Old Oct 22, 2012, 01:44 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Hiviz, I almost replied! But wanted to see if could think of other options!
I think if you want OSD with mag and baro on cheap your choices are real limited.
Multiwii plus mobidrone OSD would give you what I think you need easiest. Also probably Rusduino OSD, but am less familiar.
Drop me a pm if want to chat further and we'll take it offline to email.
Shikra is offline Find More Posts by Shikra
Old Oct 22, 2012, 02:04 PM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by mudlark View Post
What's up with the KK2?? just about to start setting one up on a hex spider
I could not get it to stop rapid beeping on connecting the battery after several attempts I tried calibrating the esc from the KK2 then the screen went blank ,screen back light was on but that was it
Read the thread there is some weird stuff going on with it some get kk2 that work amazing some get crap
I think it is HK qc at fault because the problems are wide ranging
jeff
Upup is offline Find More Posts by Upup
Old Oct 22, 2012, 10:11 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, High Wycombe
Joined Mar 2001
cheers for the heads up.
I'll let you know how I get on with my two
mudlark is offline Find More Posts by mudlark
Old Oct 23, 2012, 03:42 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
time for a video from last weekend, the conditions were perfect.
I hope you enjoy...I know I did
frolicking in the clouds (0 min 0 sec)
rcmonster99 is offline Find More Posts by rcmonster99
Old Oct 23, 2012, 05:07 AM
SouthPawPaul is offline
Find More Posts by SouthPawPaul
Electronics slayer
SouthPawPaul's Avatar
Reading, UK
Joined Jul 2008
Originally Posted by highviz View Post
Thanks Paul - That has occupied a few hours reading into it!
I think I would be happy enough assembling the hardware, but I have very little experience of compiling code - just a bit of configuring of other peoples work, such as commenting out lines etc. It looks like Dennis is using the GPS data at present and there is nothing in place to read separate baro / magnetometer. I found the sample code on the coolcomponents page for the individual sensors, but would be at a bit of a loss on how to integrate that with the DIY OSD code. - Any help on that would be much appreciated.
PS Greenham flyable at this time of year - if you fancy meeting up there sometime.
Malcolm
Malcolm I'm not quite sure about integrating those components into the desing, but a post on the thread may yield and answer from Dennis or one of his knowledable followers.
I'd completely forgotten about Greenham being available again. A fly there together would be great.
SouthPawPaul is offline Find More Posts by SouthPawPaul
Old Oct 23, 2012, 05:38 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Now this is what I need
DeX Mini Quad Crash Test (7 min 10 sec)
Jeff
Old Oct 23, 2012, 06:23 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
Spent lastnight setting up the naza and GPS on my hex has any one else had issues with the connection to the pc dropping in and out? Don't know it it's a bad connection in the lead or connections , laptop not playing nice , or Internet connection dropping out and ideas guys?
Inhave got it more or less set up only thing that I can't sort out ATM is the motors spin as soon as its armed no matter if inhave the motor setting on low recommended or high.
fpvnick is offline Find More Posts by fpvnick
Old Oct 23, 2012, 06:50 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
http://vimeo.com/51951048
Jeff
This'll keep you fit
Frank
http://www.youtube.com/watch?feature...&v=H0qfgBeb35Y
frank48 is online now Find More Posts by frank48
Old Oct 23, 2012, 07:06 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
I hope yours are OK I have another on its way as I speak BTW did you buy the flashing USBASP lead from HK
Keep me in the loop when they work they look great
Jeff
Old Oct 23, 2012, 07:12 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by frank48 View Post
In my dreams
so I have built this human powered heli .... thats useful how far can u go in it........... about 5 inches.......... oh
Old Oct 23, 2012, 07:43 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Hi Nick.
As for the motors running that weird have you calibrated all the channels??
All stick positions should be neutral. Naza does not care where they are set the next time you power up.
Are you coming Saturday (indoors) if you are then bring it along and we can figure it out. Also bring the lead and laptop if you use a laptop to set it up. I can bring mine to try so we could figure that one out too.
Old Oct 23, 2012, 07:45 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Jeff
No I haven't
To be honest I haven't kept up the the KK2 thread for a while. I take it there is an update I need to load?? Probably got a lead.
Old Oct 23, 2012, 08:30 AM
highviz is offline
Find More Posts by highviz
Joined Mar 2009
Hi Nick - Not had any problems maintaining connection on mine while setting things up. - I know that does not help you though ! Could be any of the things you suggest..
The motors will always start to spin once you arm them. That's just the way they do it. The high / low/ recommend settings are just to adjust the rpm point in case they don't run smoothly or a motor or two fails to start. (Can happen with the lower settings sometimes)
If you are in 'intelligent' mode and either GPS or Atti, they will stop again if you don't increase the throttle stick within 3 seconds. (Then you have to re-arm) In Manual mode they will keep spinning unless you move Tx sticks to bottom corners of travel ie manually dis-arm.
Malcolm
highviz is offline Find More Posts by highviz
Old Oct 23, 2012, 10:24 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
No I haven't
The latest ( as far as I know ... u have to be careful on here is 1.2 but there are all the other "after market" FW plus if your board goes blank there is no where to go I was confident I would not need one .... wrong!!! I am hoping a re flash will jump-start my existing board back into life ( live in hope die in despair I think ) got to try it
Mind you what I know about electronics you could write on a grain of rice
Jeff
Old Oct 23, 2012, 10:52 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Nick Malcolm's right. Motors do spin up on start but I assumed that they kept going. More info.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
For Sale FPV Stuffs UK QUIKSILVER Aircraft - General - Radio Equipment (FS/W) 19 Jan 31, 2016 03:37 PM
Discussion UK to France FPV srjs FPV Talk 95 Oct 11, 2014 01:10 PM
Discussion can we have a uk section in the for sales thread please? kieran3008 Site Chat 28 Apr 17, 2014 03:13 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
