Look for the Motors with 2 holes in the front face. These are the new ones. |
Latest blog entry: AR6400 guillows Space Shuttle
All the black backed motors have the same winding spec's. There is a huge variation from motor to motor and sometimes you can get a powerful one and sometimes you get a not so powerful one. Even the not so powerful ones have more thrust than a white endbell motor in a Champ or original sukhoi.
The old motors didn't have holes in the front, the new ones do. The XP was the first plane to get the new motors. That was last year. Anything Horizon ships should has the new motors now. There is nothing special about a current XP motor over an Extra 300 or a motor that now comes in a 4 site. The XP motors may have a tiny bit more thrust than the others because the wires are shorter, but it shouldn't be all that noticeable in a Champ. |
Joined Oct 2006
As UNGN noted - it's just the standard variability in output between motors that we've noted since HH produced their first 8.5mm motored planes. The P-51/4-Site/XP/T-28/F4U definitely use the same black end-bell motor. Only the lead lengths are different. The newer black motor with the holes in the case has been disassembled & compared with the older black end-bell motor, and was found to be electrically & mechanically identical to the original. The Mossie's motors are also the same as the P-51 motor - except that the starboard motor's end-bell is mirror-imaged to prolong brush life with the ccw rotation. The mSR also uses the same motor as the P-51 - with a different pinion. The Champ & the original Sukhoi 26m share the lower-power white end-bell motor. These things have been well-documented by those of us who have been flying & experimenting with these UM ships since the original Sukhoi 26m was released a few years ago. The Nine Eagles Solo Pro motor has the same power as the P-51 motor, with superior longevity. Their Bravo SX/P-47 motor w/5043 provides a ~30% increase in thrust over the P-51 motor w/5043. (Requires a Hyp 180, at minimum.) So....what you observed is normal; however it is due to the standard manufacturing variability between samples within the same motor model. It is not due to any electrical difference between the XP, P-51, or T-28 motors. Even a 5% variability in output between samples is noticeable in an airborne application - and we've noted about a 20% spread between samples of the 'P-51 motor'. Independent static testing (current draw, RPM & thrust data) done by a number of people on the UM forums has confirmed the above. Joel |
United States, FL, Jacksonville
Joined May 2011
I agree with Greg 100%. And I have been proven wrong. I will assume that I simply got lucky with "better" motors. After that extensive summary I feel that I owe you an apology. I do apologize. Nows I got a few questions. Why was there a series of mustang motors that were bad?why would HH claim the suk motor is better? where do I buy a nine eagles motor. what mods and parts are required for install? And best of all, got any new mods up your sleeve? Btw to everyone, my laptop has crashed so I will be posting all my pics tonight. Sorry for not getting them up earlier. |
FRT - no apology needed! This stuff is tough to keep track of sometimes, and there is plenty of misinformation flying around. Here's a thread on putting the Nine Eagles motors in UM planes that use the 8.5mm motor mount. http://www.rcgroups.com/forums/showthread.php?t=1326158 Either motor requires a pinion & connector swap. If you'd rather not do it yourself, RCBabbel sells them ready to go. Here's a clip of mine with an SP motor, 5043 prop, and Hyp 180 cell. The SX motor provides ~30% more power than this:
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined May 2011
Joel,
Thanks for the info on the super motor. Looks like a new project for me. To everyone... My computers have all crashed. No idea what happened so they both went to get reformatted. Anyways, I have as many as 15 pics to post on here and no way to do it. If anyone would be so awesome to send me an email, I'll pass them to you if you could post them here. My email is levi<dot>oshea(at)gmail.com Thanks everyone!! |
Removeable motor mount
Im experimenting on the Champ motor mounting on the airframe
its always a pain removing the motor/gearbox if you have to work on it like cleaning accumulated gunk on the gears, oiling cleaning the bush bearings, replacing the shaft, replacing the motor etc or just general maintenace or work of the gearbox motor unit. This is an old gearbox on a new fuselage that im building and I removed all the 4 pins as they were almost breaking off anyway then just added 2 nylon screws embeded on the fuse held by nylon nuts. do you guys have any other means of quick GB removal ? or do you always have to cut the glue and dig out the gearbox out of the foam everytime. |
hey Ridge
this is just an "experiment" as I have mentioned above and have not flown the a/c as pictured above. I do hope it works out ok as Im tired of yanking the g/b each time i have to work on it. Yes the gearbox is tight when the nylon nuts are secured but i intend to still use glue[sparingly] around the edges of the moutn as im worried that a nose-in-the-ground crash might break the foam around the nylon bolt. will let you guys know as soon as I put flight time on this build and see if it really works |
what i was intending to do is drill 4 holes on the g/b mount and push thin carbon fiber rods through into the foam to replace the 4 original pins that were there. then I could just easily pull them out if i need to remove the g/b from the airframe btw those were the smallest nylon bolt/nut i could find seems they don't make em smaller than that ! |
| Thread Tools | |
| Article HobbyZone Champ RTF Review | dee-grose | Micro RTF | 866 | Apr 03, 2013 08:00 PM |
| Discussion HobbyZone Champ On-board Video | VasMan | Aerial Photography | 2 | Jun 25, 2010 02:47 PM |
| Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) | PerlAddict | Hot Online Deals | 5 | Jun 16, 2010 06:00 PM |
| Wanted Hobbyzone Champ | pmass23 | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 01, 2010 01:17 PM |
| Video Hobbyzone Champ - Short Glide Video | VasMan | Electric Plane Talk | 0 | May 16, 2010 10:01 PM |
