Old Dec 13, 2010, 03:27 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Originally Posted by The Hog Pen View Post
...or...don't crash it...
...sorry...it was there.
A laudable goal, but the several T-28 outline holes punched in the snow around my house attest to the difficulty of achieving it...
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Dec 13, 2010, 04:27 PM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
Dave
lol...as for me...the nose on my Champ can damn near play the polka as it flies.
The Hog Pen is offline Find More Posts by The Hog Pen
Old Dec 13, 2010, 06:51 PM
CNY_Dave is offline
Joined Sep 2010
Several full-throttle straight-down 20-50 foot descents onto pavement on my end...
Dave
Old Dec 13, 2010, 07:50 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Dave
Geez, Dave...that's a lot of time to recover...you drinkin' and flyin'?
Old Dec 13, 2010, 09:48 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Brain-fart here...HZ sent me a new brick...installed it, bound it, goodto go. Then I had a thought...is there any way to tap into the existing rudder servo, and reinstall my old brick, and use the power from that to actuate the old, still functional servo? I can find a place to install it...and it would make a cheap modification to be able to run ailerons. One would think it would be as easy as splicing the red and blue wires...but I don't know enough about circuitry to know all the ins and outs. Anyone ever thought of something like this?
What about "hard-wiring" in one of these:
Old Dec 13, 2010, 10:25 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Nope, won't work.
What's wrong with you brick? is a FET burned, or does the servo just not work?
UNGN is offline Find More Posts by UNGN
Old Dec 13, 2010, 11:08 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Originally Posted by UNGN View Post
Nope, won't work.
One of the servos doesn't work...acts like it's bound up, and struggling. I was told it's probably the FET, even though they don't look damaged. I can only spin the gear about 1/3 turn before it binds.
I'd order the new chips, but my soldering skills aren't to the point where I can do that kind of detail.
Old Dec 13, 2010, 11:50 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If you have a #000 Phillips screw driver, you can undo the Servo rack, press out the motor with your finger tip. Clean the resistive track with a pencil erasure or Q-tip with alcohol. Swap rack sides to see if its the rack.
If its not the rack, the motor could be weak. You can buy a new servo racks/motors at your LHS part number EFLH1066. You'll have to solder the motor wires to the old ones (easier than soldering to the board), but its not that hard.
Every bad FET brick I've even had gets fingerburning/foam melting hot on the bottom. If it doesn't get hot, it might not be a FET.
Old Dec 13, 2010, 11:56 PM
LndShrk is offline
Find More Posts by LndShrk
Washington
Joined Oct 2010
Champ Mods.
Here are some pictures of My Champ.
I have added the oversized tires on it now. I really like them.
The lights I built. I just tapped into the battery leads for power.
the P-51 with a 240 MAh 20c battery pack turns the GWS 4530, 5030, and the 5043 very well.
Each prop flys the plane equally well. I like the 4540 for neighborhood flying as it has a significant more punch to really turn the plane on a dime.
The 5030 works very well. This is the prop I have decided I will use when I mount the camera to it. For long flight times and lazy bird touch and goes I go with the 5043. It just feels better at slow and low flying.
Hope to get some flights in between all the rain..
LndShrk is offline Find More Posts by LndShrk
Old Dec 14, 2010, 12:25 AM
Go Ugly Early
Azle, TX
Joined Oct 2010
Thanks for that...I'm going to pull the servo rack and check it...like I said, it sounds like it's binding up...like it wants to move.
LS...LOVE what you've done with your Champ. Last week, I ordered a 5000mah lipo, UM P-51 motor, and some GWS 5043's. Everything shoud be here in time for a weekend/Xmas break build. I also realy like the fat tires. I prefer leaving the LG on, myself...
Old Dec 14, 2010, 02:08 AM
LndShrk is offline
Washington
Joined Oct 2010
Thanks.. The Champ was my first plane. So the only original parts left are the brick, Tail wheel, and the wing..
Everything else I have had to replace.. Now that I have it setup I will get out the airbrush and give it some adjustments..
Old Dec 14, 2010, 07:03 AM
CNY_Dave is offline
Joined Sep 2010
A buddy's champ had a similar problem- a biff pulled on a pushrod and actually bent some gear teeth- was invisible without a magnifier, they did straighten out with a sharp screwdriver to reform them.
Or does the servo turn freely by hand, battery out?
Dave
Old Dec 14, 2010, 07:05 AM
CNY_Dave is offline
Joined Sep 2010
I tend to have to fly in gusty winds- if you are pointed down and a gust hits from the front, you ain't pullin' out...
And a few maneuvers that didn't come off quite right. If you are low, and inverted, and just as you apply full down elevator to lift the nose a bit a gust comes along andf flips it upright just then...
Dave
Old Dec 14, 2010, 07:46 AM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Regarding cleaning the servo track: I've seen several posts where folks have suggested cleaning the track w/ a pencil eraser. I assume by "track" you mean the white plastic device that holds the slider that moves the push rod.
Question: HOW do you get a pencil eraser in there??
Even if I remove the track from the board, it's still too narrow to get something inside....
Thanks!
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Dec 14, 2010, 08:15 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Thanks!
The track is the resistive strip on the circuirt board. It appears to micro spark and get carboned up (or that's just dirt).
The rack is the white plastic worm gear holder you have to take off to get to the track.
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 02:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 01:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 07:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 02:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 11:01 PM
