Old Aug 06, 2012, 05:45 PM
Airhead600cc is offline
Find More Posts by Airhead600cc
Chris
Canada, NS, Queensland
Joined May 2012
Hey North,
Good to follow your progress. When you're all done, let me be first in line for a 'kit'. I have a brand spankin' new Champ waiting for its winter transformation No pressure...
Airhead600cc is offline Find More Posts by Airhead600cc
Old Aug 07, 2012, 01:31 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by Airhead600cc View Post
Hey North,
With the insane amount of time I spent on this... 'hope your pockets are deep
Will have video hopefully tomorrow of the whole thing (with the nav lights and wing landing light) assembled and ready to fly... looks killer!
Here's a few screen grabs from some ipod video for now...
Description: Name: vlcsnap-2012-08-07-00h45m58s214.jpg
Description: Name: vlcsnap-2012-08-07-00h51m19s202.jpg
Description:
North_of_49 is offline Find More Posts by North_of_49
Old Aug 07, 2012, 04:52 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
It makes me think of Christmas... I think it needs a little Elf Hat logo on the tail.
All kidding aside, it looks wonderful!
davidterrell80 is offline Find More Posts by davidterrell80
Old Aug 07, 2012, 10:02 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
That's pretty cool.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Aug 08, 2012, 10:31 AM
teflon97239 is offline
Find More Posts by teflon97239
teflon97239's Avatar
United States, OR, Portland
Joined Aug 2011
Rebuilding a shattered Champ here and I want to treat some of the replacement foam parts first, particularly the tailfeathers. I've read here about a reinforced skin of thinned white glue, which certainly can't hurt (and doesn't add much weight/drag).
Do I want common Elmer's white glue? Or am I looking for something more specific at a hobby or craft store?
Thanks in advance fellers!
teflon97239 is offline Find More Posts by teflon97239
Old Aug 08, 2012, 04:03 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I'm a newb at planks/Champs. I have already traced out new tail feathers onto a pattern. Set that aside. I've learned to use "foam safe" CA which is suppose to be oderless as opposed to regular CA. After a repair with "foam safe" repair some opt to use a fine mist spray "chemical" referred to as "kicker." I just repaired my wing (a hairline crack) and used "Great Planes" Pro Foam Safe CA (thick) and then misted it with some "kicker" after about a minute or two. I think many would prefer the "medium" or "thin" CA. I got "thick" because that's all they had
But, she's fixed up like new and awaiting calm winds
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Aug 08, 2012, 05:57 PM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
Don't add anything except a speckle of tape where it's needed. Champ is as nearly perfectly balanced out of the box as any plane. Any massive amounts of weight you add to the -tail- you need to add weight to the -nose- to maintain CG.
Here's how balance works. The longitudinal 'center' of the tail area is appx. 8.5" behind the CG. To maintain CG, for every 'x' amount of weight you add to the tail -behind- the CG you need to add 8.5x that weight 0.85" in -front- of the CG.
Example, let's pick a number and say you use 10 drops of white glue to coat the tail. You need to add a mass equal to EIGHTY FIVE drops of dried white glue and mount it 0.85" in front of the CG.
Example, a few folks talk about laminating tape to the tail surfaces. At a quick eyeball the surface area of the v and h surfaces are 18si. (That's one side not both sides.) The 'balance' amount of weight, added 0.85" in front fo the CG, is a mass equal to 153si of the tape material. a little over a square foot.
The result of adding 'whatever' amount of weight for reinforcement -behind- the CG is drastically multiplied by the amount added in -front- of the CG to retain CG as designed. Sure you can add down elevator, but that raises stall speed and detracts from basic handling stability.
There are only a couple of weak spots that need reinforcement, not the whole surface. I've bent and/or creased 2 spots in my rudder near the top. On each of those spots I added about 1/2si piece of transparent scotch tape, and they've never bent again. I also broke the root of the v-stab, and had to CA that. My H-stab is getting weak and I will add struts up to the v-stab. But I've never broken or even creased the elevator.
Now of course everyone's mileage will vary but I've had *TONS* of 'tail first' landings, cartwheels, and 'on landing wind flips plane over and blows it down the runway' adventures. Wingtips look like a puppy chewed on them. LOL!! I have bonked that thing from every angle possible. Yet in the tail I've done serious damage at only a couple of the weakest points.
White glue BTW is *extremely* brittle. There's *no* flex. The first time it lands on a surface it shouldn't, with a touch too much force, it'll snap.
Oddly the one thing I've never broken is the wing, but that's mostly because early on I added a piece of CF to flatten the dihedral a bunch.
