Old Nov 01, 2012, 04:28 AM
SouthPawPaul is offline
Find More Posts by SouthPawPaul
Electronics slayer
SouthPawPaul's Avatar
Reading, UK
Joined Jul 2008
Originally Posted by DodgeRC View Post
There is one...
I'm still reading up about this but it sounds pretty awesome so far!
The new GoPro Hero 3 comes with an iPhone (Not sure about android) app, that allows a live video feed straight to your phone with the ability to adjust the settings whilst your at it,
http://gopro.com/software-app/gopro-app
I think this is for short distances for framing up a shot, not for long distance video monitoring. Could be wrong though
Edit:
I've just done some quick research and it looks like it's acheived using the wifi backpack. There are apps for both iPhone and Android.
The range is limited, but further than I thought.
GoPro Wi-Fi BacPac range test (2 min 23 sec)
GoPro Wi-Fi BacPac range test #2 (1 min 57 sec)
SouthPawPaul is offline Find More Posts by SouthPawPaul
Old Nov 01, 2012, 04:34 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by BenLimeClouds View Post
Thanks, looks like a job well done sir! Good thinking! Them booms have much flex? Im guessing under the dome the booms are held with pipe clips and scred through?
Thanks for that
The quad shaft to shaft is 22" booms are 10" there is no flex to speak of when I try to bend them at that length so they will not flex under motor load IMO but will flex and absorb some impact ( I hope) because I WILL crash
The booms are clamped by "compressing" the two 1/4 ply 6" discs ( decks) using 6mm nylon machine screws through the tubes the ply is soft enough to grip the tube very firmly I did elonggate the tube holes slightly to allow me to twist the tubes a couple of degrees
The last three inches of the tubes has some 1/4 ply in the end to stop the "compresion " crushing the tubes ( the ply is cut to is three pieces one for each side of the mounting hole and one between the mounting holes
It weighs 28 oz without the kk2 board which I understand is not to bad for that size by comparing weights with friends wooden quads but i would be interested how this compares to other quads
The electrical conduit came from wicks @1.73 for 3 mtrs ( cheapskates rule OK)
Jeff
Upup is offline Find More Posts by Upup
Old Nov 01, 2012, 06:08 AM
blackbrabus is offline
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
There is one...
Range would be over the WiFi I guess.
I was hoping to hook my phone up to my ground station and have a good quality screen anywhere.
blackbrabus is offline Find More Posts by blackbrabus
Old Nov 01, 2012, 06:14 AM
Joined Nov 2011
Edit:
http://www.youtube.com/watch?v=iLFWlOxcQ94
http://www.youtube.com/watch?v=hBUxe...feature=relmfu
Missed this post but as I thought WiFi....not really what I was after.
I just wanna use my phone screen as a monitor.
Old Nov 01, 2012, 06:29 AM
DodgeRC is offline
Find More Posts by DodgeRC
Cable ties & ductape
DodgeRC's Avatar
United Kingdom, Wilmslow
Joined May 2011
A noob question, but what would the chances be of rigging a different antenna/power to the BacPac?
DodgeRC is offline Find More Posts by DodgeRC
Old Nov 01, 2012, 06:35 AM
Western Stalwart is offline
Find More Posts by Western Stalwart
United Kingdom, England, Byfleet
Joined May 2012
Originally Posted by fpvnick View Post
Mark your not to far from me then my brother used to work in Byfleet
Nick
Originally Posted by flylite View Post
Hows Richmond park for you?
I did a LOS flight in Richmond Park a couple of weeks ago on a Sunday. They were a couple of FPVers there but they were packing up. One had a new FPV plane but thnk they had troubles launching and took the nose off it I think.
Be good to meet you guys. I also fly at the old Wisley airfield off the A3. There is a club who fly there on a Sunday so I avoid that time so I'm not treading on there toes but they said they can't stop me flying here. Maybe we could also meet there one Saturday.
Cheers, Mark
Western Stalwart is offline Find More Posts by Western Stalwart
Old Nov 01, 2012, 07:42 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
Cheers, Mark
You should defiantly meet up with James and Mike at Richmond, Its a great place to fly and those guys can help loads. James gave me my first LOS fixed wing flight there and also let me fly his FPV EZ* before i found my local field and the Dirty Dozen.
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Nov 01, 2012, 07:58 AM
Joined Aug 2011
Cj:
will this do?
Board Spacing by demowayne, on Flickr
Old Nov 01, 2012, 08:04 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Originally Posted by brucey View Post
Hey CJ,
Your printer must be flat out and red hot! Can I add an order to your ever growing list? I'm after a mount for my ezuhf to my futaba 9c in black please.
Ill put it in the print que.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Nov 01, 2012, 08:07 AM
Joined Jun 2007
Originally Posted by Wayno Complaino View Post
Cj:
will this do?
Perfect, thanks wayne, What hole size (Fixings) do you want? M2/M3/M4 bolts im guessing.
CJ
Old Nov 01, 2012, 08:53 AM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Edit:
Just a quite note, this is the GoPro HERO 2, I think the 3 is majorly improved,
Old Nov 01, 2012, 12:19 PM
Joined Aug 2011
CJ
M3 ta.
Old Nov 01, 2012, 02:32 PM
Electronics slayer
Reading, UK
Joined Jul 2008
The signal range is determined by the universal wifi backpack that is used for video linking, not the camera.
Old Nov 01, 2012, 02:35 PM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
I though the same especially since my Cinemizer goggles connect to the iPhone. But I was told there is a lot of delay on the video playback and it is not usable for flying on that video feed.
-Angelos
Angelos is offline Find More Posts by Angelos
Old Nov 01, 2012, 03:11 PM
JaeDubbya is offline
Find More Posts by JaeDubbya
Just put it on the credit card
JaeDubbya's Avatar
Joined Jun 2012
I've also heard there is a slight delay in the picture. Not bad for framing shots etc, but not very good for FPV. Plus the range limitations will be a major issue if you are flying.
JaeDubbya is offline Find More Posts by JaeDubbya
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10803 Today 07:50 AM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 02:37 PM
Discussion UK to France FPV srjs FPV Talk 95 Oct 11, 2014 12:10 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 02:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
