Old Jan 01, 2013, 03:52 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by Dlta Nvmbr Ynkee View Post
Same here I have four batteries and would usually cycle through them without a break I recently got a umx beast 3D do brushless motors have the same problems ?
PS bought a um P-51 motor for the champ
The same thing that destroys brushed motors can also ruin a brushless one... heat. In the RC car/truck community we watch our "temps" very closely... with a temperature gun or telemetry. I have both
you usually only need to find the temps you're hitting with a new setup (gearing... props, gears, pinions, weight changes, etc) to find a ballpark figure for the limit of continuous run times... or when outdoor temperatures change with the seasons. I can run stuff alot harder and longer right now in the winter.
North_of_49 is offline Find More Posts by North_of_49
Old Jan 01, 2013, 08:11 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
thinking out loud.
Motor cost 5-10 give or take. you gotten 50-100 runs. the cost is .05-.10 cents per run per length 10 minutes?
comes out to a penny a minute. I say that is not bad at all.
There is a short rest, but way to short.
excellent advice about the motors .
Happy new year all
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Jan 01, 2013, 08:48 PM
Joined Dec 2011
Yes, Happy New Year!
Old Jan 07, 2013, 11:42 AM
JT2 is offline
JT2
Find More Posts by JT2
JT2
Joined Jan 2013
Anyone have Champ WeboCalc values?
Could somebody post a screenshot of a WebOCalc for the Hobbyzone Champ?
I've been playing with WebOCalc for this and can't get it to accept any prop size to allow the plane to fly.
From the Hobbyzone Champ page:
Wingspan: 20.3 in (517mm)
Overall Length: 14.3 in (365mm)
Flying Weight: 1.3 oz (38g)
Radio: 4-channel 2.4GHz transmitter with Spektrum DSM 2; 3 channel receiver and aircraft
Prop Size: 130 x 70mm
Charger: DC 3.7V LiPo charger (included)
Recommended Battery: 3.7V 1S 150mAh LiPo (included)
Landing Gear: Fixed main with steerable tail wheel
Trim Scheme Colors: Yellow with orange trim
CG (center of gravity): Approximately 28mm from leading edge of the main wing
I saw elsewhere that someone had the total wing area at 63.3sq
JT2 is offline Find More Posts by JT2
Old Jan 08, 2013, 06:35 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
This is what I got with my own measurements, but I realize "garbage in, garbage out." Someone feel free to improve on stuff I guessed at like motor kv.
Name: HobbyZone Champ on Webocalc (metric).png
Description: Name: HobbyZone Champ on Webocalc (Imperial).png
Description:
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 08, 2013, 09:42 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Sax, the 1.5.2 Version is what you have. I notice there are other versions. Any difference between them that you know of?
BTW, nice find
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jan 08, 2013, 02:11 PM
JT2 is offline
JT2
JT2
Joined Jan 2013
Champ WebOCalc
Yes, that is about what I had too...
I was trying to come up with the stock motor kvm. I don't have a feel for the thrust on this plane as I don't have enough flight time on it yet.
Here what I came up with, with the goal of getting the 4:1 gear ratio of the 5x3 stock prop
Old Jan 08, 2013, 07:29 PM
cervri is offline
Find More Posts by cervri
United States, NM, Deming
Joined Sep 2012
Champ gearbox shaft.
Can someone please advise me on how to remove the gearbox shaft for the champ? I need to replace it and the nylon gear. Thanks in advance.
cervri is offline Find More Posts by cervri
Old Jan 09, 2013, 04:12 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Hi. You have to carefully cut the tape that holds the fuselage together, open it and work on it from there. Hold the nut on the back side of the shaft with needle nose pliers and turn the prop to loosen and remove it. Replace and re-tape the fuse back together. Off into the wild blue after that.
Old Jan 09, 2013, 04:13 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
BTW, nice find
Mike.
Wasn't aware of the different versions, Mike. Thanks for telling me that. I was using an old bookmark.
Update: Just figured the same data as what JT2 has above and it comes out exactly the same with version 1.7.6. The new version has fewer bugs and more options, but same results.
Old Jan 09, 2013, 04:14 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
That's got to be pretty close to right.
Old Jan 09, 2013, 09:35 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Got it! Thanks
Mike.
Old Jan 09, 2013, 08:18 PM
Iplumb is offline
Find More Posts by Iplumb
Joined Aug 2012
What's the best battery for the Champ? Where are you guys picking them up? My 150s are getting tired. I think I read somewhere about 190s.
Iplumb is offline Find More Posts by Iplumb
Old Jan 09, 2013, 09:05 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
I believe these are the batts you are talking about. They come from the UK. I think I seen some on ebay. I hear a lot of good talk about these. Miniaviation.
http://www.miniaviation.com/KM_190P.html
I would check them out but, I have a fleet of 6 Thunder Power 160mah 25C batts that are still flying very well.
Mike.
Old Jan 10, 2013, 04:27 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by North_of_49 View Post
These are the same ones in 1-3/4" and 2" ... modified...
http://www.rcgroups.com/forums/showp...postcount=3682
The 2"
Attachment 5362733
Attachment 5362736
Hey, North, I was just noticing the wheel supports in the photos. How did you do that mod? Very nice.
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
