Old Jun 09, 2010, 02:41 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
2.4ghz hard deck ?
With my soon coming 400mhz UHF system the problem of flying at low altitude over long distances from a radio point of view are pretty sorted.
The limiting factor will be getting a reception from my video tx
Im using a 2.4ghz 500mw tx with a circular 8db patch
What sort of low altitudes will be possible at given ranges where the video will still work fine ?
Coyote64 is offline Find More Posts by Coyote64
Old Jun 09, 2010, 02:57 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Thomas recommends 1m of altitude for every 10m from home. Unless you live in a completely flat part of the world with not trees or buildings, don't expect to be flying at 5m off the deck when you're 5km out.
lovegroove is offline Find More Posts by lovegroove
Old Jun 09, 2010, 04:25 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I can't speak to 2.4Ghz video since I don't use it any more, but I've had solid 2.4Ghz
R/C control way way below 1:10 ratio. I actually think 1:10 is very
conservative, perhaps by as much as a factor of 5 to 10.
Thing is, 2.4Ghz is very direction, and being high frequency it does not have
a really huge fresnel zone. Also 2.4Ghz video antennas don't generally need or benefit
from being near the ground like 900Mhz and to a lesser degree 1.3Ghz do, so if you want
to fly low and far away, just elevate your Rx antenna/s.
ian
Daemon is offline Find More Posts by Daemon
Old Jun 09, 2010, 04:59 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Right i see, most my flight will be conducted from a point 803m above sea level with my flying space in front of me dropping to sea level ( most of the time )
What sort of height am i looking at with my antenna tracker ( coming soon ) / patch setup to get most effective performance ?
Old Jun 09, 2010, 11:39 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
ian
I second this, in my recent range tests I got +5km 2.4GHz RC at ground level with an altitude difference of 40m between Tx and Rx, and direct visual between them.
renatoa is online now Find More Posts by renatoa
Old Jun 09, 2010, 11:54 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
So a lot better than i thought then i figured thn, ill start off conservative and take it steady
New Product Micro Cessna 2.4Ghz Airplane w/ 2.4Ghz Ready-2-Fly CrashingDutchman Scratchbuilt Indoor and Micro Models 22 Jul 14, 2010 12:47 PM
Sold Hitec Spectra 2.4GHz Module & 2-Optima 7Ch 2.4GHZ receivers $105 shipped flyingrandy55 Aircraft - General - Radio Equipment (FS/W) 3 Dec 02, 2009 12:56 PM
Sold HBFP 2.4Ghz Like new JUST RELEASED & VERY hard to find Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Mar 07, 2009 08:15 PM
Discussion What's better? Honey Bee CP2 2.4GHz vs Walkera 1#B 2.4GHz vs Walkera 22#E 2.4GHz phstc Micro Helis 5 Jul 08, 2008 03:04 PM
Tally Ho... X-32A above the hard deck! Kevin Cox Electric Ducted Fan Jet Talk 18 Oct 05, 2001 09:49 AM
