Old Nov 18, 2012, 06:01 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
There's life in the Skywalker!
I'm off to the field, lots of new builds that need crashing...
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Nov 18, 2012, 07:15 AM
JaeDubbya is offline
Find More Posts by JaeDubbya
Just put it on the credit card
JaeDubbya's Avatar
Joined Jun 2012
I'm gutted I was up until 4am this morning trying to get my Bixler 2 ready, but I am still about 3 hours away from having it done. It is definitely not FPV friendly compared to the Bixler. Because of the tubes they have added in so you can screw on the wings, you can't get anything down inside the body, so I had to cut a hole in the side to fit everything in. They have also put cheeks to support the battery up in the nose, but they are too narrow to fit my Turnigy 2650 nano tech battery in. Also why if it's FPV friendly did they make the canopy smaller than the Bixler, making it harder to get anything in! Grrr
I can't even fly my quad because I pulled it to bits to put my Eagle Tree OSD and DL2 on and stripped my Turnigy X9 to flash the firmware. I really should learn to work on one task at a time. LOL
JaeDubbya is offline Find More Posts by JaeDubbya
Old Nov 18, 2012, 07:20 AM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
That's why I split mine apart took out the tubes and cut a hatch under the wing.
Also meant I could sort out the battery cheeks to suit.
Loads of space now.
mudlark is offline Find More Posts by mudlark
Old Nov 18, 2012, 07:28 AM
JaeDubbya's Avatar
Joined Jun 2012
Originally Posted by MikeTheCrash View Post
Mine is just taped to the side.
Cheers Mike, if what I have done creates too much drag I may end up just letting the bottom cable drag. This is what I did last night:
I spent hours trying to cut a hole in the side so I could make room for all the FPV gear. It took me ages to cut the sides from the central supports. In the end I attached a razor blade to a ruler and slide it underneath and slowly cut through.
Next job is to cut the cheeks on the inside of the nose so I can get my battery in. I don't suppose you had to do this?
Old Nov 18, 2012, 07:30 AM
Butty is offline
Find More Posts by Butty
Joined Apr 2010
FPV Quad Artemis (2 min 7 sec)
Testing the new Artemis Quad prototype for flyability and video jelloing.
All good so far! Wahooooo!!
Flying with Angelos and me, giving it some welly!!
Butty is offline Find More Posts by Butty
Old Nov 18, 2012, 07:41 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Originally Posted by Butty View Post
http://www.youtube.com/watch?v=fQUHO7mtKSE
Nice
Old Nov 18, 2012, 09:05 AM
blackbrabus is offline
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
Great video butty.
Thanks for the offer to the dirty dozen field I'll take you up on it a little further down the line, I seem to be having some teething problems I need to sort first.
The bixler flies great with all the fpv kit on and I'm very happy with the setup.
However big issue with the VX VR......good solid picture on the ground and with the motor running, however walk more than 20 meters and it loses signal......same in the air.
I fly in a farmer's field in the middle of nowhere so no other interance expected.
I was my very nice CL CP antennas so was expecting much more.
I didn't have the originals with me to see if that helped but I'll do a ground test with those later today I have a theory and would like to see if anyone else think the same......here are some picture......wonder if anyone can spot something that might cause a range issue
Description:
Description:
blackbrabus is offline Find More Posts by blackbrabus
Old Nov 18, 2012, 10:28 AM
Carlos230023 is online now
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Originally Posted by blackbrabus View Post
Great video butty.
Attachment 5311630
Attachment 5311631
Bin the VTx. Was it turned on without an antenna on it at any point?
CJ
Carlos230023 is online now Find More Posts by Carlos230023
Old Nov 18, 2012, 10:33 AM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
Here is my edit of the same flights. The question is... which one is better?
The Train Line (2 min 24 sec)
Angelos is offline Find More Posts by Angelos
Old Nov 18, 2012, 10:35 AM
Joined Nov 2011
Only just got the VTX so I would rather not get rid of it straight away.
Not turned on without antenna at all.
Is there any turn on procedure like my dx6i ect ect.
Not sure if you noticed the silver reverse polarity adaptor on both antennas as my other half ordered the wrong set to match the VTx and VRx....could this be the issue??
Old Nov 18, 2012, 10:38 AM
Joined Nov 2011
https://vimeo.com/53766351
Both very good, I cant pick a best.
bloody close on that one tunnel pass.
Old Nov 18, 2012, 10:54 AM
Joined Jun 2007
A gender bender wouldn't cause that sort of issue, and there shouldn't be a turn on procedure as the frequencies of the two devices are different. Id contact the retailer who sold it to you and quiz them on how to move forward. Sounds like a duff VTx to me unless you've got some contact loss somewhere on the active element pins in the adapters.
CJ
Old Nov 18, 2012, 11:25 AM
Joined Nov 2011
first step is to test with the antenna that came with the VTx........then i'll worry about contacting the seller in China
Old Nov 18, 2012, 12:08 PM
badlands is online now
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Both are fun to watch but i liked your ending Angelos... :-)
So when is this ready for sale?
badlands is online now Find More Posts by badlands
Old Nov 18, 2012, 12:21 PM
Joined Nov 2011
Originally Posted by Carlos230023 View Post
A gender bender
CJ
Love it.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11274 Today 12:16 PM
Discussion UK to France FPV srjs FPV Talk 98 Jul 21, 2016 02:14 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
