Old Oct 26, 2012, 10:22 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Originally Posted by Loserboy View Post
The wing struts are made of 0.032" music wire soldered together and painted. They are heavy and fragile but I like the look. They take away some of the dihedral so the plane is not as stable as when I remove them.
If you take a peek at North_of_49's blog (click on his user name) he used CF rod (.020" i think). He claims is very light.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Oct 26, 2012, 10:26 AM
Loserboy is offline
Find More Posts by Loserboy
United States, TX, Conroe
Joined Oct 2012
Chap1012,
I actually used part of your battery suggestion on my mod. The difference is the shrink tube sleeve is replaced by the rubber band (see the middle pic on previous post. Thanks for the tip, it works great.
Loserboy is offline Find More Posts by Loserboy
Old Oct 26, 2012, 10:31 AM
Loserboy is offline
Joined Oct 2012
Mike.
I thought about CF rods but chose the wire so I could bend the ends to make the struts removeable.
Old Oct 26, 2012, 12:24 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
This is what I do with my Champ to save the paint when I need to open the fuselage. I make a tab on the back of the removable part of the fuselage to hold the pieces together at the back end and use a strap to hold the front together. This way I can open the fuselage repeatedly without tearing off paint.
I also added a battery cover as you can see in the middle pic just to make it look better.
Ahh I was not fully awake when I read and viewed.
Awesome job. Packing tape and a tab and slot I see it now. Great job will try to do that I'm my other champ
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Oct 26, 2012, 04:24 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
@North Are you still not impressed yet OR are you still fumbling with magnets Sorry could not resist
Mike.
I just finally found my mini magnets on the seat of my car under some crap (not literally) that's been sitting on the passenger seat forever ... still going to do this mod though. Just haven't had time for the Champ... it's on my "to do" list along with either repairing my cracked in half fuse or transfering all my current mods over to a new fuse, but not until after modding my RC truck and buggy with lights/brake lights and then finishing my bushwheels for my Super Cub and maidening it. Unfortunately, since I've put that stuff off for so long now, I probably won't get to run (maiden) my floats on water on either plane until next spring as temps are dropping and any water will be frozen soon... but I can still run them on snow
North_of_49 is offline Find More Posts by North_of_49
Old Oct 26, 2012, 04:31 PM
Joined Dec 2011
Mike.
Yeah, my tail wire braces (flying wires) are the CF and won't even register on my scale. The main wing struts are styrene from my LHS's model building section (half rounds). They're more aesthetic than functional but they do function to a point. They're designed to break away if enough force is applied to them (crashing)
Old Oct 27, 2012, 06:45 AM
eagle1933 is offline
Find More Posts by eagle1933
Dallas USA, TX
Joined Jul 2010
Loserboy: thanks for the info on your wing struts. They really look good.
eagle1933 is offline Find More Posts by eagle1933
Old Oct 28, 2012, 08:43 AM
Crescendo is offline
Find More Posts by Crescendo
Joined Oct 2012
Hi all,
I'm buying my first RC plane and I've decided on the champ. For now I've decided to keep everything stock except for the battery, which I plan to upgrade because I'm hoping to achieve longer flying times.
Can someone please tell me what the technical name of the Champ battery connector type is? Is it JST-XH, or Ultra Micro, or something else? In my naivety I can't seem to find a definitive answer, as it seems this is just one of those things it's assumed you already know.
In light of this, is the following battery compatible with the Champ (i.e. no connection adapter required)? http://miniaviation.com/KM_190P.html
If it's not, could someone please recommend a good quality, 200mah range battery that would be 'plug in and play' with the Champ?
I apologise if these questions have been asked a 1000 times before. I'm suffering from information overload at the moment and am hoping some kind soul will take pity on me.
Crescendo is offline Find More Posts by Crescendo
Old Oct 28, 2012, 09:26 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Originally Posted by Crescendo View Post
Hi all,
Those Miniaviation batts will work just fine. In fact I hear they are pretty awesome.
Here is the battery plug (stock number) you'll need should the old one fail.
http://www.horizonhobby.com/products...w-wire-PKZ3052
You will love your new Champ. If you've ever flown helis, just go easy on the sticks. No stick banging...lol. Have fun..
Mike.
Old Oct 28, 2012, 10:05 AM
Joined Oct 2012
Mike.
Hello Mike,
Thanks very much for your reply, and for confirming the compatbility of the Miniaviation battery. At your suggestion I've also taken note of the battery plug you linked to.
I have never flown an RC helicopter, but I have had some experience with RC planes, so I've at least learned to only use as much of the control surfaces as is necessary to execute the desired manoeuvre.
One final clarification if I may: the Miniaviation 190mAh 25c webpage I linked to specifies that the "Balance & Discharge Plug" is of the type "JST-XH". If this battery is in fact compatible with the Champ, does this mean the Champ uses JST-XH plug?
Thanks again!
Old Oct 28, 2012, 10:20 AM
Joined Dec 2011
ultra micro
Old Oct 28, 2012, 10:39 AM
Joined Oct 2012
Originally Posted by North_of_49 View Post
ultra micro
OK, thanks, North_of_49!
(Sorry if I'm being really obtuse, but how can the Miniaviation batteries be plug-in-and-play compatible with the Champ if they use "JST-XH" connectors and not Ultra Micro? Is it possible the Miniaviation page should say Ultra Micro instead?)
Old Oct 28, 2012, 10:48 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
If you google "JST-XH" you come up up with several types of JST type, size and config. Female/male...1S (cell). 2S (cell). 3S (cell)...ETC.
This is opposed to "Deans" type connectors or "bullet" / "banana".
This is why I sent you the stock number for the Champ's battery plug (female). I agree it's a bit confusing when trying to choose the right cable/connector. I still ask questions before buying
Mike.
Old Oct 28, 2012, 10:50 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Don't worry. The Miniaviation batts will fit just fine in the Champ. I plan to buy some of these when my Thunder Power crap the bed. But they are still somewhat new
Mike.
Old Oct 28, 2012, 11:01 AM
Travler is offline
Find More Posts by Travler
Wingman
Travler's Avatar
United States, AL, Randolph
Joined Mar 2004
go to http://www.rc-connectors.com that should keep you busy for a while and hopefully answer some of your questions.
Larry
Travler is offline Find More Posts by Travler
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 890 Yesterday 12:12 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
