Old Oct 10, 2012, 01:16 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Check out my Blog - I have photos of a BL setup that I did - I used a AR6400LBL brick, a Turnigy 1S 5A ESC (AWESOME for this application!) and a AP05 motor. THe latter two are available through HK. (including 160mAh 1S Turnigy NT batteries!!)
Feel free to PM me with any Qs. Mine's flying GRRReat!
Sc
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Oct 10, 2012, 01:24 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
Mike:
The Glue-coat procedure is a coating of diluted white glue (I recommend/prefer Weldbond) over all surfaces (exc. hinges!) on a foamy. I dilute it by~50% (1:1 with water) and then brush it lightly on using a small acrylic paint brush used in modelling applications (my main brush is ~3/8" wide). I use a smaller 1/16" wide brush for tight spots.
Application is 2x on the front cowl (where most of the damage can occur!), wings, fuselage, and tail - I usually NOW do a second coat on TOP of the vertical stabilizer, where inadvertent tip overs may cause it to hit on occasion, the wing/horizontal stabilizer tips, and leading edges of the wing and elevator (horizontal stab).
Yes, this adds some weight, but NOT very much. Perhaps 1-2g max or so, depending upon how thick you apply this coating. HUGE benefit is the extra strength and impact resistance this gives to the plane. I did this recently with my <new> UMX Beast 3D plane, and during one aileron lockup on a handlaunch, it went near WOT into the ground! Only a tiny dint in the spinner, and a micro crack in the cowl, with a small prop bite. Otherwise, not bad at all! I can almost guarantee it would have been MUCH worse without the mod.
Scuffing, dents, and general chips are way fewer with this coating, and the drag is slightly reduced too, since any foam open cells are closed by the glue.
SkyCadet
Old Oct 11, 2012, 05:46 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by SkyCadet View Post
Mike:
SkyCadet
Is white glue the same as PVA??
mutha is offline Find More Posts by mutha
Old Oct 11, 2012, 06:50 PM
planegoofy is offline
Find More Posts by planegoofy
Joined Sep 2004
Can you apply this over tape & the decals?
planegoofy is offline Find More Posts by planegoofy
Old Oct 11, 2012, 07:54 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Thank you SkyC, Now the "glue coat" proceedure sounds familiar. A friend/Member (leethetreeguy) mentioned using Elmers glue (as he did on his Champ). I believe it was the same mixture (1 to 1). As everyone knows Elmers glue dries slow giving you plenty of time to spread the solution AND is very strong. You just need time on your hands which I have plenty of
How fast, OR how much time do you have, to work with "Weldbond"? I have worked with (and like) a carpenters glue called "Titebond." It dries in 30 minutes (24 hour cure time). So,,,...I don't think (IMHO) that would be the glue to use as a "Glue-Coat" procedure...the "Titebond" that is
Just trying to keep ideas open
BTW SC, I like your description (write up) of the application "areas."
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Oct 11, 2012, 08:38 PM
Edmond Y is offline
Find More Posts by Edmond Y
Canada, BC, Port Coquitlam
Joined Nov 2008
I have used both Elmers and Weldbond and didn't notice any different between one an other but this glue mod is the single most important mod that NEED to be done before the first flight. If I knew this before I bought the first Champ. I don't need to buy the second one.
Edmond
Edmond Y is offline Find More Posts by Edmond Y
Old Oct 11, 2012, 10:35 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
OK, Great! Thanks Guys. Time to get to work. BTW, my Champ's verticle stab has a slight horizontal crease. Nothing serious. Will this "Glue Coat" firm it up a bit? Should I tape (small slice) on one side? Both sides? OR, Apply tape "after" Glue Coat? Sorry about all the questions Guys but, I find this very interesting and I'd like to get it right
Mike.
Old Oct 11, 2012, 10:40 PM
mutha is offline
mutha's Avatar
Joined Jan 2011
Did some research and answered my own question.
Yes it is ...
Old Oct 11, 2012, 11:14 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Mike.
Clear tape. Once depron is creased, clear tape is best to put the stiffness back in.
UNGN is offline Find More Posts by UNGN
Old Oct 12, 2012, 03:19 AM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
Pretty much any white glue will work as a coating. I prefer Weldbond because it is very easy to dissolve without breaking the emulsion, and also because it dries VERY clear.
I sometimes have used a small "patch" of clear model decal material to reinforce a crease, but usually pre-cover again with white glue first. This adds some lateral strength to the material, I find, esp. if it is creased significantly.
Any way to do it is fine, but be mindful that too much of either solution may add weight. Not a problem with larger models, but micros are somewhat sensitive to signficant additional weight.
SC
Old Oct 12, 2012, 08:37 AM
jimsp is offline
Find More Posts by jimsp
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Mike.
By far the best solution for this is 1/2 or 3/4oz fiberglass applied with with Minwax Polycrylic. Very simple to do, weight gain is imperceptible, adds considerable strength and stiffness and is nearly invisible.
jimsp is offline Find More Posts by jimsp
Old Oct 12, 2012, 10:45 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Hi Jim, you now have my attention but, your post is a bit vague. First, is this the 1/2 oz fiberglass you are talking about???
http://www.horizonhobby.com/products...q-yard-HAN3620
I assume this is the Minwax you use:
http://www.minwax.com/wood-products/...tective-finish
Is it possible to be a little more specific as far as the application process and how you do it? The picture of the fiberglass cloth looks heavy but, I know looks can be deceiving. I'm still trying to absorb and understand how this method would be lighter than just a mixture of glue and water. Thanks in advance.
To the rest of you guys. Thank you for your input. Please keep it coming if you think of anything else.
Mike.
Old Oct 12, 2012, 11:58 AM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Man, I must be getting old Mike. You forget what I tell ya. ahahahahhahaha. I know I mentioned the elmors solution to ya. And on some planes (sometimes) a lightweight spackle can be a good friend. Use your igmagionation bro. You could prolly build a new airplane out of foam plates, and spackle. GO FOR IT!!!
Woot hoot.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Oct 12, 2012, 12:08 PM
jimsp is offline
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Mike.
Both of those are the right products. The fiberglass is very thin and easily conforms even to curved surfaces. Sort of like a very fine silk scarf. Hobby shops generally carry it. Minwax is a water based product with a watery type consistency. You can find it at stores like Walmart and comes in a size as small as a half pint. The polycrylic only takes about an hour to dry.
All you do is lay a piece of the fiberglass on the surface and using a small paint brush in the polycrylic. This will pull the fiberglass down and adhere it to the surface.
Attach is a photo showing a repair I made to the vertical fin my Carbon Cub after creasing it on a landing flip over.
Old Oct 13, 2012, 12:00 AM
trevorsride is offline
Find More Posts by trevorsride
Joined Feb 2007
New Champ owner.
Loving the Champ! Been into cars, trucks, and helicopters for most of my life, but have never done a plane for some reason. So much fun!! Only mods so far are the bigger wheels, and tires, and some glue and tape to fix a broken wing, and tail. still flys like a Champ! I would like to get some upgraded batteries that will fly for at least 15 minutes without hitting LVC. What do you guys reccomend without cutting the plane up, and will still work in the stock charger? I will probably end up upgrading to a better motor, and prop one of these days also.
trevorsride is offline Find More Posts by trevorsride
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 02:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 01:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 07:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 02:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 11:01 PM
