Old Feb 02, 2013, 10:34 PM
North_of_49 is online now
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by teflon97239 View Post
Okay, I just received a fresh batch of 600 mAh 1S 35 70C Nano-Techs. Not the best battery money can buy, I know, but that's what I have here. I plan to run them just a short time 3-4 minutes the first few cycles, and then be mindful thereafter as well.
So before I do something terrible to them right off the bat, is there a charging rate I should hit them with the first time? My charger is the generic Celectra variable rate 0.1 to 0.7 thing that comes with most E-flite RTF kits. What's my best rate to start, and then later after the initial break-in?
Thanks in advance for advice.
There's going to be alot of opinions on this. I have lipos ranging from 70mah to 5000mah and I charge most of them at 1C if I can afford the waiting time... and I usually can. That is being conservative, I have lipos that are rated for charging at 5C and I still don't charge them above 2C. Bottom line is I have happy lipos.
I'm more likely to stick to 1C on my cheaper lower quality lipos like the original white E-flite ones.
I'd charge my 5000mah lipos at 2C (10A) if my charger could do it on AC but needs to be DC powered to charge at 10A... so I charge those at just under 1.5C (7.4A) when my charger is on AC.
1C on your 600mah lipo is 0.6A so you can max that Celectra and you'll be fine regardless of whether you're breaking them in or doing subsequent charges... there's no setting on that charger that will overdo it on those or even on lesser quality lipos... at that capacity.(600mah)
What's the recommended maximum C for charge rate on that lipo? I'd halve it, personally, if I had a charger that could do it (Celectra won't)... and do 1C during break-in.
North_of_49 is online now Find More Posts by North_of_49
Old Feb 02, 2013, 11:10 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Wow - that's quite a load!
Gene K
speedy01 is offline Find More Posts by speedy01
Old Feb 02, 2013, 11:31 PM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Gene K
Once you get North going, there's no stopping him Very precise
Here's a pretty good site I always pass off to noob electric flyers. Easy reading, easy to understand...I still refer to it
https://sites.google.com/site/tjingu...arging-how-tos
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Feb 03, 2013, 12:10 AM
Joined Dec 2011
Mike.
Speaking of precise, you should see the gold mine of official Piper Super Cub blueprints I just came across in PDF format I've already downloaded 37 of them including the two I wanted most... a flat pattern for the windshield and a front view of the landing gear and suspension... both of which I can cut or bend to directly if I print them to scale I should end up with most scale HZ Super Cub ever done! I could tell you where to find them, but then I'd have to kill you :
Old Feb 03, 2013, 06:00 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
(Mike! I didn't know you were one of the original Beetles)
Interesting, I actually helped to build/refurbish the original Cavern in Liverpool circa 1955/6 and played there a few times. If you remember a guy called Ron McKay the drummer with the Kinks at the time, he used to sit in with us on odd occasions. Those were the days !!
Off topic I know, but I do have three Champs. great little plane to chuck in the boot for that "just in case" situation.
geedee is offline Find More Posts by geedee
Old Feb 03, 2013, 12:41 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Mike, I loved that pic bro. Nice haircuts!!!
North, you have to link us to those plans man. Dang it...I am just about to start a scratch build project. That is a tempting thought. I love cubs.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Feb 03, 2013, 03:04 PM
Saxguy1000 is online now
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
You are killing me, man! If you don't post those plans, I'm going to spam you with pictures of pre-WWI flying machine crashes.
Saxguy1000 is online now Find More Posts by Saxguy1000
Old Feb 03, 2013, 03:43 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
North: Spot on with your recommendations. My only concern is the size and weight of the 600mAh Nano-Tech lipo. I use the Hyperion 240mAh 1S 25C lipo, with good results. Fits the Champ perfectly, both position-wise and CG-wise.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Feb 03, 2013, 04:29 PM
Joined Dec 2011
Here you go. This is for the Piper PA-18 Super Cub, not the Champ. I know Mike has one, as do I I'll probably make a paypal donation... I'm happier than a pig in #%@$
http://www.supercubproject.com/drawings/
Description: Name: sample-gear.jpg
Description:
Old Feb 03, 2013, 04:34 PM
Joined Dec 2011
RD
Yeah, I'm not familiar with the Nanotech. But I did see alot of guys in the Champ threads when I first subbed to them who were (are) using the 500mah or 550mah 120SR sized batteries.
Old Feb 05, 2013, 01:12 PM
dbdukeboy is offline
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
Subscribed
dbdukeboy is offline Find More Posts by dbdukeboy
Old Feb 11, 2013, 08:28 PM
QuinnZ. is offline
Find More Posts by QuinnZ.
The Corsair Kid
United States, NV, Spring Creek
Joined Feb 2013
Total NOOB
Could the Champ use a 450 mah 1s batt? Though it may be pretty heavy, it will provide a lot of flying, possibly 30+ minutes. Along with a keychain camera to... Just ideas
QuinnZ. is offline Find More Posts by QuinnZ.
Old Feb 11, 2013, 09:56 PM
Joined Dec 2011
Look a few posts above
Old Feb 12, 2013, 12:55 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by leethetreeguy View Post
Ridge, I almost fell out of my chair!!!
Originally Posted by whirlcap View Post
Me too!
I just spit my drink up thru my nose...too funny
Long time since I have read through this thread .... is this fishy-comics you speak of??? I have only gone back a couple of pages ... what have I missed??
mutha is offline Find More Posts by mutha
Old Feb 12, 2013, 09:14 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Welcome back mutha. Lets just say he re-invented himself...
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 02:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 01:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 07:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 02:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 11:01 PM
