Old Dec 17, 2010, 07:42 AM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
Originally Posted by lusitanv View Post
New champ owner subscribing to the thread
Welcome...your homework for the weekend is to read all 96 pages and take notes. There will be a test...the next time you fly...lol.
The Hog Pen is offline Find More Posts by The Hog Pen
Old Dec 17, 2010, 10:13 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by big_poppa4904 View Post
Oops, meant to post this question earlier.
Speaking of "throw position". Which holes are good for the Champ? To maneuver aerobatics without sacrificing ease of flying?
I believe stock both elevator and rudder was on very outer hole. Whats that mean? Most or least throw? And what would be the cons of the "most" throw?
The Cons of moving the Pushrods "In" on the horns is you can't hammerstick the plane. Small stick movements result in large plane movements and you fly with the tip of your finger and not your whole hand.. but it does make aerobatics possible.
A downside to this is aeroloadings on the control surfaces increase and the elevator or rudder can break near the control horn. I reinforced mine with clear blisterpack plastic between the horn and control surface foam.
UNGN is offline Find More Posts by UNGN
Old Dec 18, 2010, 08:44 PM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
DANGER WILL ROBINSON DANGER!!!!
I think I may have found a problem with early battery failures and maybe the tx overheat problem.
Walked in the shop and right before I hit the light switch I could see a tiny orange glow from the bench. First thought was "Dang it I forgot to turn the tx off". Hit the lights and picked up the tx, and nope it was turned off.
WTH! And then I caught it. In the gap on the right side of the throttle switch was a tiny orange light glowing.
Turned the tx on and the light kept on glowing. Pulled one of the batteries and it went out. Reinstalled the the battery and the light came back on and I heard 4 very faint beeps from the tx.
I tried this a couple of times just to be sure and it does it every time.
Snapped a shot of it so you know where to look.
Something is staying on, on this tx, and would surely drain the batteries over time. Might just be a boo boo in the circuit board that's not cutting power.
I'm going to email Horizon and see what they say, but in the mean time you might want to take a look at the tx on yours.
Glacier Girl is online now Find More Posts by Glacier Girl
Old Dec 18, 2010, 08:48 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I had something similar happen to a Eflite RTF TX about a year ago. I hadn't used it in weeks and it just started beeping (I guess low battery voltage). It had been off the whole 2 weeks.
From then on I never leave batteries in RTF TX's.
Old Dec 18, 2010, 09:13 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
I have a few spare stock Tx's if you need one - let me know. Mine don't do that though:
http://www.rcgroups.com/forums/showthread.php?t=1317798
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Dec 18, 2010, 09:42 PM
Kamikaze Ace
USA, FL, Lakeland
Joined Jan 2010
Thanks for the offer Sentry.
I'll wait to see what Horizon says first. Hopefully they'll handle it, otherwise it might look bad for them.
I got this one yesterday, direct from Hobby Town/Horizon as part of their "Hobbyist of the Year" contest which I'm in the running for.
Wouldn't look to good them giving out faulty stuff to the contestants.
Other then that, my Champ showed up perfect, not a bubble to be seen on the wing stickers.
It's already nearing completion of a lot of the mods I've learned from you guys.
So far custom 3 GWS lite wheels, opened up the air intake and added baffles to redirect the airflow to the motor and brick.
Applied chip tape to the cowl, great stuff, I use it on my big birds, it's the clear tape you see on cars on the fenders and rockers to prevent stone chips. Works great to prevent scrapes on my big planes cowls and wing tips, so I figured why not on this one. Even used two small pieces for the gear flarings so they don't dig into the foam.
Added bungees to the landing gear made out of real bungee chord.
Instead of the wing struts I decided to go with a CF wing spar. Used two of the PZ Cub clips to hold it to the wing tips. Worked great, no tape or glue to be seen.
Speaking of tape, I managed to get mine off without removing the paint. I'm going with a lip catch and rare earth magnets to hold mine together.
