Old Jun 14, 2010, 12:55 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Originally Posted by UNGN View Post
There is no Rudder channel on the Champs brick.
I looked for it, I couldn't find it. Unless there is some switch to turn it on that Horizon isn't telling us about, the Brick is 3 channel.
Keep your green dots, for now.
Right I got that but use that third channel for ailerons instead of rudder as the ailerons would allow tighter turning.
kenstogie is offline Find More Posts by kenstogie
Old Jun 14, 2010, 12:58 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That's hard to do because of the brick location. Hooking the Pushrod and having it work properly would be tough.
UNGN is offline Find More Posts by UNGN
Old Jun 14, 2010, 02:31 PM
MinneFlyer is offline
Find More Posts by MinneFlyer
MinneFlyer's Avatar
Joined Oct 2007
Originally Posted by olthump View Post
Everybody knows that if ya wanna go faster, just paint it red!
And put duals on it, of course.
Olthump - what material did you make your struts out of? Very nice job!!
MinneFlyer is offline Find More Posts by MinneFlyer
Old Jun 14, 2010, 02:46 PM
Carl T is offline
Find More Posts by Carl T
CARL T
Carl T's Avatar
United States, OR, Grants Pass
Joined Dec 2005
I made my exhausts of .062 Black wire insulation with the wire pulled out. That way IF it should bump the nose they will flex rather than crush.
Pictures to come along with a detail addition list.
Carl
Carl T is offline Find More Posts by Carl T
Old Jun 14, 2010, 02:47 PM
olthump is offline
Find More Posts by olthump
Occupying RCG
olthump's Avatar
United States, MS, Ocean Springs
Joined Sep 2009
Thanks. 1/16 balsa. Either ca soaked or fine cf rods for reinforcement. Attach with foam safe ca.
olthump is offline Find More Posts by olthump
Old Jun 14, 2010, 02:49 PM
MinneFlyer's Avatar
Joined Oct 2007
So no problems with the extra/added weight? I was thinking of using balsa, but thought it might add too much.
Old Jun 14, 2010, 04:12 PM
Ensign Jimmy is offline
Find More Posts by Ensign Jimmy
The building never ends!
Tucson, AZ
Joined Oct 2008
The Champ doesn't seem to really notice anything less than two or three grams of weight gain. I added struts to mine made from four pieces of 0.05" CF rod and the Champ didn't even notice. And my wings are far stiffer now, to boot.
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Old Jun 14, 2010, 04:53 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
what positive or ill effects do the stiffer wings cause, if any?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Jun 14, 2010, 06:46 PM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
the rudder channel is the same as an aleron channel,( rt stick rudder). It is a 3 channel brick, yes. Throttle, Elevator and rudder. Someone mentioned using the rudder channel for ailerons instead, and then fixing the rudder straight.
I don't think this plane will fly well with that type of setup as it probably needs the rudder to make the turns more so than ailerons would.
restlessswind is offline Find More Posts by restlessswind
Old Jun 14, 2010, 07:47 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
The Hyperion 160's are great batts was flying mixed throttle closer to top end for 90% of 10 minute flight and hadn't hit LVC.
Climbs a lot better with these batts - come on GWS prop hurry up lol
Old Jun 14, 2010, 08:13 PM
drewwrx is offline
Find More Posts by drewwrx
Ain't Nothing but a Peanut
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
Razor, Thanks for the reviews on the Hyperions. My Hyp 160s just came in today as well. Looking forward to flying with them. My only other batteries for this plane are one of the stock 150 and a turnigy 160. I have heard that the Hyperions are really good!
drewwrx is offline Find More Posts by drewwrx
Old Jun 14, 2010, 08:19 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Ailerons are in the top of the fuse, the Brick and elevator are in the bottom. Hooking up the Pushrods alone would be more trouble than this is worth.
Modding a RET 3 channel plane to still have 3 channels but AET would be silly, since it's easier to to make it 4 channels with an AR6400 and a remote aileron servo.
Even if it flew better with Ailerons instead of rudder, using the installed brick isn't the best way to do it.
Old Jun 14, 2010, 08:25 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
No worries
So far I am impressed - doesnt make any faster, but thats expected, but power is definitely there. The GWS prop and this batt, or the 240's which I have yet to wire up will be a great combo as others have reported
Old Jun 15, 2010, 07:44 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Well the swapping of channels (Rudder for Aileron) was an idea but evidentally not a good one.
I have a 5043 w/prop adapter on the way and I'll let you know how much difference it makes.
Old Jun 15, 2010, 08:41 AM
MinneFlyer's Avatar
Joined Oct 2007
I haven't even flown my Champ yet - just took it out of the box last night and went straight to bashing. I made some struts out of coffee stir-straws. Let me tell you, it was a challenge trying to find an adhesive that would stick to plastic straws!! I tried superglue, CA, hot glue, and UHU. Eventually a combination between hot glue and UHU worked, but it was a pain.
Next bash will be wheels, decals, and maybe paint. I suppose I should also try flying the Champ at some point!
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
