Old Jun 08, 2010, 06:48 AM
samir140 is offline
Find More Posts by samir140
Joined May 2008
GPS V4 expander
I bought a GPS expander from eagletree and I want to use it for my own application.
In the manual they do not mention what each wire is and the baudrate of the gps and protocol it is working on.
Can anybody help?
Regards
Samir
samir140 is offline Find More Posts by samir140
Old Jun 08, 2010, 10:24 AM
samir140 is offline
Joined May 2008
Anybody knows the datasheet for the GPS module used in the V4 GPS?
thanks
Old Jun 08, 2010, 09:11 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi,
The required pinout, from left to right, is:
Power (red wire on our GPS)
Ground
TX (data sent to GPS)
RX (data received from GPS, brown wire on our GPS)
Here is the required programming for the GPS:
* baud rate: 38400, N, 8, 1
* messages: GGA(1hz/5hz/10hz), GSA(1hz), RMC(1hz/5hz/10hz)
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jun 09, 2010, 12:58 AM
samir140 is offline
Joined May 2008
Hi Bill,
I need the module of the GPS used so that I could program the messages at different frequencies.
Old Jun 09, 2010, 11:45 PM
samir140 is offline
Joined May 2008
Hi Guys,
the gps module has GTA010 written on it. Anybody knows which manufacturer does them.
Old Jun 13, 2010, 10:56 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
samir, the GPS is an MTK variant, so most of the MTK specs on the web should work, I believe.
Site Sponsor
Old Jul 08, 2010, 05:28 PM
Mikey G is offline
Find More Posts by Mikey G
Joined Jul 2010
Anybody know why the GPS V4 UTC timestamp is programmed to convert to milliseconds when you upload the data into Microsoft Excel? This is really strange, are they basing the time on milliseconds since midnight? Is there a way to keep the time in UTC?
Mikey G is offline Find More Posts by Mikey G
Old Sep 20, 2010, 06:30 PM
erwinkendo is offline
Find More Posts by erwinkendo
Joined Sep 2010
Any of you know the nominal voltage or current that this GPS needs??
3.3V? 5V?
erwinkendo is offline Find More Posts by erwinkendo
Old Sep 22, 2010, 12:00 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
Mikey, the time in standard wall clock format is also included in the .FDR file. It's one of the last columns in the file.
erwinkendo, the operating voltage for the GPS is between about 3.3V and less than 5.5v.
Site Sponsor
Old Dec 11, 2010, 09:36 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Bill,
Do you have to wait a set time before receiving data from the GPS? I'm trying to interface it with an Arduino and assume I have a lock because the LED is out on the GPS. I confirmed the lock by connecting it to the e-Logger and checking with your software so it seems to have a lock but I don't get any information back from the GPS regardless of the baud rate I set it at. I figured it would be worth asking about possibly waiting at all for values before I move on to another possible GPS. I would prefer this one as it's a 5V unit as opposed to many that are 3.3V.
Thanks!
healthyfatboy is offline Find More Posts by healthyfatboy
Old Dec 13, 2010, 11:10 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hmm, I suspect it is sending data. The only reason it would not is if it has been programmed to send no messages, and our products don't do that. I would recommend hooking up an oscilloscope to the output line if you have one, or perhaps a voltmeter in AC mode will read a voltage between 0-3.3V, which would indicate data is being transmitted.
Site Sponsor
Old Dec 14, 2010, 05:22 AM
Joined Jan 2007
Thanks Bill! I'll try that out and get back to you.
Old Dec 15, 2010, 08:53 PM
Joined Jan 2007
I tried it out again today and was able to see the data on the board. The code I had didn't work but at least I was getting everything in like I was supposed to.
Thanks again!
Old Dec 16, 2010, 04:44 PM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
hey Bill
If I understand correctly, your gps sends a standard NMEA protocol. Does this mean that I could use my MTK GTA010 from another supplier with the E-logger, (baud 38400, 10hz)?
I have the old Eagletree 5Hz GPS, and think it is too large in the plane, so I will instead use it for purpose on earth.
Is there any required programming for the 5hz GPS.
Thanks in advance.
Michael Sorensen
absolute-zero is offline Find More Posts by absolute-zero
Old Oct 10, 2011, 06:14 AM
Retlaw is offline
Find More Posts by Retlaw
registered user
Retlaw's Avatar
Belgie
Joined Jun 2004
#3 The required pinout, from left to right, is:
Ground
? what to do with the 10Hz GPS V4 expander for R/C data logger and V3elogger
I have set the comport to above mentioned baud rate settings
But the output on te comport gives a lot of characters which are not correct
Do I have to sent the messages to the comport to be able to recieve the correct GPS data ( starting GPGGA, etc ... )
Retlaw is offline Find More Posts by Retlaw
Discussion GPS Expander kenai Eagle Tree Systems 5 May 30, 2010 02:37 PM
Sold Eagle tree osd pro elogger v3 gps expander v3 Squatter Aircraft - General - Miscellaneous (FS/W) 2 Nov 27, 2009 09:12 PM
Sold Eagle tree osd pro elogger v3 gps expander v3 Squatter Aircraft - General - Miscellaneous (FS/W) 14 Nov 27, 2009 08:58 PM
Sold Eagle Tree GPS Expander V3, Model GPS-5HZ green66 Aircraft - General - Radio Equipment (FS/W) 1 May 25, 2008 09:28 AM
