Old Dec 14, 2011, 03:10 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Should work just fine. I use an extention connector for some batts that are too big to fit in the charger. Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Dec 14, 2011, 06:10 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Another alternate battery arrangement, which I have mentioned a few times before: Hyperion 240, 25C
Works great on the Champ, Mustang, Cub, T-28...........
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Dec 15, 2011, 11:27 AM
eagle1933 is offline
Find More Posts by eagle1933
Dallas USA, TX
Joined Jul 2010
I'm getting ready to replace the tail on my champ. Is there any preference as to what kind of glue to use to attach the rudder and elevator control horns? Any tricks to doing this or things to look out for?
Thank you.
eagle1933 is offline Find More Posts by eagle1933
Old Dec 15, 2011, 11:47 AM
olthump is offline
Find More Posts by olthump
Occupying RCG
olthump's Avatar
United States, MS, Ocean Springs
Joined Sep 2009
Thank you.
eagle,
Take note that you dont glue them on backwards...as I did on an elevator horn once.
My adhesive choice is white Gorilla Glue or 5min epoxy, 'cuz they add a little fillet of goop for support. Foam safe ca will work as well.
Greg
olthump is offline Find More Posts by olthump
Old Dec 15, 2011, 01:33 PM
astronaut is offline
Find More Posts by astronaut
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
Wowee Doug, that Champ looks crisp!
I can't believe mine looked like that out of the box. Although I do think I have maintained it quite well for the past 8 months. I'd say 90% of the blemishes and damage is from the first 30 minutes of flight
I like the Hyp 240 you got, it's a great battery. I replaced the micro plug with a regular one though (on my Champ too). Makes all my batteries and chargers very interchangeable, and easier to handle. The pins on the micro plugs get flimsy and started giving me bad connections (mid-flight shut downs = scary!)
astronaut is offline Find More Posts by astronaut
Old Dec 15, 2011, 02:26 PM
Dallas USA, TX
Joined Jul 2010
Thanks for the advice olthump. Got it done with Gorilla glue. I can sure see how it would be easy to glue these things in backwards.
Old Dec 15, 2011, 02:47 PM
Winder Ga
Joined Sep 2008
I am considering making a true wing for my Champ. Complete with ailerons and maybe flaps. By true wing, I mean curved on top and flat on bottom. Anyone tried this yet?
Lee
Old Dec 15, 2011, 03:59 PM
olthump is offline
Occupying RCG
olthump's Avatar
Joined Sep 2009
Lee
Lee,
Check out these airfoils...thread at top of scratchbuilt foam section.
Old Dec 15, 2011, 04:20 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Lee
There's a lot of aerodynamics research that demonstrates an undercambered wing - like the one on the Champ - is actually more efficient than a conventional airfoil for models like the Champ. There's no reason you can't add ailerons, either, though perhaps a bit less dihedral would be in order.
Cheesehead is offline Find More Posts by Cheesehead
Old Dec 15, 2011, 05:00 PM
Winder Ga
Joined Sep 2008
I agree. I think the dihedral would hinder the flight characteristic of the ailerons.
Thanks Olthump, I have been studying all that lately. I found some good instructional videos last night on the subject. Isn't foam wonderfull? hehe
Lee
Old Dec 15, 2011, 05:05 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
careful with the use of white gorilla glue.
Any part of that Champ, that isunpainted will do just that. you got the box, you try a lil dab.
I use Rubber cement
http://www.youtube.com/watch?v=TDxO1PKgGvw
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Dec 15, 2011, 10:34 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Looks like a flesh eating infection!
I did the wing break thing and used regular white glue and some thin strips of packing tape over the seam after the glue cured. Rubber cement sounds good too.
whirlcap is offline Find More Posts by whirlcap
Old Dec 16, 2011, 08:05 AM
Dallas USA, TX
Joined Jul 2010
In the stock out-of-the-box Champ, are the pushrod z-bends in the farthest control-horn hole from the control surfaces(rudder & elevator)?
Old Dec 16, 2011, 08:11 AM
olthump is offline
Occupying RCG
olthump's Avatar
Joined Sep 2009
Mine were.
Further out, less control surface movement, futher in, more.
As an aside...
The box is made of a different type foam than the plane.
I have used white GG on my Champ without any ill effects.
Just my experience, YMMV.
Greg
Old Dec 16, 2011, 08:29 AM
Dallas USA, TX
Joined Jul 2010
olthump: In one of your posts a while back you show your champ with wing struts and also tail bracing between fin & stab and stab to fuse. What is your bracing and strut material and how did you attach each?
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
