Old Jul 18, 2011, 10:35 PM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
Agree with Lee. I had the same issue, and it was so small, it took close examination 4 times before I saw it. A quick trim with a new blade, and good as new.
The Hog Pen is offline Find More Posts by The Hog Pen
Old Jul 19, 2011, 01:07 AM
slow2by2z is offline
Find More Posts by slow2by2z
United States, TN, Seymour
Joined Jun 2011
Well, Lee and hog are geniuses lol. Very very fine debris in the prop shaft gear. Used a knife blade to very gently remove and she's spinnin free again. Thanks very much all!
slow2by2z is offline Find More Posts by slow2by2z
Old Jul 19, 2011, 01:28 AM
Go Ugly Early
Azle, TX
Joined Oct 2010
LOL...no problem. Although...I think it was UNGN, or one of the other vets that leaned me that way. Glad it worked out.
Old Jul 19, 2011, 06:28 AM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Hey, what about me??
Originally Posted by Endlesslag View Post
Might be the spur gear. Happens on mine sometimes if i crash with power on (I try not to though..sometimes stuff happens tho )
Look at the teeth where it's catching, maybe a damaged tooth or dirt in there. Try using a hobby knife to reshape or clean the affected teeth.
If not new shafts are $3 with the gear, may as well get some
Endlesslag is offline Find More Posts by Endlesslag
Old Jul 19, 2011, 06:35 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Nahh you didn't count -
It funny that gearbox is really sensitive to a little bit of grit - even the tiniest amount.
I flew my UM Sukhoi with a friend who was flying his Champ - he was chatting to me whilst we were flying and doing some nice scale circuits ... I was sweating blood trying not to dirt nap the Sukhoi in the wind .... miss my little champ going to have to put the tailplane back on and roll it out for some peaceful air time!
mutha is offline Find More Posts by mutha
Old Jul 19, 2011, 10:19 PM
Joined Jun 2011
Haha thanks EVERYONE.
Flew her today and she was great. Grass at the park was off limits for some stupid reason so I was having to launch from and land on the sidewalk in a spot about 10' x 8'. No sweat, plenty of lift to roll off the sidewalk and would glider her in and land on the same spot. Did some touch and goes and let a friend give it a try after I got him some altitude. Think he might get one lol
Old Jul 20, 2011, 12:59 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Just so long as all y'all recall I have the first reported servo gear bent-tooth reshaping fix...
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Jul 20, 2011, 01:44 PM
Mr.Firemouth is offline
Find More Posts by Mr.Firemouth
Sir-Crash-a-Lot
Mr.Firemouth's Avatar
United States, IL, Edwardsville
Joined Jun 2011
Great News!!! I talked a new member here...Dangerous444, into buying a Champ! He is stoked! Our shared experience with his P-51 UM was a disaster. We do however have a P-51 motor!!!! LOL
I just also fixed my Champ that has all the packing tape on it. The nose dive from the wing snap made the fuselage about a 1/4" shorter than the new fuse. It was flying but the prop started to have play. I suspected that it had spun loose, but when I opened her up I found that the foam around the engine had torn loose and that the damage was extensive. I replaced the fuse w/electronics, took the upper fuse and wing section and mounted it my new fuse and transferred the tail feathers. They were looking more V-shaped then level so I reinforced them with a carbon fiber rod across the elevator flaps. I flew it today, and it flew great, but the prop tightened onto the fuse. (5043 prop). I have used CA glue, but it tightened again. Any tips on how to get the prop to stay put?!?
Mr.Firemouth is offline Find More Posts by Mr.Firemouth
Old Jul 25, 2011, 01:35 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
What are you using to hold the 5043 prop on? I've always used the little wood prop adapters from radical rc and never have had an issue with them.
jlcamp7 is offline Find More Posts by jlcamp7
Old Jul 25, 2011, 08:41 PM
mutha is offline
mutha's Avatar
Joined Jan 2011
Good question ... has anyone made their own adapters for the 5030 or 5043 props???
I am down to one prop-saver adapter - am beginning to think a glue in one would be better - also thinking that I might be able to drill my own ... I haven't used the wooden ones -are they glued in or are they prop saver as well ... does someone have a link?
Old Jul 25, 2011, 08:59 PM
astronaut is offline
Find More Posts by astronaut
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
Ridgwalker made a video describing how to make an adapter using shrink tubing. Works very well for him. I have tried, but I can't seem to find his video...
astronaut is offline Find More Posts by astronaut
Old Jul 25, 2011, 10:28 PM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
My Champ came today. Put larger tires on as all my flying is off the grass. Couldn't resist a maiden even though we had 10 knot winds. No problem stock out of the box with stock battery pushed forward. Did move the rudder control in two holes upon landing for a bit more turn authority.Motor sounds rougher than my T-28, but the Champ sure handles the wind better!
Will the G FLYER decals on the wings come off somehow without messing up the paint?
WSEN is offline Find More Posts by WSEN
Old Jul 25, 2011, 10:29 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
I will make a new how to video tomorrow.
Ridgewalker
ridgewalker is offline Find More Posts by ridgewalker
Old Jul 25, 2011, 11:00 PM
mutha is offline
mutha's Avatar
Joined Jan 2011
Ridgewalker
Your original post is here
http://www.rcgroups.com/forums/showp...postcount=7150
Old Jul 26, 2011, 10:13 AM
Joined Aug 2008
Originally Posted by mutha View Post
Thanks for finding that.
I have since just been using shrink tube alone with no carbon fiber.
Two wraps of the blue and two wraps of the red.
then the 5043 prop gently slides over the shrink tube and then i use some ca glue and let it seep in while i apply a small drop on the end.
Give it a test spin first to make sure the prop is centered.
I have the prop on my Champ mounted this way as well as the prop on the um T-28 and have never had any trouble.
**EDIT**
Video will have to be put on hold til i pick up some more shrink tube,thought i had some left but i'm out of the 1/8'' stuff.
Below are a couple pics of the shrink tube sizes you need to make a prop adapter.
You will use two wraps of the 1/16'' place one length over the prop shaft,dry no glue,shrink it,not too much though...just enough to form around the prop shaft.
Then slide another length of the 1/16'' over the first one that you just shrunk.
It can be tough getting the second 1/16 one over the first one,just takes some finesse.lol
Shrink the second 1/16 piece over the first 1/16 piece.
Now do the same thing with the 1/8'' shrink tubing,two layers over the two 1/16'' pieces already on the prop shaft..
Now the 5043 prop should just slide right over the shrink tube.
It should be a smooth fit,you don't want there to be a gap between the shrink tube and the prop because then the prop will wobble because it is off center,check this before using any glue.
If you find that the prop is to loose over the shrink tube....then you have to use a razor and cut the shrink tub from the prop shaft and start over.
That's why i say not to shrink it to much.
It might take a couple tries till you get it.
Use a lighter to shrink the tube if you have one.
After the prop is on there what i do is plug in the battery on the plane and give it a slow spin up with the motor,very slow.
This is when i watch the center hub on the prop to be sure the prop is centered.
Then i place a small drop of ca glue on the end of the prop where the spinner would be so the glue seeps into the shrink tube,then give some throttle and spin the prop up slowly and then it should be ready to go!
Like i said the Champ and T-28 both run the 5043 this way and never once have there been any issue,even survived a few crashes!
Doing it this way is much easier than using carbon fiber tube and can be done with minimal tools...lighter,razor blade,shrink tube and some ca glue is all you need!
Ridgewalker
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
