Old Nov 18, 2012, 10:28 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Originally Posted by fOaMmaSh87 View Post
Will this work for 5043 props????
http://www.hobbyking.com/hobbyking/s..._10_motor.html
Cheers in advance Ben
Hey Ben.
I do not mind spending a few dollars, like UNGN said, and ridgewalker having a video demonstration on the heat shrink video?
I was offered advice from Ridgewalker, pointing out the E-Flight 1.5mm adp.
It is a better fit, and will not cause issues.
The Prop saver is not needed because there is not enough force to break the prop, unless an unlucky incident occurres.
Hobbyzone champ last weekend flight Sony (4 min 52 sec)
Today If I had that prop saver I think I be searching for that band? see at the end the prop hitting the floor?
Also you have to add the prop and band on first, then tighten down the adp, and then to the prop shaft, and if pressure is applied I see the motor and mount coming loose, my thoughts
1. make your own. you feel good
2. get the e-flite 1.5mm adp
3 the 1.5mm saver has a bigger diameter that the prop may need drilling I got one sitting here.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 18, 2012, 04:55 PM
EpicRC is offline
Find More Posts by EpicRC
Just another FPV addicted teen
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Originally Posted by UNGN View Post
Yes, but it has a 2mm hole, which will be a lttle sloppy on on a 1.5mm shaft.
heat shrink tubing can be used if it's too sloppy.
Will it spin straight?
EpicRC is offline Find More Posts by EpicRC
Old Nov 20, 2012, 09:44 AM
AeroMaestro is offline
Find More Posts by AeroMaestro
Smasher of foam
AeroMaestro's Avatar
United States, CO, Grand Junction
Joined Sep 2012
I thought you guys would get a kick out of this. I crashed my Champ into a tree two days ago while testing out my new camera mount. (I'd say the camera mount is a success.... the flight wasn't.) Please spare me the "what a stupid place to fly" comments -- I've learned my lesson the hard way. I spent the last 2.5 days trying to get the plane back down.
I am now the owner of a new fishing rod and 30 feet of pvc pipe.
Champ hits a tree (1 min 22 sec)
(I walk into the very top left corner of the frame at about 1:10.)
There's a fairly long thread about the rescue attempts -- with a happy ending -- here:
http://www.rcgroups.com/forums/showthread.php?t=1773479
AeroMaestro is offline Find More Posts by AeroMaestro
Old Nov 20, 2012, 10:45 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
1 1/4" electrical pvc pipe for 2 or 3 lengths is much stiffer than half or 3/4. Works
way better..... for future reference
jrjr is offline Find More Posts by jrjr
Old Nov 20, 2012, 10:52 AM
Mac Smith is offline
Find More Posts by Mac Smith
Mac Smith's Avatar
Germany, HE, Frankfurt
Joined Jun 2012
Had to pick my Champ out of a tree on its maiden flight, so no lecturing from me.
Mac Smith is offline Find More Posts by Mac Smith
Old Nov 20, 2012, 12:49 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I have used the lead weight tied to twine, toss it, then tie clothes line to that and pull it though and shake it like crazy. My Bud and I call it our Champ Retrieval System or (CRS). NO, NO, NOT that CRS...Can't Remember Sh..
I had the honor of using it first
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Nov 20, 2012, 06:56 PM
Joined Oct 2006
Some EMT is a lot better less flex, but I use a sling shot, fishline, then rope, sinkers thanks to a few members like Blu, viper, ridge for advice . Now I just carry the good ole sling and some twine as back up.
Old Nov 28, 2012, 04:19 PM
Gharddog03 is offline
Find More Posts by Gharddog03
Ground Pounder
Gharddog03's Avatar
United States, CA, Fresno
Joined Nov 2012
Hello, new to the RC world but enjoying the hell out of it. I just bought a Champ. Question is what is the best mod to do. I have read P51 engine, prop, and battery? I was bored with the yellow so I started to shapie it.
Gharddog03 is offline Find More Posts by Gharddog03
Old Nov 28, 2012, 05:07 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Welcome Gharddog03 The Champ is a beautiful first time trainer. There are many mods you can do but, for the first mod and, very simple... Raid your wifes make-up stuff. Look for some of this. Dab a couple of applications of "Sally Hansen Hard As Nails (clear)to the end end of the axle to prevent your wheels from coming off and disappearing for ever. You can also use CA. The idea is to form a "teardrop" at the end of the axle
Very simple (5 min.) and it will keep you from losing your wheel(s).
