Old Jul 13, 2012, 08:01 PM
kilabean is offline
Find More Posts by kilabean
I just need one more plane..
kilabean's Avatar
United States, VA, Fairfax
Joined Jun 2012
In about twenty lipos I haven't crashed the champ yet. I'm on a fuggin roll! Got down figure 8's and loops and I think they're called knife edges... got those pretty locked down. And then I got this trick down where I try to go straight up and it stalls, when it starts to fall I slam the throttle and do this corkscrew thing that looks pretty legit. Anyhow I just wanted to express my love for the champ, I went from crashing every 19 seconds to a pretty decent pilot in a month. Thinking about getting the carbon cub to try my hand at some 4ch action.
kilabean is offline Find More Posts by kilabean
Old Jul 13, 2012, 08:08 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by kilabean View Post
Thinking about getting the carbon cub ...
Description:
North_of_49 is offline Find More Posts by North_of_49
Old Jul 13, 2012, 09:45 PM
teflon97239 is offline
Find More Posts by teflon97239
teflon97239's Avatar
United States, OR, Portland
Joined Aug 2011
The cowl broke off my champ so I Modded it with stale french bread from an old hoagie I had laying around. I had to tape a piece of salami to the tail to balance it out but man that thing flies great now.
Bonus! Properly feathered in, you can't tell where the paint stops and the mustard begins!
teflon97239 is offline Find More Posts by teflon97239
Old Jul 14, 2012, 05:50 AM
shawn pierce is offline
Find More Posts by shawn pierce
shawn pierce's Avatar
United States, LA, Houma
Joined Mar 2005
placed wing in over inbetween two cookie pans. 230degrees for 5-7 minutes. take out then let cool. tape/glue carbon rod on.
shawn pierce is offline Find More Posts by shawn pierce
Old Jul 14, 2012, 06:24 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
This thread is starting to sound more like a baking class
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Jul 14, 2012, 10:37 AM
Airhead600cc is offline
Find More Posts by Airhead600cc
Chris
Canada, NS, Queensland
Joined May 2012
No sprinkles?
Airhead600cc is offline Find More Posts by Airhead600cc
Old Jul 14, 2012, 11:48 AM
Joined Mar 2005
ha could prob do the same with a heat gun. I tell you what, it flies good but was a handfull before I added expo and trim.
Old Jul 14, 2012, 12:20 PM
Joined Dec 2011
Thanks, bro
I tried using a heat gun to take the curve out of another type of foam... same thing, heat and flatten... was just an experiment on some scrap...
... there's a very fine line, when using that device, between it not doing much or destroying the foam instantly and without warning. The problem is there's no way to gauge how much heat you're applying (without sticking your hand under there... which I DON'T recommend).
Old Jul 14, 2012, 12:58 PM
Joined Mar 2005
thats true. i melted quite a few myself before
Old Jul 14, 2012, 11:44 PM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
Originally Posted by Airhead600cc View Post
No sprinkles?
Turbulators would definitely lower the stall speed, and this is a high wing cub style so lowering the high end of the speed range isn't that big a deal.
Yeah, I'd say go for it!
Looking forward to the bake log!!
jbarchuk is offline Find More Posts by jbarchuk
Old Jul 15, 2012, 01:08 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Quick question? How come every time I use my DX5 to fly my Champ it needs a rebind if I use it to fly my Super Cub and vice versa. Multiple flights on the same plane no rebind. Switch and I have to rebind. What gives?
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Jul 15, 2012, 07:03 AM
kilabean is offline
kilabean's Avatar
Joined Jun 2012
I'm fairly certain the dx5e is a one model tx right? Yes just searched it. You can only bind one at a time. The Dx6i has a ten model memory if you want more you gotta upgrade!
Old Jul 15, 2012, 07:27 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
The Dx6i can store different settings for ten planes, but I have successfully bound one of the "video game" transmitters to two UM planes.
The bind process is one-way in that the receiver learns which transmitter to listen to. It transmits no signal to the transmitter-radio to identify it, as far as I know.
Are you making sure that the transmitter is powered on before the receiver... every time?
Have you tried cycling the power of the transmitter as part of the switch process? I can imagine the transmitter doing a frequency-hunting check as part of power-up.
I suggest trying this sequence... after separately binding each aircraft to the one transmitter.
1. All systems off.
2. Transmitter (Tx) on... wait for bind.
3. Aircraft A power on... wait for light.
4. Aircraft A should be ready to fly.
5. Aircraft A power off.
6. Tx power off and let settings save.
7. Tx on... wait
8. Aircraft B power on... wait for light.
9. Aircraft B should be ready to fly.
10. Aircraft B power off.
11. Tx power off and let settings save.
davidterrell80 is offline Find More Posts by davidterrell80
Old Jul 15, 2012, 12:54 PM
Joined Dec 2011
quitcherbitchen...
I'm pretty sure the DX5e is the same as the DX4e, which I own, as far as binding goes. I have all 4 of my helis bound to it... never requiring a re-bind to fly any of them with that specific Tx. (I only need to re-bind if I switch to a different Tx like to my DX6i for example).
Yours should be doing the same.
(In fact, haven't tried it yet, but I should be able to fly them all at the same time )
And that is probably why
Old Jul 15, 2012, 04:46 PM
Bombs away!!!
Joined Jul 2011
I am using the sequence you suggested. My DX5 is new to me. I only bought it to use the buddy plug for the other Spectrum radio I already had a DX4e. I have owned about every PCM FM radio ever made(literally) and have an A9. The Champ is my first UM and got tired of the stock transmitters range. So now I think I am stuck is some rebind disorder as in maybe I should rebind them at the same time. I always have to rebind the Cub after I want to switch to the Champ. Others have told me they have no problems doing it, but I do. I know I am doing something out of sequence, but it is not the power on to off. Should I bind the Cub first using the bind plug and then the Champ? Either way I hit the trainer switch first then power on and it seems the transmitter loses the bind to the other plane.
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
