Old Jul 17, 2010, 10:10 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Originally Posted by BigD1961 View Post
Has anybodyused their DX6I with their champ, and if so, what settings do you use?
I use the Spektrum DX6i for almost all of my micro fleet (Embers, J-3 Cub, Um Mustang, Champ). My initial set up for the Champ is as follows:
Full Rate: Aileron 100%, +5% Expo; Elevator 100%, +10% Expo, Rudder 100%, no Expo (Inhibited)
Dual Rate: Aileron 80%, +10% Expo, Elevator 80%, Expo +10%, Rudder 100%, no Expo (Inhibited)
Rudder settings are moot as you are not actually using the left stick for rudder. The Champ is so easy to fly, I use full rates all the time, no need for dual rate. Rudder linkage and elevator linkage set at second hole in from outer most setting. Not sure if that is stock. I'm thinking of changing both settings to gain some increased agility. Great little plane. Had a bad motor, it failed after only 18-20 flights. Replaced it with the UM P-51 Mustang motor.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Last edited by Doug Sipprell; Jul 18, 2010 at 09:29 PM. Reason: Correction to number of flights on stock motor.
Old Jul 18, 2010, 12:23 AM
canadianufo is offline
Find More Posts by canadianufo
Just gotta mod. it
canadianufo's Avatar
Northern British Columbia
Joined Dec 2006
Not quite finished with it and have not flown it yet but hoping for little wind tomorrow. Without having read this whole thread I'm assuming all those 120mah batteries I've got for the cub and um mustang will work ok...except for flight time of course...? I've added stacks up front, moved the tail wheel to the body and added struts. The floats I used for the um cub should work fine with the champ. Wheels are also larger.
canadianufo is offline Find More Posts by canadianufo
Old Jul 18, 2010, 08:52 AM
Ensign Jimmy is offline
Find More Posts by Ensign Jimmy
The building never ends!
Tucson, AZ
Joined Oct 2008
Yes, 120 mAH cells will work fine. Expect flight times to fall somewhere between the Mustang and the Cub. Very nice mods, BTW.
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Old Jul 18, 2010, 01:59 PM
Nunja Business is offline
Find More Posts by Nunja Business
Incorrigible
Nunja Business's Avatar
USA, AL, Silverhill
Joined Jun 2010
Really liking those DuBro wheels, I could probably ROG from my driveway with those.
Nunja Business is offline Find More Posts by Nunja Business
Old Jul 18, 2010, 08:59 PM
Just gotta mod. it
Joined Dec 2006
Thanks, but they are not DuBro, they are from a 2 channel B-52 plane from radio shack. these are DuBro...lol, a little heavy but if they work I have others of the same size but lighter. Stock wheel in the center.
Old Jul 18, 2010, 09:09 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Here are dubro's, part # 150wm If I recall, 2.15g per wheel, 1.5 inch tall:
~Kev
darksiede is offline Find More Posts by darksiede
Old Jul 18, 2010, 09:50 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
"Mustang" your Champ
After changing out the stock motor for the UM P-51 Mustang motor, I noticed a slight to moderate increase in performance. I stayed with the stock prop, and only changed to the Mustang motor because I had one on the shelf and it fits the Champ gearbox. However, along with this motor came an increased appetite for battery mAh's. Translation: the Mustang motor would eat a 130 or 150 mAh Lipo rather quickly, usually within 7 - 8 minutes of moderately aggressive flying, hitting the LVC. So, I figured I would do to the Champ what I did with the Mustang......go with a 240 1S Lipo, either the HK Zippy, or the Hyperion 240 1S. The photos show the Zippy 240, but the way to go is with the Hyperion 240's. 12-14 minutes of spirited flight before LVC. Modifiction is rather easy, just enlargen the battery "tray" via the use of a sharp X-acto knife, and shave the leading edge of the landing gear former slot, and you are good to go. With a stock Champ motor, the 240 1S Hyperion Lipo should provide some good extended flight times. The plane is a touch more nose heavy with the battery located as shown, but you could trim the plastic former for clearance and move the battery further back in the "tray". Photos taken when I was trying the HK Zippy 240's. Forget about them, and go with the Hyperion's. What works for the Mustang works for the Champ!
RDS
Latest blog entry: Big Red Cadillac
Old Jul 19, 2010, 07:50 AM
captdave221 is offline
Find More Posts by captdave221
220 221 Whatever it takes
captdave221's Avatar
USA, IL, Belleville
Joined Dec 2009
I was wondering if any one else was having issues with batteries? I have some that charge up ok according to my led on the Celectra but when plugged in they either run for a minute or so or the light in the brick goes out as soon as I throttle up. 2 batt's are e-flite 150's and the others are plain label I bought at a swap meet by the Belleville RC flyers this spring.
captdave221 is offline Find More Posts by captdave221
Old Jul 20, 2010, 03:31 PM
Just gotta mod. it
Joined Dec 2006
A few more details added,still more to go.
Old Jul 20, 2010, 04:12 PM
skiesthelimit is offline
Find More Posts by skiesthelimit
It works, don't touch it.
skiesthelimit's Avatar
Joined Dec 2007
What are the new eflite 250mah lipos rated for? 15C?
skiesthelimit is offline Find More Posts by skiesthelimit
Old Jul 20, 2010, 04:19 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
no idea.. I have one, and the label does not say.. So I peeled off the label, and the printing on the pack itself does not even say..
I do know that 15 minutes at full throttle does not even warm it up, and leaves about 115mah in the pack.. My flights are generally 30-40 minutes at under 50% throttle on this pack though..
~Kev
Old Jul 20, 2010, 04:22 PM
Joined Dec 2007
~Kev
Thanks darsiede! I couldn't find it anywhere on the internet. Well it sounds pretty good to me though whatever the rating happens to be.
Old Jul 20, 2010, 10:40 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Probably. I have the Tenergy 250 mAh Lipo, and it is rated at 15C. Most of these batteries are probably produced by the same manufacturer, thus similar specs. I use the Hyperion 240 mAh Lipo's in my UM P-51 Mustang, and more recently in the Champ (with Mustang motor). The Hyperion is about 1 gram lighter in weight, and narrower at the connection end. Not sure what the "C" rating is for the Hyperion. Haven't tried the Tenergy 250 on anything yet. Will have to try it on the Mustang.
RD
Old Jul 21, 2010, 01:52 AM
Just gotta mod. it
Joined Dec 2006
can't stop moddinnngggg....lol it's going to be a long 2 weeks off also went with larger tailwheel.
Old Jul 21, 2010, 07:18 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
That thing is really looking sharp.
Tony
t-turley is offline Find More Posts by t-turley
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
