Old Oct 18, 2010, 09:47 PM
iceman88 is offline
Find More Posts by iceman88
Joined Aug 2006
Is there any disadvantage to losing the rubber tip of the prop on the stock prop? I think mine is about to come off cause I inverted stalled at like 8 feet up and hit the dirt hard.
iceman88 is offline Find More Posts by iceman88
Old Oct 18, 2010, 09:50 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
It saves knocking the gearbox lose when you run the plane into stuff.
UNGN is offline Find More Posts by UNGN
Old Oct 18, 2010, 09:54 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Originally Posted by CNY_Dave View Post
If the controls go to neutral and the red led in the cowl goes out, its likely a tx problem (or maybe an esc RF noise issue?).
Dave
I did have it need re-binding the other day to my DX6i.
However, the controls stay in their assigned positions, as I have seen the plane "pulse" during turns, on occasion, with no apparent interruptions to the controls.
SC
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Oct 18, 2010, 10:45 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Originally Posted by Doug Sipprell View Post
I usually get 14 - 16 minutes, but have gotten as much as 20. I don't fly close to the ground, making circles, etc. I fly at higher altitudes, with some closer to the ground buzzing. A hand full of inside loops, wing overs, hand launched. 240 cell works great. I don't use the 160's any more, strictly 240's. Hyperions's are the one's to use, forget about the HK Zippies. Very slight modification to the battery tray to get the 240 cell to fit. Try it, you'll like it!!
RD
Just ordered some 240 mah Hyperions from RCBABBLE
and some GWS 5045 props, and prop inserts from Radical RC
Time to have some fun with the CHAMP
Thanks for the advice everyone, been asking a lot of questions
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Oct 18, 2010, 10:46 PM
iceman88 is offline
Joined Aug 2006
OK, ill probably need a new gearbox then soon...the plane is remarkably well put together and durable for 90 bucks.
Old Oct 19, 2010, 12:17 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by SkyCadet View Post
Hello!
Well, as much as I was sure that this would work, that little motor just cannot turn the blades fast enough to get enough consistent thrust to keep her flying. Even trimming the blades with a dremmel to 4.4", this was barely enough to keep the plane flying other than at near WOT [at least 75% throttle was needed to keep her aloft].
So, Champ#2 will be eventually retro-fitted with a brushless 1S outrunner, and the stock motor will serve as a spare for Champ #1. I'll use the smaller 3-blade with the BL motor for trials, as many small BL motors are lighter than the stock motor, which will aid in balance.
That'll be a bit yet, probably a late fall project... Have some other priorities with my larger models to complete...
Skycadet
Skycadet,
Problem is - given the same blade design - the more blades, the less efficient the prop. Full-scale planes don't use 3 or 4-bladed props because they're more efficient. They use them primarily in cases where a two-blade prop of sufficient diameter to absorb the engine's power would be long enough to present a ground-clearance problem, mechanical design problem, or when the tips would go supersonic. They also use them because they're typically quieter than a two-blade design that can absorb the same amount of power.
A one-blade prop is the most efficient. Some control-line racers used (use?) one-bladed props that have a streamlined counter-weight where the other blade should be.
Joel
turboparker is offline Find More Posts by turboparker
Old Oct 19, 2010, 08:09 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
The gearbox is quite tough, the propshaft bends or the gearbox comes loose before anything really happens to the gears or the plastic itself.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Oct 19, 2010, 11:56 AM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
Originally Posted by turboparker View Post
Skycadet,
Joel
This is true for the most part, but not always. As an example, my Super decathlon BL and Lancair ES both have MAS 3-blades on them. The pull is much more than 2-blades of the same diameter, by about 30% or so, while the current draw is only 8-10% [measured in line], yet the RPM at WOT is 90% or so of the 2-blade versions. Static and sim tests using Motor and Drive Calc confirm this, as do real world flight tests.
My problem with the Micro is that I don't have an easy way to test this without getting a whole whap of connectors and converters to the small micro connector, and this will most likely skew results due to the introduction a lot of extra loss that is less of an issue with the bigger planes. Also, the torque on the little Champ motor system seems very sensitive to loads, comparatively.
While the little 3-blader works, I think my issue is that the stock power system just does not turn the blades fast enough for a thrust advantage. I figured it might be a coin toss anyway. I'll convert that Champ #2 to brushless with a AP05 motor, and then try again.
SC
Old Oct 19, 2010, 12:15 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
Skycadet,
Joel
Joel:
Your information is not entriely right - there is a current trend in full scale aviation to go to 3-blades. I have seen this many times, as the 3-blades offer some advantages: ground clearance, smoother running, and depending upon the prop choice, in some cases much quieter running too.
>2 bladed props also do not suffer from OOP [out of plane] inertial moments generated by gyroscopic forces acting on the blades each rotation. This is why they are generally quieter and smoother running.
while 3-blades add an extra blade to add to tip drag, some additional drag due to extra blade area, and so on, in general, with the flight characteristics of these small park flyers, we're far from trans sonic on tip speeds anyway. The 3 blades can be made or chosen to be very efficient, however, we're somewhat limited in choices on smaller models.
Darren/Skycadet
Old Oct 19, 2010, 06:02 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Originally Posted by FLAME747 View Post
Just ordered some 240 mah Hyperions from RCBABBLE and some GWS 5045 props, and prop inserts from Radical RC FCA
Before switching props, and that in itself will be a neat study, just fly the plane as aggressively as you wish, with the stock prop and the Hyperion 240 mAh battery. You will be surprised just how nice the plane flys "stock", other than the battery change. I consistently get 14-16 minute flights with the 240cell, and there are lots of loops (inside), wing overs, barrel rolls, and WOT flyby's included in the performance. I haven't tried the prop swap yet. Haven't gotten bored enough with the stock setup!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Oct 19, 2010, 08:22 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
RD
Hi RD,
I was thinking about doing that, so I could provide some feedback on how both prop's felt, not anything technical, but just an overall feel.
Anyhow when did you place your pack, can you post a pic - I'm a visual type of guy
BTW: I have been recommending this plane to everyone under the sun, just love it
FCA
Old Oct 19, 2010, 10:37 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Anyhow when did you place your pack, can you post a pic - I'm a visual type of guy FCA
I think you mean "where" did I place or locate the battery pack. If so, this is where.........
RD
Old Oct 19, 2010, 11:57 PM
Joined Jul 2009
SC
SC,
I was specifically referring to props that load the motor the same - props that have the same static RPM @ WOT - not 2 & 3-blade props of the same diameter.
Joel
Old Oct 20, 2010, 12:07 AM
Joined Jul 2009
Joel:
Darren/Skycadet
Darren,
Regarding full-scale aviation - I stated the same thing in my post. I said that the reason they use 3 or more blades is not because they're more efficient - it's because of ground-clearance, transonic problems, & noise.
In my experience with RC planes, I have yet to find a 3 or 4-blade prop that can outperform a well-designed 2-blade prop that's well-matched to the powerplant & airframe.
Joel
Old Oct 20, 2010, 09:03 AM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
So --- parts have been rolling in --- I think I am just about all set to start my build thread... but can some1 post pics/ideas/suggestions of wing reinforcement? My Champ will pick up more power, but also more weight... I just wanna be sure that the wings are up for allI can toss at it.
SENTRY 62 is offline Find More Posts by SENTRY 62
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
