Old Aug 28, 2012, 01:30 AM
Wufnu is offline
Find More Posts by Wufnu
Pickin' an a Flyin'
Wufnu's Avatar
United States, TN, Knoxville
Joined Apr 2004
Could someone with a Champ brick laying around measure it for me? I want to use Champ guts in a balsa FF conversion and I'm curious whether the brick will fit.
Edit: Also saw someone that mentioned flying with a P51 motor on the stock Champ batteries (150mah 12C, I think) is not good (a person had experienced stuttering and shutoff). I'm curious if the Tenergy 160mah 15C batteries would be good with the P51 motor.
Edit2: If anyone has a RTF Champ in questionable condition and would like to sell, PM me please. Must include Tx, charger, etc.
Wufnu is offline Find More Posts by Wufnu
Old Aug 28, 2012, 03:02 PM
davidterrell80 is online now
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Looking at Champ.Mk.1 (currently undergoing conversion to a twin rotor, coaxial auto-gyro)
From front to back, in aircraft coordinates, the circuit board is 23mm long and the overall length, including the servo gearing in the front and the throttle plug in the back, is 25mm.
The circuit board is 27mm wide.
The right servo drive axis is 4.5mm from the right edge. The left servo axis is 7.5mm from the left edge. In their neutral position, the center servo connections are 7mm aft of the circuit board LE. Total servo travel is about 10.5mm.
Also, I've had zero problems with the P51 motor and any of my stock batteries; but, I monitor my batteries's performance closely and avoid flying to LVC.
davidterrell80 is online now Find More Posts by davidterrell80
Latest blog entry: Ace Wing Cores
Old Aug 28, 2012, 03:27 PM
Wufnu is offline
Pickin' an a Flyin'
Wufnu's Avatar
Joined Apr 2004
Thank you, David! The fuse is 1 1/8" (28.56mm) square so it looks like it will be a perfect fit.
I'll keep that in mind about the batteries, as well.
Old Aug 28, 2012, 03:38 PM
medic45 is offline
Find More Posts by medic45
United States, KY, Booneville
Joined Jul 2012
I just placed my Um P-51 reciever in my Champ. Everything works GREAT the only issue now is that the rudder is on the L side. Id like to have it on the R side along with the elevator!!! Is this possible??? I am using a Dx6i..
Thanks ahead of time for all help...
medic45 is offline Find More Posts by medic45
Old Aug 28, 2012, 05:53 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Do this but reverse the order of the two items in the top line... this picture shows how to get the (stock) Champ's rudder over on to the left stick in the first place...
North_of_49 is offline Find More Posts by North_of_49
Old Aug 29, 2012, 03:56 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Basically, what Nof49 means is to set the Aileron--> Rudd so that Aileron maps 1:1 with the rudder channel.
That should do it. You then have rudder inputs on BOTH sticks, FYI.
SkyCadet
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Aug 29, 2012, 08:02 PM
Mikeamondo is offline
Find More Posts by Mikeamondo
Joined May 2012
Quick question.... When you change the tires on your Champ, then go flying and land in the grass and watch one of your tires go rolling across the lawn and then spend a half hour on your knees looking for that tiny black retainer and finally give up and have a bowl of ice cream..... Is there a good substitute for holding your neato tundra tires on your Champ?
Mikeamondo is offline Find More Posts by Mikeamondo
Old Aug 29, 2012, 08:25 PM
Joined Apr 2012
For the wheel retainer... I didn't even look... I cut a small piece of plastic, used a fine needle to stick a undersized hole through it, and pushed it on to the wire.
Old Aug 29, 2012, 08:38 PM
Joined May 2012
That sounds way to easy. I will give it a try, but I was pretty sure there would be cussing and tooth grinding involved.....
Thanks!
Old Aug 29, 2012, 09:22 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
You can also dab the very end of the wheel axle with drops of CA or Sally Hansen Hard as Nails (clear). They will pop off when you are ready to pop them off scrapping the end of the axle with a hobby knife.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Aug 30, 2012, 02:04 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Mike.
booger Wheel nuts have been proposed here too
mutha is offline Find More Posts by mutha
Old Aug 30, 2012, 05:16 AM
Joined May 2012
Cool! I already have everything I need to do it that way!
Old Aug 30, 2012, 08:50 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
EEEWWWW!!! You'll need to get a much bigger hobby knife to remove the wheels
Mike.
Old Aug 30, 2012, 06:16 PM
Airhead600cc is offline
Find More Posts by Airhead600cc
Chris
Canada, NS, Queensland
Joined May 2012
Mike.
Don't you mean a much booger hobby knife?
Airhead600cc is offline Find More Posts by Airhead600cc
Old Aug 30, 2012, 06:40 PM
Joined May 2012
Heh heh Heh. Booger. Heh heh....
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
