Old Jun 15, 2003, 03:00 AM
swede
swede
Guest
n/a Posts
How to: bending music wire
Before I to start to try to make my own music wire landing gear, I'd like
some tips and info on techiques on how to properly and easily bend it into
shape. I tempted to heat it to make it bend easier.
Swede
David AMA40795 / KC5UH
Guest
n/a Posts
Re: How to: bending music wire
The straight and simple answer is to go purchase a wire bender. Dubro
and K+S make wire benders, as do some other mfgrs. That way, no heat
is required, which reduces the temper of the wire.
David
On Sat, 14 Jun 2003 20:06:01 -0500, swede <poker_run01@yahoo.com>
>Swede
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
If you use heat you will destroy the temper of the wire and it will not hold
its shape when you land.
Buy a purpose-built wire bender such as DuBro or K&S versions.
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
"swede" <poker_run01@yahoo.com> wrote in message
news:BB1130A9.2E7E0%poker_run01@yahoo.com...
into
> Swede
Old Jun 16, 2003, 03:00 AM
The Natural Philosopher
Guest
n/a Posts
Sadly, it bends easy enough already. Leastways the stuff I get nowadays
does :-(
Gone are the days when it would splinter on a sharp bend....
> Swede
D
D
Guest
n/a Posts
Hi Swede -
The wire bending tool is good advice; I made my own quick and dirty tools
by drilling holes a little larger than the wire near the end of a piece of
steel tubing. By clamping the wire in a bench vise between two pieces of
flat steel, then using my bender, I cranked out a very nice set of landing
gear.
Things I leared:
Do NOT use heat! It may change the temper of the wire. If you use steady,
even pressure with a bending tool, you'll get a nice sharp bend without
breaking the wire.
Do NOT use a hammer! It will just break the wire.
Mark the wires identically prior to bending either piece, and/or jig
everything, so you get two identical pieces.
into
> Swede
Jerry L. Gubka
Jerry L. Gubka
Guest
n/a Posts
If you do wish to use heat, go here and read this:
http://www.sailplanes.com/musicwire.htm
Live long, and prosper
Jerry L. Gubka
gray-bearded tramp miner looking for work
(experienced mine planner available)
http:/home.attbi.com/~jlguru/JLGHome00.htm
into
> Swede
Mike Norton
Mike Norton
Guest
n/a Posts
Sometimes you want two mirror-image pieces. Don't ask how I know.
-- Mike Norton
"D" <a@b.c> wrote in message news:9x_Ga.149$KW2.23299@news.iquest.net...
> Hi Swede -
> gear.
> Things I leared:
steady,
> breaking the wire.
like
> into
> > Swede
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
While technically correct, that is the HARD way to do it. The K&S benders
will make just about any bend you want without heating and cooling.
Paul McIntosh
"Jerry L. Gubka" <jlguru@attbi.com> wrote in message
news:1w%Ga.158803$d51.227301@sccrnsc01...
> Jerry L. Gubka
like
> into
> > Swede
Bousch
Bousch
Guest
n/a Posts
Buy a wire bender.
into
> Swede
Ralph Henrichs
Ralph Henrichs
Guest
n/a Posts
I've bent 1/4" music wire 90 deg. cold with a vice & hammer, it has held
up a 13 lb. plane for 6 years with many not so good landings.
> Paul McIntosh
>>Jerry L. Gubka
> like
>>into
>>>Swede
Old Jun 17, 2003, 03:00 AM
Philip McNamara
Philip McNamara
Guest
n/a Posts
The K&S Mighty Wire Bender is a superior tool, as the previous posts
have indicated;
I've owned one of the K&S units for years,
and have also been pleased with Hobby Lobby's wire bender, which I
bought more recently: http://www.hobby-lobby.com/tools.htm
It's salient feature is a unique locking clamp that holds the work
firmly in place, avoiding slippage as the wire is formed.
Phil
Bending Music Wire Tommy D Scale Kit/Scratch Built 6 Oct 14, 2004 09:34 AM
How to solder music wire? SlowRider The Builders Workshop 25 Dec 12, 2003 09:12 AM
How do you bend thick music wire? sizam Parkflyers 6 Nov 27, 2002 07:27 PM
How to straighten out music wire? ferradas Electric Plane Talk 8 Oct 29, 2002 04:30 PM
