Old Nov 01, 2012, 09:27 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by nightfox7 View Post
... where do you get the prop adapter?
No need for ebay, waiting, and spending. Simply shrink multiple layers of heat shrink tubing onto a 1.5mm drill bit/wire until it's built up enough to snugly fit into the 5043. Trim after inserting and screw the prop onto the motor shaft. Simple and effective.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Nov 01, 2012, 10:06 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Thanks fishy and speedy! I'll try the shrink wrap! I'm also looking for a mustang motor
nightfox7 is offline Find More Posts by nightfox7
Old Nov 02, 2012, 08:06 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
yep there are a few propellers out there that have a thickness in diameter.
I chose the few dollar route has a better look Adds a tad of weight,
with a home made job, slippage may happen? with the machine made one the hex screw may come loose?
Either way they are great options. with mine just remember to add locktite to the hex screw and keep an eye on the screw, its aluminum, ad glueing it will cause that screw to snp with some force.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 03, 2012, 04:53 AM
EpicRC is offline
Find More Posts by EpicRC
Just another FPV addicted teen
EpicRC's Avatar
Australia, WA, York
Joined May 2012
My Champ
My mods to the Champ
-Bigger wheels
-Clear plastic to stop the wheel pant things digging into the side.
-Thin wire in between the wheels to stop bouncing on the landings.
-AR6400
-220mah battery
-5043 prop to go on soon
-Solo pro motor to upgrade to
-Removable wing struts
Will answer questions.
Description: Wing struts
Description: bigger wheels
Description: some thin wire to stop bouncing on landings
+ bigger battery tray.
EpicRC is offline Find More Posts by EpicRC
Latest blog entry: 450 pics
Old Nov 03, 2012, 07:51 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
What about carbon tow ran under the wings for a spar?
Old Nov 03, 2012, 07:59 AM
EpicRC is offline
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Sorry?
Old Nov 03, 2012, 03:31 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Originally Posted by fOaMmaSh87 View Post
Sorry?
Like the carbon thread that is in rolls, I assume you could run a small thread under the wing and CA it in place and it would be quite stiff.
I got my champ today and put 1.5" mini lite wheels on it and it looks quite great!
Old Nov 03, 2012, 04:16 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
I just got back in from flying and had a blast! Who new this could be as fun as my 3d plane?? With the wheels on it I can take off of trimmed grass and caravel with ease!
Old Nov 03, 2012, 08:49 PM
EpicRC is offline
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Nice I might get some bigger wheels again because the ones i got don't really make a difference.
Anyway last night i put some CF reinforcement on the tail tried to make it look scale what do you all think???
Description: CF
Description: CF
Description: CF
Old Nov 03, 2012, 10:25 PM
North_of_49 is online now
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
I like it
http://www.rcgroups.com/forums/showthread.php?t=1683386
... and here's your bigger wheels ...
North_of_49 is online now Find More Posts by North_of_49
Old Nov 03, 2012, 10:37 PM
EpicRC is offline
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Originally Posted by North_of_49 View Post
I like it
Yours look a little better then mine and thank you for the idea (I saw your champ somewhere and thought it was a good idea)
And also where does everyone get their 240mah hyperions from?
Old Nov 03, 2012, 11:36 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I love take off's and landings. Touch and go's are pretty awesome too
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Nov 04, 2012, 12:23 AM
EpicRC is offline
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Mike.
Nice did you put the stock wheels inside the bigger ones?
Old Nov 04, 2012, 12:28 AM
Joined Dec 2011
I know for a fact that he did... I remember him trying to figure out what I had done from my first pics I posted back in the summer
Hey, Mike... did you ever get some "show off" video? Mine's still sitting here on my hard drive... have been too lazy to upload it
Mike's wheels are the ones I started with... T-28 wheels (PKZ4406). I'm on version 2 and 3 of mine and am now using DuBro foams that I shaped and removed the tread from (1-3/4" and 2")... mine and Mike's have been removed from their original hubs... one of the benefits of this is the center hole is a fair amount smaller than you might realize once you've gotten rid of the flange on their stock rims regardless of which brand of wheel... the tires themselves actually look scale to the real Alaskan Bushwheels, which have a very small rim diameter compared to the tire diameter. If you leave them on their stock plastic hubs they're not only heavier but they don't look "right" if a true bushwheel is what you're after.
Old Nov 04, 2012, 12:35 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Attachment 5278744
Attachment 5278745
Attachment 5278746
Do it man, I got mine from heads up rc, fast shipping and its only two dollars.1.5" seems to be a very good size.
And I like the carbon!
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 02:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 01:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 07:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 02:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 11:01 PM
