Old Oct 07, 2010, 12:16 AM
horseflesh is offline
Find More Posts by horseflesh
United States, WA, Woodinville
Joined May 2010
Originally Posted by Rickochet View Post
Hyperion makes a collet type prop adapter for 2mm shafts. It may tighten down that extra 1/2mm. If not maybe wrap some tape around the shaft then tighten down the collet.
http://www.allerc.com/product_info.p...oducts_id=1866
This works perfectly on the Champ and other UM planes.
http://www.bsdmicrorc.com/index.php?productID=716
horseflesh is offline Find More Posts by horseflesh
Old Oct 07, 2010, 07:23 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Originally Posted by iceman88 View Post
Has anyone been able to increase wing area either by adding on wing extensions or maybe something like flaps?
One of these champ threads has a fellow who added some slats.
I tried some in balsa- too heavy. He used foam (front part of a donor wing), I haven't gotten around to trying it again.
I'm tempted to add some small slats just in front of the wing, like on a Zenith.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Oct 07, 2010, 01:59 PM
NuFlya is offline
Find More Posts by NuFlya
aka RTF
NuFlya's Avatar
Long Island, NY
Joined Apr 2010
Got bored and painted some stripes on the Champ.Tamiya acrylic black and white.G-flyer decals came off easy with some heat from hair dryer.Looks a little decathlon-ish.Love this little guy.
NuFlya is offline Find More Posts by NuFlya
Old Oct 07, 2010, 02:16 PM
Rickochet is online now
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Very nice. I will have to decorate mine. I discovered a bunch of threads in the "Scale Electric Aircraft" forum about making your own water slide decals in your printer. You can use most any graphics program to create your own or import various graphics and print it out and stick it on the plane. The waterslide paper comes in both a clear and white sheets. This will be fun. I will have to spiff this little dude up.
Has anyone used colored packing tape for trim on the Champ?
Rickochet is online now Find More Posts by Rickochet
Old Oct 07, 2010, 10:16 PM
canadianufo is offline
Find More Posts by canadianufo
Just gotta mod. it
canadianufo's Avatar
Northern British Columbia
Joined Dec 2006
I used electrical tape but can get it [coloured packing tape] at work. Can't figure out how to lay a strip down to cut out a design, and then pull it free to place on the Champ....put it on wax paper maybe?
canadianufo is offline Find More Posts by canadianufo
Old Oct 08, 2010, 12:33 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
NuFlya!
Very nice scheme on your Champ! Nicely done...
Darren/Skycadet
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Oct 08, 2010, 12:50 AM
iceman88 is offline
Find More Posts by iceman88
Joined Aug 2006
Can someone put the link to the forum with the wing slats? I did a massive search and came up with nothing
iceman88 is offline Find More Posts by iceman88
Old Oct 08, 2010, 03:30 AM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
Try a small sheet of Sintra - this is polyvinyl sheet used in signs. Tape does not stick to it well, and it is tough enough to cut into to for making your detailed decals...
Old Oct 08, 2010, 03:31 AM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
A quick thank you to the poster initally mentioning the Dubro sport 1.23" wheels. Got mine today at the LHS, and painted them to match. Fit like a glove!
Darren/SkyCadet
Old Oct 08, 2010, 05:41 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by ZackJones View Post
Like others have already done I swapped out wheels on my Champ yesterday. I really like the way she looks in the air with them. Next modification will be to put the P-51 Mustang motor in it. She flew beautifully this morning until the winds started kicking up so we packed her up and brought her home. The in air shot is one my wife took this morning.
Do those Dubro 123MS wheels fit the Champ axle (not wobbly)?
I'm taking a trip to the LHS in a few hours. If your wheels are a good fit, I'll get some!
pugsam is offline Find More Posts by pugsam
Old Oct 08, 2010, 05:43 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I have one those rubber like self healing cutting mats. I just stick the tape to it, do my cutting and remove the tape part from the mat. I also use the mat to cut foam parts on when building a scratch build foamie. These mats are available at most craft stores in various sizes.
Old Oct 08, 2010, 06:24 AM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
Because they are skinnier than the stock tires they will move around a good bit but you can limit the play by adjusting the retaining clips and then put a drop of hot glue behind each one to hold them in place. I seem to recall the wheels fitting just fine without a bunch of slop in 'em. Take your landing gear with you and then you can check fitment while at the LHS.
ZackJones is offline Find More Posts by ZackJones
Old Oct 08, 2010, 06:28 AM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
Is this the one Iceman?
struts
Edit: I need more coffee. I saw slats but my maind said struts
Old Oct 08, 2010, 07:05 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Pictures of Champ Slats
Ember Citabria WIng Fences and slats
UNGN is offline Find More Posts by UNGN
Old Oct 08, 2010, 08:52 AM
NuFlya is offline
aka RTF
NuFlya's Avatar
Long Island, NY
Joined Apr 2010
Thanks,after further review i decided 3 stripes would look best and added some orange highlight to the wing and tail.Tamiya X6 perfect orange match.I like the sound of those printer decals.May need some new skills for that .
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