On mine it's the *NOSE* that looks like Frankenstein's monster had a -very- bad day in reconstructive surgery. LOL!! BTW don't know if it's been mentioned in this thread but 'crushed' foam can be 90% 'uncrushed' in hot water.
The other thing that suffered drastically from landing on the tail is the rudder hinges. The coating delaminated from the foam. So I added some -tiny- specks of tape to make new hinges and even with casual use they need frequent inspection and touchup (pressing them back down.)
My main point is that it doesn't need atomic blast reinforcement. Fix the spots that break, as minimally as possible, and those points will become stronger. The weight that you add in places that would never have broken are totally wasted weight.
jbarchuk is offline Find More Posts by jbarchuk
Old Aug 08, 2012, 06:32 PM
Joined Dec 2011
Originally Posted by jbarchuk View Post
snip
snip
I read about this "strengthening" mod and came to this same conclusion myself without even trying it... seemed to me like alot of extra weight (compared to tape or braces) without the benefit of actually working
Old Aug 08, 2012, 10:56 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I use White glue to make areas of the foam more abrasion resistant. For areas like the underside of the nose or the wingtips, especially if you fly off cement runways.
Paint goes away on the first nose over, and foam gets removed on every nose over after that if a harder coating isn't applied.
UNGN is offline Find More Posts by UNGN
Old Aug 09, 2012, 11:19 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Some white glues, like WeldBond, are somewhat flexible, and forgiving under certain sheer stresses. I had a Bushed champ clip a tree in the winter last year, and the wing was pretty much undamaged, yet I am 90% certain that a significant dent would have resulted otherwise, given how it hit.
SC
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Aug 09, 2012, 02:10 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Yep I was reacting to the Elmers word. There's also 560/canopy glue which smells kinda 'elmersish' but definitely is excellent where flexibility is needed.
The whole reinforcement thing though I take up to only a certain point. If I'm hotrodding and I hit something, well, whatever damage I come away with I figure is a small potatoes compared to all the ooohs and aaahs from the peanut gallery from the many times that I -did- get away with it. LOL!!!!
There's a 'challenge' thread that I want to take a video for. One of the challenges is to fl completely around a tree several times. There's a field near me with three trees in about a half acre area. Two of the trees have about 20-30' spacing between each other and then the treeline. Then the third tree is in a -corner-, with only about 6-8' space to go around it. A larger plane couldn't do this trick at all. I've gone around that tree and around the corner about a dozen times and successfully about 80%. The other two trees are difficult during the part where it 'disappears' behind the tree and all you can do is wait the few seconds till it comes out the other side. A little more practice and I'll be totally competent and comfortable with all 3 trees and then I'll do the vid.
Old Aug 09, 2012, 08:47 PM
dge is offline
dge
Find More Posts by dge
dge
United States, TX, Weatherford
Joined Mar 2012
Bad day in aviation
I was flying my champ today in some light wind. I was about 50 ft doing some hard turns when suddenly my wing flew off. Crashed hard. tore the tail off and broke the prop shaft.
Does anyone know if a um p-51 motor and gear box work on a champ? I know the motor works, just not sure about the gears.
dge is offline Find More Posts by dge
Old Aug 09, 2012, 10:32 PM
Joined Apr 2012
The UM P-51 motor and gearbox works very well! I think the gearing is the same, actually.
Old Aug 10, 2012, 03:13 PM
Joined Dec 2011
LED mod with 7556 timer IC
Got the Champ back together with the LEDs and timer. Am working on combating a weight increase due to the fiberglass circuit board and using a more powerful battery but I may have some solutions for both of those. Did my maiden last night... pure awesomeness Flying in the field out behind my place, it looks like a real plane. There's a road bordering the field at one end, I'm sure people driving by were watching it thinking it was a real plane only higher and farther away... was thinking, what if I looped it?
... or crashed it
The green LED is really bright when viewed head on... lights up the ground like a flashlight for about 20 feet when it's in my hand... I use it to find my way to and from the middle of the field in the dark (I could probably put a higher resistor on it and save some current draw)
Here's some pics and crappy ipod video (non flying). Might get my buddy to video it flying tonight.
Description: Name: Champ-LED-done-stage-1-014.jpg
Description: Name: Champ-LED-done-stage-1-016.jpg
Description:
Description: Name: Champ-LED-done-stage-1-006.jpg
Description:
click image to watch at YouTube
Old Aug 11, 2012, 11:02 AM
GRUMPEE is offline
Find More Posts by GRUMPEE
Mr. Magoo's Co-Pilot
GRUMPEE's Avatar
United States, CA, San Diego
Joined Sep 2009
Sweet Looking Flyer N_49
GRUMPEE is offline Find More Posts by GRUMPEE
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