Others will chime in on other mods
Mike.
Old Nov 28, 2012, 05:29 PM
Ground Pounder
Gharddog03's Avatar
Joined Nov 2012
Mike.
Sweet thanks Mike. Will do.
Old Nov 28, 2012, 06:36 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
I have the mustang motor on mine with the stock prop, but really the extra speed doesnt get used from me as i fly in my front yard, but thats what is so fun about the champ, the slow capabilities.
One mod that i would recommend is to get some dubro 1 1/2" mini lite wheels.
http://www.headsuprc.com/servlet/the...er-Mini/Detail
Heads up is a great place to order from with good prices and cheap shipping. Also, you can pick up some extra batteries.
http://www.headsuprc.com/servlet/the...-20C-EZ/Detail
they seem to be working out well for me.
nightfox7 is offline Find More Posts by nightfox7
Old Nov 28, 2012, 06:56 PM
Joined Oct 2006
Today I lost the both hubs inner and out, of one side only? some Antz rolled them away for a project? razer scooter?
I preglued them guess those antz were desperate .
So some black tape wrapped and a dap of gorilla brown glue.
The dubrows are awesome, for me I think lighter now is better I may just cut some circles out as I only use the LG as cosmetics Lol, JK
Old Nov 28, 2012, 09:00 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
http://www.youtube.com/watch?v=bT_X5...ature=youtu.be
Also a reminder for those that have multiple batteries...know which ones youcharged last before your flight...I was out yesterday at dusk flying the champ and daughter comes out to watch..I just finished telling her how battery life in the plane is very short in cold weather..was mid 30's here..just after finished telling her that my champ glided into the brush..I had no control at all..apparently I grabbed a battery that I had flown last time and did not recharge it.. And yes, I did throw in a battery after I retrieved it and was fine. First time I have done that..but just shows how easy you can lose this puppy real quick.
Ginohio is offline Find More Posts by Ginohio
Old Nov 29, 2012, 02:42 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
I've said before that I really don't think the cold is as hard on these small 1S lipo batteries as it maybe is on the main-board circuitry in some of these micro birds. I can fly full 6 minute flights in my mCX2 at 0°C (32°F) with the same lipos (EDIT: 160mah, I fly 125mah in the Scout) that I fly in my Scout CX and the Scout will shut down in under half a minute in the same temperature...
... I owned my Scout before I got the mCX2 and when it'd shut down so quickly running it outside in the winter I mistakenly chalked it up to being the battery that couldn't handle the cold and wrote off the whole idea of flying this and any future helis outside during the winter... until I came across some posts Martyn McKinney made in another thread suggesting that it's actually something about the design of the circuitry in the Scout CX main-board that is the culprit when it comes to cold...
... when I bought my mCX2 soon after getting my Scout last winter, I found out that there were no noticeable differences in flight times flying it indoors or outdoors... at or around freezing... give or take a few degrees. To head off the nay-sayers who think I might be making this up, I've also mentioned, when I've brought this up before, that I have a 6 minute unedited non-stop video on Youtube (linked to on my blog) of myself flying my mCX2 (in, I believe, January)... take maybe half a minute off that time for mishaps that grounded me temporarily, but it was also still going when I purposely brought it back down due to not having a timer and not wanting to actually run it to LVC.
I don't know if the Champ is susceptible to cold, I haven't flown mine in the cold yet, but if it is, I'd suspect it's the circuitry and not the actual battery (the battery generates its own heat as it discharges).
North_of_49 is offline Find More Posts by North_of_49
Old Nov 29, 2012, 10:14 AM
Joined Oct 2006
Cold on these do not affect a lot, just some, and how much I care not to discuss, detail, detail, detail just adds fuel to the fire at rcgroups.com
I had just gone out, and will be placing a #20 on my battery, and that will stand for 20 minute flight time on a 500mah,
he battery should get three good flights 2 full power third with loss, before hitting LVC.
SO yes how we take care of them, LVC, charge, cold, storage.
Glad we can pull our champs out of a tricky situation and fly another day.
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
