Old Sep 29, 2001, 07:55 PM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
GWS 10 x 4.7 prop gives more thrust than APC
Using 3 x 800 Tadrian Li battery with nominal 9V and a GWS DX-A motor I got:
5.2 oz static thrust with an APC 10 x 4.7 prop and
6.2 oz static thrust with a GWS 10 x 4.7
I don't know if it's due to the heavier weight of the APC or the design, but I like the GWS.
My numbers are a bit low since I measured the thrust by tying my scale to the tail of my GWS Tiger Moth. I have fat foam rubber tires with toe in. That gives some drag.
When I measured a 10 x 4.7 GWS prop, same battery and motor on a plane with light, free running wheels I got 6.75 oz thrust.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Sep 29, 2001, 09:58 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
Did the amp draw change as well? That would tell alot about the prop(s) efficiency. Interested to hear, if you had a chance to measure current.
Marcus
MKH is offline Find More Posts by MKH
Old Sep 30, 2001, 12:09 AM
Newark, DE USA
Joined May 2001
No. I didn't measure the current on the Moth and I'll probably never put the APC on again. It's a bit of trouble what with Loc Tite, different washer set up etc. Maybe if I break the GWS and have to replace it I'll put the APC on briefly.
I do have values on the GWS 10x4.7 from the time I measured it on the other plane.
That was 2.0A, 16W, 8V, 6.75 oz. thrust I also got:
9x7" prop 1.9A, 15W, 8V, 4.50 oz.
8x6" 1.4A, 11W, 8V, 3.50 oz. all GWS
In looking at the data I see that I also measured thrust of a 9x7" GWS on the Moth. I got 4.5 oz. The same as on the "free wheeling" plane. I guess I have some experimental error.
RB
I had everything in columns, but the BB software throws away more than one space and doesn't allow the use of tabs.
Old Sep 30, 2001, 08:24 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
It is not uncommon for two props from different manufacturers with identical dimensions to have different characteristics due to the airfoil design of the blades. For instance, one can have higher static thrust while the other may produce more thrust when unloaded in flight. Also, a prop that provides less thrust can provide more airspeed, which may or may not be more important depending on the particular application. So basing prop decisions on static thrust alone may or may not get you the best prop for the flight characteristics of a particular aircraft.
Personally, I have no problem with the larger (10-inch and higher) GWS props. However, the smaller GWS props (9-inch and lower) are fragile. I broke a bunch of 9x7 GWS props in relatively soft grass landings on my GWS Tiger Moth. I've since gone exclusively to the use of 8x6 and 9x6 APC props on my TM and have yet to damage one. I have not tested static thrust on any props because I am more interested in how they fly than how they test, and don't want to be misled by static thrust figures that may or may not relate to flight characteristics. Both the 8x6 and 9x6 APC props give fine performance on the TM, and I still haven't decided which one I like best.
Slowflyer props are cheap enough that it makes sense to me just to buy many different sizes and try them all in the air to see how they perform. Those that don't work on one of your current aircraft will probably wind up being useful on a future one.
Dave Hederich is offline Find More Posts by Dave Hederich
Yippee! GWS EDF55 will be 9% more thrust than Varsa55 at 130W! GWS4CEO GWS (Grand Wing Servo) 497 Aug 04, 2009 01:50 AM
Question is there a good cd motor for turning a 9 x 4.7 prop booger Power Systems 7 Dec 16, 2004 10:59 PM
10 x 4.7 prop on TM yodasands Parkflyers 4 Dec 16, 2003 08:23 PM
WTB: Lite Stick Orange 10 x 4.7 Props and ... Jamie- Aircraft - Electric - Airplanes (FS/W) 0 Jul 28, 2001 09:56 PM
How noisy is Speed 400, 4:1 gear, 11 x 4.7 prop? Red Baron 47 Electric Plane Talk 13 Jul 18, 2001 11:11 PM
