Old Jan 15, 2012, 02:07 PM
noob
Veccster's Avatar
United States, PA, Greensburg
Joined Oct 2011
Wanted to fly today and it was about 32'F outside. I fabbed up some battery insulation that worked well. Thought I'd share some pictures.
I used a small piece of foam tubing and used a drill to hollow out the middle for the battery to sit.
This is the tubing - cost $1.50 at Lowes.
Used a twist tie wrapped around the landing gear.
Two boring videos:
Winter flying with my HobbyZone Champ - 1 (1 min 54 sec)
Winter flying with my HobbyZone Champ - 2 (3 min 20 sec)
Veccster is offline Find More Posts by Veccster
Old Jan 15, 2012, 03:16 PM
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
That looks like an external drop tank. Nice!!!
leethetreeguy is offline Find More Posts by leethetreeguy
Old Jan 15, 2012, 05:31 PM
Joined Oct 2006
sweet flying, motor sounds dog barkin, yep nice Mod, gots to look for some here if I fly thanks for the tip
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Jan 16, 2012, 03:29 AM
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
That looks like foam backer rod or "caulk saver". Am I right?
makg is offline Find More Posts by makg
Old Jan 20, 2012, 09:55 AM
noob
Veccster's Avatar
Joined Oct 2011
yes...it's caulk saver. It was killing me that I couldn't think of that....thank you!
I like it because it's light and you can cut the hole in the middle of it as big as you want.
I'm sure others came up with better ideas for insulating their batteries but I thought I'd share mine.
Old Jan 20, 2012, 10:39 AM
Joined Dec 2011
is it really that bad to fly the plane in the cold?
Veccster im like 200 miles south of you and it is really cold too and i just fly. but it is decreasing performance/battery life?
Idk how much more flying im going to do tho cause my hands turn blue cause its cold... a heated TX would be super nice
nate32 is offline Find More Posts by nate32
Old Jan 20, 2012, 11:04 AM
Endlesslag's Avatar
USA, VA, Spotsylvania
Joined Jan 2011
Someone beat you to it http://www.rcgroups.com/forums/showt...143460&page=31
order one of those and a heater set from HK and you're good to go
Endlesslag is online now Find More Posts by Endlesslag
Old Jan 20, 2012, 05:40 PM
United States, NC, Pilot Mountain
Joined Oct 2011
Anybody know the stock thrust of the champ? Considering making a UM nutball out of my first Champ.
Ikankrachuhmoll is offline Find More Posts by Ikankrachuhmoll
Old Jan 21, 2012, 11:44 AM
noob
Veccster's Avatar
Joined Oct 2011
Yes, the lipo's are affected by the cold air. Insulate them and you can stay in the air longer. I was even told to keep them warm (in your pocket) until you are ready to fly.
I have been wearing light gloves while I fly. It takes some time to adjust to the controls though - loss of touch. It was also difficult because I had to hold TX while using the controls. I need to add a strap that goes around my neck so I can focus on the controls.
Old Jan 21, 2012, 12:06 PM
Winder Ga
Joined Sep 2008
Holding a tx with your hands is a bad habbit. Like holding a guitar with your hands. They need to be able to move freely at all times. I still don't like a strap on my banjo, mandolin, or guitar. Because I learned without a strap. Fix this now, while there is still time to correct. haha. Lee
Old Jan 21, 2012, 12:09 PM
Endlesslag's Avatar
Joined Jan 2011
No, I dont BUT I built a 14" nutball out of UMX beast parts and it's insanely overpowered. 12-14" diameter should be no problem with the champ parts with dollar tree foamboard
Old Jan 21, 2012, 12:38 PM
noob
Veccster's Avatar
Joined Oct 2011
And there's my motivation to go fab something to the Champ TX. Be right back...
Thanks lee.
EDIT...OK, so it's NOT pretty. I'm headed out to see if it works but have a feeling the straps will be in my way. Afraid to even show a picture of what I "manufactured"
Do they sell straps that would fit the Champ's TX?
Old Jan 22, 2012, 09:12 AM
Joined Jan 2012
Glue wash
I bought a Champ for my boys and I to fly and spend time together. Loving every minute of it. Of course I have to make sure that the plane is flying properly before I hand over the controls but by that time the second battery is half way used up (Safety reasons, you know ) . I read about the "glue wash" to strengthen the foam and attempted carefully to do so. Long time model RR so I'm familiar with these white glue washes. My question is if the glue wash is to be done after the paint is stripped? Most of the wash just beads up on the paint and not getting good coverage/penetration.
Miguel
Tree Finder is offline Find More Posts by Tree Finder
Old Jan 22, 2012, 09:30 AM
Occupying RCG
olthump's Avatar
United States, MS, Ocean Springs
Joined Sep 2009
Miguel,
First of all, let me welcome you to the Champ community. Flying with your children must be a real treat. Check out our "off-topic" Champ thread as well, we talk about all our stuff over there.
I dont have personal experience with the glue wash technique. However, I'm fairly certain that what you are encountering is a wax type coating on the waterbased paint. I would simply wipe the surface with either de-natured alcohol or ???
I'm not really sure of what to use that wont mess up the paint, and dont want to make a wrong suggestion. Prehaps someone else will chime in here with what can be safely used.
I do know that sometimes, when you make something stiffer, the damage can be worse in a given situation because you change the material's ability to dissapate shock. And any coating adds weight. I've painted my Champ, and it does make a noticable difference. Not bad, but noticable.
Welcome, and Good flyin' to you and your boys.
Greg
olthump is offline Find More Posts by olthump
Old Jan 22, 2012, 09:47 AM
Joined Jan 2012
Thanks for the welcome Greg. Flying with my boys is a blast, already gone through 1 wing and tail replacement. The boys (8, 10 & 47) are learning that the ground and trees are harder than the plane. They are doing quite well with flying now. After reading through all of 236 pages of this thread I'm ready to start modifying a few things and I do understand the weight issue.
Miguel
Article HobbyZone Champ RTF Review dee-grose Micro RTF 866 Apr 03, 2013 08:00 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 2 Jun 25, 2010 02:47 PM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
