Old Dec 08, 2010, 11:05 AM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
previous damage is a definite probable cause. As I got to looking my tail needs replacing too. So I will order a wing and complete tail.
But for the glue part, does the foam safe CA work good? Do I need the "Activator"??
As for the gorilla glue, how long does it take to dry? As I dont care for putting "temporary tape" on my plane as it will take paint off. And does the gorilla apply to BOTH pieces to be glued? or just one? His description does not describe that
Also, what about epoxy? Anybody ever try using epoxy for repair? Its automatically foam safe
big_poppa4904 is offline Find More Posts by big_poppa4904
Old Dec 08, 2010, 12:09 PM
WAM74 is offline
Find More Posts by WAM74
Ridgecrest Calif
Joined Nov 2010
You sure about that? I've had it eat thru a styrofoam cup I was mixing it in.
WAM74 is offline Find More Posts by WAM74
Old Dec 08, 2010, 12:31 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by The Hog Pen View Post
I wouldn't even bother removing the wing. You might grab another one to keep as a spare...maybe replace it when your wings actually vaporize.
I have two Champs, both flying great with broken/repaired wings.
I also have two pristine replacement wings, still sitting in their boxes because the repaired wings refuse to break again! They do indeed seem to be stronger than they were originally.
A little CA and tape can work wonders.
pugsam is offline Find More Posts by pugsam
Old Dec 08, 2010, 12:41 PM
Joined Nov 2010
WAM74, im not 100% sure, but I believe it is. I have my broken wing to test.
How long did it take to eat through your cup?
Old Dec 08, 2010, 01:12 PM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
Foam safe CA is decent...it flexes very little. The activator crap makes it get hot, and dries VERY hard...with little or no flexion...that's pretty much the definition of "brittle". Gorilla Glue is VERY flexible, and VERY strong. These 2 properties combined, IMO,make it the best "long term" fix for a foam plane.
The Gorilla Glue needs only be applied to one side...and then I used blue painters tape to hold everything in place. The blue tape doesn't stick very hard, and won't take the paint off...but it does stick hard enough to hold the wing in place. It tells you on the Gorilla Glue bottle how long it takes to cure...I just let it cure overnight.
The Hog Pen is offline Find More Posts by The Hog Pen
Old Dec 08, 2010, 01:18 PM
Joined Nov 2010
how "hard", if you will, did you have to tape down the wing? Like how long do you have to apply pressure? And says it will swell up and ooze out some, is that just right when you first bond together?
oh and exactly which gorilla glue do I get? That guy said clear, but are they different clears to get?
Old Dec 08, 2010, 01:19 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Also...Big-Pop...don't test ANYTHING on that wing. If you decide to "test" anything on the wing, go ahead and order yourself a new one. You have to preserve the joint between the broken halves...if you eat a big pit into it using the wrong glue, you'll have a very creative repair to make.
Old Dec 08, 2010, 01:25 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
I fit the pieces firmly, and then taped in place. If you mash, and force the two halves together, you'll squeeze out a lot of the glue (and you're not using much), and possibly damage the bonding surfaces. If you try to "hold it til it sticks"...you'll be there all night. Tony was right on...after about 5 minutes or so, the glue starts to swell, and ooze out...but it's not very much...just enough to make a little "scar", so to speak. TonyK's suggestion was to greatly reduce the "scar" by working the oozed out glue back in. I didn't even bother working the glue in...I like the scar, and it affects nothing whatsoever.
Old Dec 08, 2010, 01:51 PM
Redcoat is offline
Find More Posts by Redcoat
Southern Ontario
Joined Nov 2010
Originally Posted by Razors edge 29 View Post
interesting
can you post pics and or vids please if you have any?
See posts 1158 and 1197. They might help.
Redcoat is offline Find More Posts by Redcoat
Old Dec 08, 2010, 02:15 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
Oh...one more thing...Gorilla has a ca glue...it's NOT foam safe. I learned this by testing on the styro insert for the Champ box...not the wing
The regular amber color Gorrila Glue is fine...and dries a wheat color. From a few feet away, it almost looks orangy...but the standard Gorilla Glue is foam safe.
Old Dec 08, 2010, 03:42 PM
monboy10 is offline
Find More Posts by monboy10
Enough Power? -NEVER ENOUGH!
monboy10's Avatar
North-Eastern Saskatchewan, Canada -Eh?!
Joined Apr 2008
interesting
here they are:
micro champ on bigger,better skis (2 min 15 sec)
micro champ skis (1 min 48 sec)
monboy10 is offline Find More Posts by monboy10
Old Dec 08, 2010, 03:47 PM
monboy10 is offline
monboy10's Avatar
Joined Apr 2008
i used epoxy and it worked great! i was flying close to some building with a but of wind and a big gust came and sent my plane towards another building so i did a half loop and didn't have enough time to flip it back over so i went full right stick up and "landed it upside down of some ice. through all of this the epoxy has held strong
Old Dec 08, 2010, 04:48 PM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Is Gorilla Glue the best because you can't get hold of UHU POR? I've got a tube of that which I've used to fix a (non-structural) crack in my Champ - I understand it's designed for gluing foam (and that it's not readily available in the US).
aracer is offline Find More Posts by aracer
Old Dec 08, 2010, 05:35 PM
WAM74 is offline
Ridgecrest Calif
Joined Nov 2010
The salesman I bought my Champ from owns one and repairs everything with white glue. I suspect most anything that doesn't attack the foam will wind up stronger than the foam itself, so it's all good.
One advantage with white glue is when it oozes out, even if it hardens some, you can rub it down with a wet finger or wet paper towel and remove the excess, spreading what's left so thin you can't see it.
As far as strength goes, when I broke my wing in half, I didn't want to quit flying for the day and I put it together with a single piece of scotch tape top and bottom. No glue at all. It was probably 20 more flights before I got around to replacing the wing, which I did, "just cause". Worrying over which glue is best takes up time you could be doing something more important. Like flying...even sleeping.
Old Dec 08, 2010, 06:47 PM
MarksRC is offline
Find More Posts by MarksRC
MarksRC's Avatar
Wellington, Florida
Joined Jun 2004
I use "Formula 560" canopy glue for my 3D foamies and Champ. Drying time to touch is 3 hours and full cure is 24 hours. Its a slow process when building but, worth it. Canopy glue cleans up with water and also stays flexible after it dries.
MarksRC is offline Find More Posts by MarksRC
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 890 Yesterday 12:12 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
