Jun 23, 2001, 12:52 AM
United States, MI, Roseville
Joined Dec 2000
I have run twin 6 Volt 400 motors in all my 5 twins I have designed so far.
My first was a twin Mustang.It ran 8-800 cells, and used a 20 amp FMA esc,wired motors in parallel.Even though it was on the edge, it never faultered.Part of the reason is that I use APC 5x5 props,and the motors draw under 10 amps each this way.
All of the following twins(Me 262, Neptune,Whirlwind)have used the same setup without so much as a glitch.My Sportwin was built with an FMA 30,only because I planned to sometime try other , higher performance motors.It , too, has never faultered.These all use 8-800 cells, or 8-1250 cells.I would think 1700 or larger might be pushing it, as they have a little less resistance, and more power getting through the ESC.
To be on the safe side, use an FMA Mini30,and use APC 5x5 props or smaller.Ask anyone who has built a SPortwin if this works, and they will say yes.
I cannot say anything bad about the FMA product.They perform flawlessly!
The reason some of these guys say that setup is pushing it is because they are drawing more amps with the Gunther props,more than the APC's will pull.
MR
