Old Nov 19, 2012, 09:05 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Class 10 looks to be twice as fast
You guys should test yours as well
mudlark is offline Find More Posts by mudlark
Old Nov 20, 2012, 02:21 AM
DodgeRC is offline
Find More Posts by DodgeRC
Cable ties & ductape
DodgeRC's Avatar
United Kingdom, Wilmslow
Joined May 2011
Nice find mudlark!
DodgeRC is offline Find More Posts by DodgeRC
Old Nov 20, 2012, 02:42 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by JaeDubbya View Post
Has anyone tried connecting a Dragonlink 2 tx to a Turnigy X9 which hasn't had the firmware flashed? I am getting a red flashing light indicating no PPM signal, I have checked the settings on the X9 are set to PPM and double checked that CJ had labelled all the pins correctly, which of course he had.
I don't know if you can change the frame length on the 9x before the firmware upgrade. Have to say that the whole point of the 9x is upgrading the firmware. Get a smartie parts board and the LED backlight from hk too. Fully awesome what you can do with it! But apart from ensuring you are in ppm mode I can't see why it wouldn't work. Can you test it on another radio?
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Nov 20, 2012, 03:14 AM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Originally Posted by MikeTheCrash View Post
Get a smartie parts board...
I've read somewhere that you can use the USBasp leads to install custom firmware?
Old Nov 20, 2012, 03:38 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Originally Posted by mudlark View Post
FYI guys
Been looking at trying to get the best micro sd card card for the GP3B
I have the recommended sd card Sandisk 16g
Tonight I cane across a little test program called H2testw
I tested the card basically write 1g files and varifies.
I got some good speed results see screen capture.
Now to test an 8g class 2 see what results for that one is
Ill check my cheapo cards later - good find Dave, hope you get your tax sorted!
lols
badlands is offline Find More Posts by badlands
Old Nov 20, 2012, 03:52 AM
undefined
Joined Jun 2008
I'm sure you can. I went for the more expensive and simpler version, with control for backlighting and and USB plug in the battery bay for updates and programming.
I'm getting quite good at programming the er9x without using the PC now, so maybe if I had to do it all again I could just use a programmer.
Old Nov 20, 2012, 04:05 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Just been reviewing our posts (trappy gate) as I have passed the fun onto one of my Washington buddies for his amusement.
I have noticed the curiously trappy2 account has been suspended
Old Nov 20, 2012, 04:13 AM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Might have a look at the card then! Trying to save as little time as stress as possible =P
Update: Damn, was only checking shipping and I bought one....ah well! Just can't tell the missus!
Old Nov 20, 2012, 05:35 AM
highviz is offline
Find More Posts by highviz
Joined Mar 2009
True - but don't forget that not all Class 10 cards are equal! - Can have significantly different read /write speeds and still be class 10. Also the method / equipment used to read and write to the card can be the limiting factor when you get to fast cards. Just because the card is capable, does not mean you will be able to access the full performance.
Malc
highviz is offline Find More Posts by highviz
Old Nov 20, 2012, 07:59 AM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
The Class rating defines the minimum speed the card should provide at all times. Operating voltage and temperature also affect the time it takes for a program cycle and thus the overall MB/s. You may get higher than expected write speed indoor but it could be considerably slower at 0 degC outdoor.
It is common for cards (all electronic components in fact) to be graded during production. So even though the come from the same batch they will acquire different class labels depending on the performance. If the manufacturer has excess production of very good ones they may stick a lower class label on them for marketing reasons. You may be lucky to get one of the good ones but it does not mean all will be the same.
Also, if your card reader is a bit slow all cards may appear similar in performance as the reader becomes the limiting factor. The same would happen if you have too many devices on the USB root hub/port thus limiting the available bandwidth.
-Angelos
Angelos is offline Find More Posts by Angelos
Old Nov 20, 2012, 09:34 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
Another FPV specific plane to chose from...
Skywakler 2? by demowayne, on Flickr
Bigger fuse, can take a 12" prop and has plastic clips to break down for transport.
Due December....
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Nov 20, 2012, 10:46 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Due December....
Na
When I get my next FPV plane it;ll be for the states and it will an SSS.
Super Sky Surfer. basically the Bixler2's Daddy.
Old Nov 20, 2012, 11:04 AM
Joined Aug 2011
Na
I'm sorta bored of loads of easy star clones and the 'SSS' is just the same but scaled up, it sort of looks like a glider but not really scale. I prefer the utility look of a plane thats designed to do a job with no care for scale planes. This is why these newer FPV planes like the Skyhunter/New Skywalker and simple wings are of interest to me.
If i go (next interview with the director is tomorrow) i'll rip all the electronics out of some of my planes and start fresh there with new foam. I figure i'll keep one or two built up here for visits home (there should be plenty).
I was hoping the Park Jet would be my 'travel plane' that i could take with me when i go visit different countries but its just too fragile. I need something robust like an EPP/laminate wing but with the size and stability of the Park Jet. My raven is just that little too big to pack. And like most wings it suffers from yaw sawing'
Old Nov 20, 2012, 11:11 AM
Angelos is offline
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
You don't ask too much, do you? Ideally you want a GoPro than can hover on its own and relay digital video directly back!
-Angelos
Old Nov 20, 2012, 11:16 AM
Joined Aug 2011
-Angelos
Could you knock one up?
There must be something out there! Besides, i'm not too bothered about making video with the GoPro's at the moment, i'm just enjoying the experience of building and flying.
When i go see Rob from flying wings next I'll she what he has or can suggest. I know he used to do a Mini Raven but maybe he can knock something up from EPP block that is more delta shaped.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10996 Today 04:35 AM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion UK to France FPV srjs FPV Talk 95 Oct 11, 2014 12:10 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
