPaul is offline
Find More Posts by SouthPawPaul
Electronics slayer
SouthPawPaul's Avatar
Reading, UK
Joined Jul 2008
Cheers =]
No. Series will give you the same current both both the voltages added together. In order to double the amperage you need to parallel the batteries.
i.e 2x 3300mah 3s1p series'd together would give a 22.2v 3300mah battery. Paralleled would give a 11.1v 6600mah battery.
SouthPawPaul is offline Find More Posts by SouthPawPaul
Old Nov 22, 2012, 01:03 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
ahhh thats the one =] cheers!
/Will look into it when i start the venturi or skywalker =]
Old Nov 22, 2012, 02:45 PM
icedfusion is offline
Find More Posts by icedfusion
Joined Aug 2011
I am looking for a decent 2.4Ghz vTx that can be used with an immersionRC duo 2400 (feel free to recommend another diversity video Rx).
So far, I have been told that lawmate have issues with returns so some firms have stopped stocking them.
There are the vTx at hobbyking, but i am not convinced of the quality.
I hear good things about the Boscam - but the cheap dipole antenna is glued on!
I need a minimum of 500mW as I expect that to give decent range as I will be using a 11db gain helical antenna on an AAT.
Please don't suggest other freq. to use as I have decided my complete setup and 2.4GHz vTx from multi->ground is what i need.
So, any recommendations gents?
Cheers
ice.
icedfusion is offline Find More Posts by icedfusion
Old Nov 22, 2012, 02:53 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
YAY! printer got upgraded today. I can now go down to 0.15mm resolution! (whereas previously I could only go down to 0.2mm) so once again, It has the finest resolution of any sub 9000 additive extrusion type printer! I suspect no one cares (or even knows what im on about) but im happy as all heck and had to tell someone, the missus just says "thats nice dear" :P
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Nov 22, 2012, 03:15 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, High Wycombe
Joined Mar 2001
nice one CJ
Can't wait to see your set up on Sunday
mudlark is offline Find More Posts by mudlark
Old Nov 22, 2012, 03:27 PM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
CJ, you are more geek than I can ever be. I salute you!
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Nov 22, 2012, 04:16 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
CJ
Haha I get that off the missus too!
Eesh!
Im guessing the resolution is how fine you can print?
Old Nov 22, 2012, 04:33 PM
Joined Jun 2007
Yeah, basically it's printed in layers, like an ink jet printer, it'll print one layer, but instead of spitting it out and grabbing a new sheet of paper, it moves the print space down and does another layer. Imagine the resolution like little cubes that build the piece up (like tiny Lego bricks) that are 0.15mm along each side.
@ Wayne, I'm a certified combustion, electrical, microelectronic, physics and chemical engineer with an RC plane hobby, an Xbox 360, a Wii (though that is the Missus), a Playstation 3 and a 3D printer, I challenge you to find a bigger geek!
CJ
Old Nov 22, 2012, 04:35 PM
blackbrabus is offline
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
CJ
getting closer to a perfect sphere.....one day.
blackbrabus is offline Find More Posts by blackbrabus
Old Nov 22, 2012, 04:36 PM
Joined Jun 2007
Cheers
ice.
Get the boscam, get some pliers or a Newton dispenser (hammer) and remove the antenna to fit a good one (inverted Vee/cloverleaf/Huge windmill) .
CJ
Old Nov 22, 2012, 04:38 PM
Joined Jun 2007
A bit of sanding of RCM's reaper dome and it would be near as damn perfect! All geared up to do the belly drop P&T mount now, oh and in answer to Mudlarks suggestion of counter weighting, there just isn't the space, and I'd rather not add the weight, so ill do the only thing you can do in the absence of a counter weight, it will be counter sprung :P. Also the drop down hinge mechanism will overlock in both directions to save on servo stress.
CJ
Old Nov 22, 2012, 07:22 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Dave Drove my FPV Monster Truck (0 min 11 sec)
we have to race around the running track...can't make it on the 1st though
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Nov 22, 2012, 08:11 PM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Originally Posted by MikeTheCrash View Post
http://youtu.be/KbvSu41js2k
oops
Does that invalidate my insurance??
Honest govna' I didn't see him coming. He just jumped out in front of me!!!
Old Nov 23, 2012, 01:33 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
Joined Sep 2003
CJ
That's nice CJ
rcmonster99 is offline Find More Posts by rcmonster99
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 03:37 PM
Discussion UK to France FPV srjs FPV Talk 95 Oct 11, 2014 01:10 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 03:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