Also added CF spars (ex micro Cub control rods) to the outside of the H stab and elevator, and got really lucky and was able to sneak two pieces in the rudder, up where they bend and down by the control horn, Worked em right between the coats of paint through the foam.
Moved the tail wheel forward. Lubed the gearbox and motor. And used a pencil to apply graphite to the gearbox and servo gears to keep em quiet and working smooth.
And so far so good it's balanced right at 28mm.
Thanks again guys for all the tips, I just know I'm going to love this bird.
I'll post a couple of pics when I wrap it up.
Old Dec 18, 2010, 09:43 PM
monboy10 is offline
Find More Posts by monboy10
Enough Power? -NEVER ENOUGH!
monboy10's Avatar
North-Eastern Saskatchewan, Canada -Eh?!
Joined Apr 2008
the eflite tx that came with my blade Mcx has that too.
monboy10 is offline Find More Posts by monboy10
Old Dec 18, 2010, 09:58 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
The Champ didn't use bungees, they had oleo strut main gear.
livonia bob is offline Find More Posts by livonia bob
Redcoat is offline
Find More Posts by Redcoat
Southern Ontario
Joined Nov 2010
Can you explain to this newby what you did to lube the gearbox and motor? Do I understand it right that you just used graphite?
Redcoat is offline Find More Posts by Redcoat
Old Dec 18, 2010, 10:33 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Quick update on my mods:
New Tenergy 500mah battery + UM P-51 motor = WIN
I still havent gotten my 5043's, but with the stock prop, and new goodies, I went flying twice today with it, and never charged it up. I got at least 30 minutes of mostly wot flying, and The battery never showed any signs of depleting itself...I bet I could take it right out and fly another 10-15 minutes. The motor and battery balanced perfectly...it was actually more stable with the heavier battery than when I tested it early this morning with a little 150mah. I did have to move the throws back to "wuss", because the motor is too poweful for the short control throws, and made even the slightest movements too snappy, and the plane was twitchy.
Old Dec 18, 2010, 11:51 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Indoor-fly fun
Flew my Champ w/P-51 motor/5043 prop/Hyp 180 cell at our indoor session tonight. I had fun flying lazy circuits just inches off the deck @ 1/4 throttle. I tried some aerobatics, and was pleased to find that she can now hang on the prop for a bit. Loops were effortless, and hammerheads & stall-turns looked cool. With some down-trim, she can really get up & go @ WOT. With the tundra tires, she had no problem negotiating the AstroTurf, and takeoffs were short. She can climb @ 70-80 degrees with no problem. With the Hyp 180s, I was getting ~8 min flights to the 80% discharge point.
I love this plane with the increased power.
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 19, 2010, 12:38 AM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
I would say the gearbox nor the motor would need lubing. As you may think they would, they weren't designed for lube. I would even think that would cause friction and make them wear out in my op.
big_poppa4904 is offline Find More Posts by big_poppa4904
Old Dec 19, 2010, 01:35 AM
Go Ugly Early
Azle, TX
Joined Oct 2010
Joel
That's awesome, Joel...I'm seeing the same things here, with the stock prop, no less. You gotta try this Tenergy 500mah...it feels like I can fly all day, and the slight bump in weight actually balances the power. I was taking off almost from a stand-still with a little elevator, and cruising at 1/3 throttle. Climbing was effortless!
*damn...I sound like a rep...
Old Dec 19, 2010, 02:17 AM
Joined Nov 2010
Does anybody have some good close-up pictures of the Tenergy 500mah battery installed on the Champ?
Maybe a how-to on getting it to fit.
And how are you guys charging these batteries? As I have the Celectra charger, I doubt it would fit
Old Dec 19, 2010, 02:26 AM
Go Ugly Early
Azle, TX
Joined Oct 2010
Gimmee a sec...
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 02:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 01:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 07:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 02:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 11:01 PM
